<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problems with  my 5-speed swap]]></title><description><![CDATA[<p dir="auto">I just finished my swap n when I went to bleed my clutch n my slave went out. Got a new one n the same thing happened. After the third one went out I pulled the Trans out to make sure the fork was moving properly n the clutch disk wasn't backwards n everything was fine. I don't know what is wrong any one have any suggestions?</p>
]]></description><link>https://wibimmers.com/topic/3766/problems-with-my-5-speed-swap</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 07:25:08 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3766.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 May 2015 15:53:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to problems with  my 5-speed swap on Thu, 28 May 2015 04:15:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for all the suggestions</p>
]]></description><link>https://wibimmers.com/post/58433</link><guid isPermaLink="true">https://wibimmers.com/post/58433</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Thu, 28 May 2015 04:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Thu, 28 May 2015 04:14:21 GMT]]></title><description><![CDATA[<p dir="auto">TOB is on correctly. Not sure what else to do so I ges  I'll just put it back together n try an oem  slave.</p>
]]></description><link>https://wibimmers.com/post/58432</link><guid isPermaLink="true">https://wibimmers.com/post/58432</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Thu, 28 May 2015 04:14:21 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 21:18:56 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/58421">brehmer said:</a></strong></p>
<p dir="auto"><strong>Power torque</strong>  from O'Reillys</p>
<p dir="auto">What a fantastic name</p>
]]></description><link>https://wibimmers.com/post/58423</link><guid isPermaLink="true">https://wibimmers.com/post/58423</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 27 May 2015 21:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 20:46:22 GMT]]></title><description><![CDATA[<p dir="auto">Try a different brand. I've heard non-oem slaves are hit or miss</p>
]]></description><link>https://wibimmers.com/post/58422</link><guid isPermaLink="true">https://wibimmers.com/post/58422</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 27 May 2015 20:46:22 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 20:39:38 GMT]]></title><description><![CDATA[<p dir="auto">Power torque  from O'Reillys</p>
]]></description><link>https://wibimmers.com/post/58421</link><guid isPermaLink="true">https://wibimmers.com/post/58421</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Wed, 27 May 2015 20:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 20:19:23 GMT]]></title><description><![CDATA[<p dir="auto">What brand slaves are you buying?</p>
]]></description><link>https://wibimmers.com/post/58418</link><guid isPermaLink="true">https://wibimmers.com/post/58418</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 27 May 2015 20:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 19:21:11 GMT]]></title><description><![CDATA[<p dir="auto">I'll check  the TOB as soon as I get home</p>
]]></description><link>https://wibimmers.com/post/58414</link><guid isPermaLink="true">https://wibimmers.com/post/58414</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Wed, 27 May 2015 19:21:11 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 19:20:31 GMT]]></title><description><![CDATA[<p dir="auto">The seal blew out.  And I  did double check  to make sure  I have the right  one.</p>
]]></description><link>https://wibimmers.com/post/58413</link><guid isPermaLink="true">https://wibimmers.com/post/58413</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Wed, 27 May 2015 19:20:31 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 18:01:00 GMT]]></title><description><![CDATA[<p dir="auto">What do you mean 'slave went out'? Did the push rod come out of the cylinder? Did the seal blow out?</p>
<p dir="auto">Do you have the right slave cylinder?</p>
<p dir="auto">Also, i belive the word you cant think of is 'and'.</p>
]]></description><link>https://wibimmers.com/post/58402</link><guid isPermaLink="true">https://wibimmers.com/post/58402</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Wed, 27 May 2015 18:01:00 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 17:26:39 GMT]]></title><description><![CDATA[<p dir="auto">Do you have the TOB in the fork the correct way? the fork shouldn't have much play</p>
]]></description><link>https://wibimmers.com/post/58401</link><guid isPermaLink="true">https://wibimmers.com/post/58401</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 27 May 2015 17:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 16:31:13 GMT]]></title><description><![CDATA[<p dir="auto">Yes I am</p>
]]></description><link>https://wibimmers.com/post/58399</link><guid isPermaLink="true">https://wibimmers.com/post/58399</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Wed, 27 May 2015 16:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to problems with  my 5-speed swap on Wed, 27 May 2015 16:19:16 GMT]]></title><description><![CDATA[<p dir="auto">Are you bench bleeding the slaves before installing them?</p>
]]></description><link>https://wibimmers.com/post/58396</link><guid isPermaLink="true">https://wibimmers.com/post/58396</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 27 May 2015 16:19:16 GMT</pubDate></item></channel></rss>
