  4. e30 Alternator Ground Cable Location?
e30alternatorground
12 Posts 7 Posters 160 Views 1 Watching
    There is no alternator ground, unless yours is on rubber mounts but I don't believe any 6 cyl. has that.
    Check your engine ground on the pass/drivers side frame rail.
      That's usually the sole ground on BMW motors isn't it?
      • JeffJ
        JeffJ
        Jeff
        I have yet to see one grounded by a wire. They ground through the block.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          I think some are rubber mounted and have a short braided strap, I can't remember where it goes to though.
            Everyone is spot on. If you choose to add the strap anyways, which some people recommend, the engine to body spot is a good one.
            I've had radio whine in every e30 with aftermarket radio that I've had so hopefully you can get rid of it.
            • jayinmadisonJ
              jayinmadisonJ
              jayinmadison
              Thanks guys. This didn't resolve the radio whine. Does anyone have any tips to resolve that issue? Also right now only my rear left speaker puts out audio. The rest just good 'ol whine!
                OE head unit?
                Sent from my potato phone
                  Check the common grounds for the stereo wiring.
                    there are some suggestions I've heard. i didn't bother to do anything, because i could only hear the whine if the radio volume was quiet and the car was not moving.
                    1)separate left/right channel wires from large power wires in stock wiring
                    2)completely new wiring with RCA cables, aftermarket amp, etc.
                    3)noise suppressors?
                    4)ground the radio to the same ground as the alternator
                    5)new radio ground on sheet metal as close to radio as possible
                    • jayinmadisonJ
                      jayinmadisonJ
                      jayinmadison
                      Thanks guys. Stock radio. It has 10 disc cd changer in the trunk. (Rad, I know lol). Is the Radio's ground wire near the deck or antenna?
                        I don't know exactly, but finding the diagrams in the etm would help you here. My guess is the stock radio harness probably grounds to a bracket or body in the drivers footwell. If you take out your radio and kick panel you should be able to follow the harness.
