Chapter GMW | E30 LS1 (starting on post #1427)
Isn't your bottom end fully built? Why not more power?
Not that those numbers aren't impressive lol
Might have something to do with the tune.
I'm pretty happy with the 500wtq! That number didn't even cross my mind for the torque.
Here are some pics of the eventful weekend. Dyno day and Chicago E30 Meet.
SO Minty!
Right hand drive 320i Touring!
320i motor.
s52 swap on the red one and an m54 swap on the M-tech 2 vert. Both very clean swaps.
Back in MKE. No problems all weekend except for my tune which needs tweaking.
Dyno run youtube video.
https://www.youtube.com/watch?v=VGWG9hdezJo
The zf320 has the 1:1 ratio in 5th gear so this was my car at 165mph!! It was deafening.
While they were programing the Dyno Jet the only option that the computer had was a 2.93 diff setting. I'm running a 2.79. Would this change my numbers?
Dyno run youtube video.https://www.youtube.com/watch?v=VGWG9hdezJo
Yes, with the 2.79 calculated in, your numbers would be 496hp and 526ftlb. Did they enter the correct tire diameter?
I think they did. I wasn't over their shoulder the whole time.
I like those numbers a little better!!!!
Was facebook messaging with a guy from Door County yesterday. He has 2 e30 M3 and a S52 swapped e30!! The m3's have CF intakes, ported heads and cams.
I have 5 words to contribute to this.
"better than a haunted house."
Send him to wibim's
We will welcome him with arms wide open and creed rock ballads
Send him to wibim's We will welcome him with arms wide open and creed rock ballads
Unless he says something stupid... then we will ostracize him.
Apparently the speed sensor is required to operate the ECU.
I also need a cam sensor.
I'm in the middle of totally redoing my bathroom, wrapping up wedding planning and trying to work in between all of this. Hectic but I love it!
Cam sensor replaced and confirmed that the code stayed off.
We are all good except the speed sensor issue. I'll fix that when I replace the differential.
I've been driving the car a lot!
To do list:
- Empty catch can.
- Pop the new diff in and speed sensor.
- Order new wheels and tires.
- Get an alignment.
- Clean wide band O2 sensor or order a new one if cleaning it doesn't work.
- Put the hood back on.
What wheels and tires?
Nothing too crazy.
These for the front with a 10/15mm spacer running 245s
http://www.nlmotoring.com/XXR-531-Wheels-17x9-Platinum-p/53179080.htm
For the rear running 265s
http://www.nlmotoring.com/XXR-531-Wheels-17x10-Hyper-Silver-p/53170083.htm
I'm debating on the platinum (link for the front) or the hyper silver (link for the rears). What do you guys think?
