pistonse30
    I got 255s so I hope that helps :shifty:
      Something has to give...just hope it's the tires and nothing in the driveline!
        As long as you are not consistently launching, I wouldn't be 1 bit worried. Looks like you are more into roll racing anyways.
          That's what I like to hear! I know how flimsy that rear end is so I don't want to push it with burnouts and banging gears.
          • andyhundleyA
            andyhundleyA
            andyhundley
            If you want to do burnouts, buy a Camaro!
              So much rubber.
                Doorman
                DrLeadFoot said:
                So much rubber.
                Did I do it right?
                  The parts are slowing coming in!
                  90mm Studs
                  15MM Spacers
                    Doze nuts
                      This thread is getting NSFW super quick
                        Came across this today.
                        http://www.bimmerforums.com/forum/showthread.php?2165294-PNP-wiring-for-MS3x-to-OBD1-m50-Harness
                          What a great thread that is
                          See you saturday!
                            See you saturday!
                            Does that make perfect sense to you?? Wanna build it for me??? Haha
                            I won't be there.. getting married Friday then headed up to Kohler for a mini-moon!
                            Have fun!
                              Yeah I know, im tagging along on the mini-moon.
                              Looks easy, i think you could do it
                                I ran into a ton of issues by trying to follow DIY's , proceed with caution.
                                Also, the last part of that is overkill, there is no reason to go through all that trouble of making a little board like that, when you can just rock another relay that switches ground. Tis what I did.
                                  I was planning to just show up in Kohler. I thought driving with would have been intruding...
                                    She is going to be super excited when I give her the updated headcount!
                                      Test fitted the wheels with out the tires. The fronts look good. 17x9 et25 with a 15mm spacer making them et10. 245/40s should be okay.
                                      The rears are so tight but don't touch. 1mm of clearance from the trailing arm and spring perch. 17x10 et20. I hope the 255/40s stretch a bit on the 10in wheel.
                                      Urban Motorworx is mounting them and should be ready for pick up tomorrow morning.
                                      Hopefully concours can squeeze me in for an alignment tomorrow if all goes well with the fitment.
                                        How's your back spacing to coil body? I'm 16"x9" ET5 all around and have good clearance to the coil body - but zero clearance to the lower coil collar.
                                          Not sure yet. It all is pretty close. I have a skinny 2mm spacer somewhere that I might have to find.
