  4. problems with my 5-speed swap
13 Posts 5 Posters 142 Views 1 Watching
    Do you have the TOB in the fork the correct way? the fork shouldn't have much play
      What do you mean 'slave went out'? Did the push rod come out of the cylinder? Did the seal blow out?
      Do you have the right slave cylinder?
      Also, i belive the word you cant think of is 'and'.
      • brehmerB
        brehmerB
        brehmer
        The seal blew out.  And I  did double check  to make sure  I have the right  one.
        • brehmerB
          brehmerB
          brehmer
          I'll check  the TOB as soon as I get home
            What brand slaves are you buying?
            • brehmerB
              brehmerB
              brehmer
              Power torque  from O'Reillys
                Try a different brand. I've heard non-oem slaves are hit or miss
                  What a fantastic name
                  • brehmerB
                    brehmerB
                    brehmer
                    TOB is on correctly. Not sure what else to do so I ges  I'll just put it back together n try an oem  slave.
                    • brehmerB
                      brehmerB
                      brehmer
                      Thanks for all the suggestions
