<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e30 m50 swap problems]]></title><description><![CDATA[<p dir="auto">Bought a full swap e30 m50 swap to put in my 1984 318i. Went to start it but nothing but turning over. Fires on starting fluid. No injector pulse through. Fuel lines have been swapped around and I triple checked all my adaptor wiring. Any info will be much appreciated</p>
]]></description><link>https://wibimmers.com/topic/3758/e30-m50-swap-problems</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:43 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3758.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2015 19:32:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e30 m50 swap problems on Wed, 03 Jun 2015 13:31:43 GMT]]></title><description><![CDATA[<p dir="auto">^Just like he mixed up the grounds here?  <img src="/assets/uploads/files/emoticons_default_shifty.gif" alt=":shifty:" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/58656</link><guid isPermaLink="true">https://wibimmers.com/post/58656</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 03 Jun 2015 13:31:43 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Wed, 03 Jun 2015 12:13:16 GMT]]></title><description><![CDATA[<p dir="auto">Hey good call!<br />
I have been helping two people with non running m5x/s5x and am getting the two mixed up!</p>
]]></description><link>https://wibimmers.com/post/58650</link><guid isPermaLink="true">https://wibimmers.com/post/58650</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 03 Jun 2015 12:13:16 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Wed, 03 Jun 2015 07:42:33 GMT]]></title><description><![CDATA[<p dir="auto">He said no the first time you asked lol</p>
]]></description><link>https://wibimmers.com/post/58641</link><guid isPermaLink="true">https://wibimmers.com/post/58641</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 03 Jun 2015 07:42:33 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Wed, 03 Jun 2015 02:21:54 GMT]]></title><description><![CDATA[<p dir="auto">^ This is a place to look<br />
Does your ICV hum when they key is in the on position?</p>
]]></description><link>https://wibimmers.com/post/58630</link><guid isPermaLink="true">https://wibimmers.com/post/58630</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 03 Jun 2015 02:21:54 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Tue, 02 Jun 2015 23:06:21 GMT]]></title><description><![CDATA[<p dir="auto">+ on injector should have 12v any time the key is switched on, - on injector should not have continuity with ground except while firing the injector</p>
<p dir="auto">Sounds like a power and ground are still mixed up</p>
]]></description><link>https://wibimmers.com/post/58624</link><guid isPermaLink="true">https://wibimmers.com/post/58624</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 02 Jun 2015 23:06:21 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Tue, 02 Jun 2015 19:51:50 GMT]]></title><description><![CDATA[<p dir="auto">Took the injector wiring harness apart checked everything, using a noid light shows no injector pulse. Also came to the conclusion it's sending 12 volts to both positive and ground on every injector plug.</p>
]]></description><link>https://wibimmers.com/post/58616</link><guid isPermaLink="true">https://wibimmers.com/post/58616</guid><dc:creator><![CDATA[SamHolzmann]]></dc:creator><pubDate>Tue, 02 Jun 2015 19:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Tue, 02 Jun 2015 18:17:17 GMT]]></title><description><![CDATA[<p dir="auto">It puzzles me that you say it fires on starting fluid. If it is sending signal for spark I don't know why it wouldn't send injector pulse as well.<br />
That makes me think ground, double check your grounds, make sure they are clean. You should have one wire grounded at the passenger side strut tower and one on the frame horn near the PS motor mount arm.</p>
]]></description><link>https://wibimmers.com/post/58614</link><guid isPermaLink="true">https://wibimmers.com/post/58614</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Tue, 02 Jun 2015 18:17:17 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Tue, 02 Jun 2015 16:49:33 GMT]]></title><description><![CDATA[<p dir="auto">Still being stumped any chance someone who knows the wiring of an m50 swap could send me a full description of what needs to go where and to what? Would like to make it scooters this year. Thanks</p>
]]></description><link>https://wibimmers.com/post/58612</link><guid isPermaLink="true">https://wibimmers.com/post/58612</guid><dc:creator><![CDATA[SamHolzmann]]></dc:creator><pubDate>Tue, 02 Jun 2015 16:49:33 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Thu, 28 May 2015 16:57:51 GMT]]></title><description><![CDATA[<p dir="auto">With the megasquirted m10 it was losing signal every revolution, which looked to be a trigger wheel issue but this "new" problem that exists with the ecu/fuel pump power wiring may be the same problem the car had with the previous setup.</p>
]]></description><link>https://wibimmers.com/post/58440</link><guid isPermaLink="true">https://wibimmers.com/post/58440</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 28 May 2015 16:57:51 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Thu, 28 May 2015 13:15:28 GMT]]></title><description><![CDATA[<p dir="auto">That swap ran and drove without any issues when it was pulled so I would bet it is something ground related or not connected properly.</p>
]]></description><link>https://wibimmers.com/post/58435</link><guid isPermaLink="true">https://wibimmers.com/post/58435</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 28 May 2015 13:15:28 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Thu, 28 May 2015 11:03:15 GMT]]></title><description><![CDATA[<p dir="auto">For me, i found my problem similar to your by replacing my fusible link.</p>
<p dir="auto">Well not only that but turns out I needed an Ecu too but probably not you.</p>
<p dir="auto">The Ecu was simply not getting power, so nothing turned on.</p>
]]></description><link>https://wibimmers.com/post/58434</link><guid isPermaLink="true">https://wibimmers.com/post/58434</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 28 May 2015 11:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Wed, 27 May 2015 12:59:18 GMT]]></title><description><![CDATA[<p dir="auto">If the ICV isn't humming you lack power to your engine harness. This is most likely the main relay not having power.</p>
]]></description><link>https://wibimmers.com/post/58381</link><guid isPermaLink="true">https://wibimmers.com/post/58381</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 27 May 2015 12:59:18 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Wed, 27 May 2015 12:24:21 GMT]]></title><description><![CDATA[<p dir="auto">No 100 percent about the relay power but will check tonight. I don't hear any humming from the ICV. My ground coming from the injector/spark box is connected to my ground stud on the car.</p>
]]></description><link>https://wibimmers.com/post/58377</link><guid isPermaLink="true">https://wibimmers.com/post/58377</guid><dc:creator><![CDATA[SamHolzmann]]></dc:creator><pubDate>Wed, 27 May 2015 12:24:21 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Tue, 26 May 2015 19:39:36 GMT]]></title><description><![CDATA[<p dir="auto">Make sure the ground coming off the injector/spark connector box is on the motor. <br />
Does your ICV hum with the key in the on position?</p>
]]></description><link>https://wibimmers.com/post/58361</link><guid isPermaLink="true">https://wibimmers.com/post/58361</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Tue, 26 May 2015 19:39:36 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Tue, 26 May 2015 15:15:06 GMT]]></title><description><![CDATA[<p dir="auto">do you have power to your main relays? Are they turning on when you turn the key on? there is 3 relays for the engine harness</p>
]]></description><link>https://wibimmers.com/post/58353</link><guid isPermaLink="true">https://wibimmers.com/post/58353</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Tue, 26 May 2015 15:15:06 GMT</pubDate></item><item><title><![CDATA[Reply to e30 m50 swap problems on Fri, 22 May 2015 19:36:27 GMT]]></title><description><![CDATA[<p dir="auto">Also running fuel cell and external pump powered by a switch so none of the e30 body fuel pump wiring is being used</p>
]]></description><link>https://wibimmers.com/post/58317</link><guid isPermaLink="true">https://wibimmers.com/post/58317</guid><dc:creator><![CDATA[SamHolzmann]]></dc:creator><pubDate>Fri, 22 May 2015 19:36:27 GMT</pubDate></item></channel></rss>
