686 Posts 32 Posters 0 Views 1 Watching
    ClassE said:
    Was the old electric aux fan JUST for the A/C system, or was that thermo switch there as a "safety net" to the fan clutch (if the fan clutch failed and the thermo switch hit its temp - it would kick on the elec aux fan?!?).
    If so - what you're describing makes perfect sense. Swap to a lower temp switch, and it'll treat the old aux elec fan as a primary cooling fan. Then it's just splice in the new fan and call it done. I'm just confused by if/what I need to change with the thermo switch (if at all?)
    You got it. The aux fan was for both. But when you have just an electric fan you want it to come on sooner. No cutting of anything except the actual fan power wires to connect them to the new fan. You can verify your thermoswitch is correct, it should have stamped on one of the hex flats "80/88". If you were really fancy you could get a 2 speed electric fan. I will try to look at a diagram tomorrow to see if the low speed relay turns off when the high comes on. If they are just both on in a high temp condition you would wire it to the low speed circuit. I just kept the oe aux fan on my e36 so it had low/high. But the e36 aux fan is way better than the e30 one.
    Sent from my potato phone
      You got it. The aux fan was for both. But when you have just an electric fan you want it to come on sooner. No cutting of anything except the actual fan power wires to connect them to the new fan. You can verify your thermoswitch is correct, it should have stamped on one of the hex flats "80/88". If you were really fancy you could get a 2 speed electric fan. I will try to look at a diagram tomorrow to see if the low speed relay turns off when the high comes on. If they are just both on in a high temp condition you would wire it to the low speed circuit. I just kept the oe aux fan on my e36 so it had low/high. But the e36 aux fan is way better than the e30 one.Sent from my potato phone
      Perfect - Thank You!!!!
      Took this afternoon off work to go home and hopefully get the car up and running. Looking good for having it running tonight as long as I don't hit any major hiccups. Keeping my fingers crossed!!!
        May the force be with you!
          Well.... Took a one hour break for dinner and some play time with the kids - other then I've been wrenching since noon.
          She's back on the ground, oil changed, coolant system burped and working, elec fan works, front lip is on.... Only thing left to do is get the hood on and drive it - neither of which I can do because I don't have a helper at 11pm and it's raining outside.
          So after work tomorrow will be its test drive... All I can do is cross my fingers and hope for the best.
            Test drive couldn't have gone better. Drivetrain vibration is gone, no squeals or noise from anywhere... Overall feels fantastic.
            No power steering under 5 mph kinda sucks, but if you're moving its totally fine.
              Great work Collin!
                Can't thank everyone enough for the help since I got this car. Some of you have had to endure painfully stupid questions via call and text - and for those people I'm eternally grateful. Earl, Brian, and Andy (and really everyone who's helped me with this) - I truly appreciate it.
                  Backed the E30 outta the driveway in Saturday, and noticed a nice drip line from under the car on the pavement. As I sat contemplating what it could be for a second - I slowly watched it evaporate.....
                  "Oh crap..."
                  Straight back into the garage.
                  Found the culprit - and got it replaced tonight:
                  Replaced the filter and both lines running to/from it. PO at some point apparently thought a kinked straight line would be fine.
                    Ordered all the parts last night to make a temporary intake for the M20 (so I can remove the AFM and stock air box - and have a good mount for an AIT).
                    Trying to win the "Biggest Goddamn Filter We've Ever Seen" Award at EuroWerks.
                        Noise makers have arrived.
                          Much filter. So wow.
                          It's just hilariously huge.... I can't help but laugh.
                            Is that to slip over the velocity stack?
                              Yup! Unfortunately, the velocity stack I got does not match the dimensions given on the website I bought it from (it's a 6.5" OD, should have been a 7" OD) so hoping they just sent me the wrong one.... But doubt it (They don't offer a 6.5").
                                Josh came over with his e30 vert - and we decided to take a quick drive and he snapped some pics... Here's what he got of mine:
                                  Hey I know that place... Great Pics
                                    It's about a mile from my house Chris.
                                      ClassE said:
                                      I had thought that I was the only one with the gap between the bumper and upper valance (under the headlights) that reduces near the kidneys.
                                      It appears that I am not!
                                        Looks amazing! Im appreciating the fact that there is more front camber than rear camber.
                                        The world needs fewer understeering pigdogs
                                        • JasonMasonJ
                                          JasonMasonJ
                                          JasonMason
                                          Well Collin I decided to read your build thread today and it made realize all the fun moments that have been had so far. With many more interesting fun times down the road.
                                          1988 325i vert
                                          2002 Jeep Grand Cherokee
