  4. e30 m50 swap problems
17 Posts 5 Posters 0 Views 1 Watching
  • SamHolzmannS
    SamHolzmannS
    SamHolzmann
    Bought a full swap e30 m50 swap to put in my 1984 318i. Went to start it but nothing but turning over. Fires on starting fluid. No injector pulse through. Fuel lines have been swapped around and I triple checked all my adaptor wiring. Any info will be much appreciated
    • SamHolzmannS
      SamHolzmannS
      SamHolzmann
      Also running fuel cell and external pump powered by a switch so none of the e30 body fuel pump wiring is being used
        do you have power to your main relays? Are they turning on when you turn the key on? there is 3 relays for the engine harness
          Make sure the ground coming off the injector/spark connector box is on the motor.
          Does your ICV hum with the key in the on position?
          • SamHolzmannS
            SamHolzmannS
            SamHolzmann
            No 100 percent about the relay power but will check tonight. I don't hear any humming from the ICV. My ground coming from the injector/spark box is connected to my ground stud on the car.
              If the ICV isn't humming you lack power to your engine harness. This is most likely the main relay not having power.
                For me, i found my problem similar to your by replacing my fusible link.
                Well not only that but turns out I needed an Ecu too but probably not you.
                The Ecu was simply not getting power, so nothing turned on.
                  That swap ran and drove without any issues when it was pulled so I would bet it is something ground related or not connected properly.
                    With the megasquirted m10 it was losing signal every revolution, which looked to be a trigger wheel issue but this "new" problem that exists with the ecu/fuel pump power wiring may be the same problem the car had with the previous setup.
                    • SamHolzmannS
                      SamHolzmannS
                      SamHolzmann
                      Still being stumped any chance someone who knows the wiring of an m50 swap could send me a full description of what needs to go where and to what? Would like to make it scooters this year. Thanks
                        It puzzles me that you say it fires on starting fluid. If it is sending signal for spark I don't know why it wouldn't send injector pulse as well.
                        That makes me think ground, double check your grounds, make sure they are clean. You should have one wire grounded at the passenger side strut tower and one on the frame horn near the PS motor mount arm.
                        • SamHolzmannS
                          SamHolzmannS
                          SamHolzmann
                          Took the injector wiring harness apart checked everything, using a noid light shows no injector pulse. Also came to the conclusion it's sending 12 volts to both positive and ground on every injector plug.
                            + on injector should have 12v any time the key is switched on, - on injector should not have continuity with ground except while firing the injector
                            Sounds like a power and ground are still mixed up
                              ^ This is a place to look
                              Does your ICV hum when they key is in the on position?
                                He said no the first time you asked lol
                                  Hey good call!
                                  I have been helping two people with non running m5x/s5x and am getting the two mixed up!
                                    ^Just like he mixed up the grounds here?  :shifty:
