534 Posts 40 Posters 0 Views 1 Watching
    So I have been trying to find a complete set of boots for these axles and I can only find the inners.
    This is what I was looking at:  http://www.ebay.com/itm/231058828736?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    I know the Meyle ones are nice, but I cant find the other ends. Anyone have any pointers?
    On a side note, I took my buddies drift car to work the other day and it developed a slight vibration. upon return to my shop, I found the culprit.......
    Also, 18's on an E30?   :o :PUKE:
      Depending on offsets and tire size, 18's in back almost look "presentable"... Everytime someone posts pics of 18's on E30's tho, it's always the rear..... Because 18's in front looks like utter and complete rubbish.
        Double stagger might be possible, but why.
          http://www.realoem.com/bmw/showparts.do?model=BB13&mospid=47326&btnr=33_0470&hg=33&fg=25
          Item 5 is the inner, 6 is the outer.  Pelican has a full kit with all 4 boots, the bolts, grease etc for $115.50
            Awesome!!! thank you so much. Placing my order today!
              So it been awhile since I updated, So here are some pics of my latest struggles and successes with my E30 . It seemed like the more I started to take things apart, the more I found things that needed to be fixed. Typical money pit as expected.
              So I can start here, I removed the old subframe bushings with a two jaw press. It was a little annoying but it worked pretty good.
              Once that was done, I got out the wire wheel and sandpaper, and took the pleasure of grinding and sanding all that nasty ruberized coating off of the subframe to prep it for paint. I had a good friend of mine machine some camber plates(which look amazing) and I planned on welding those on. But due to the deadline of Sowo closing in, I decided that they will have to wait until I get back to be installed.
              This is what the kit basically looks like.
              So skipping that, which im not to thrilled about, I Painted my Subframe. Needless to say I am stoked how it turned out. Its a shame I will need to grind it down again to weld on the camber plates.
              Here's a close up. I used this metallic spray after a nice coat of black, and it really gave it some POP!
              Also prior to tackling my rear subframe, I installed new wheel bearings up front, only to realize that my balljoints were starting to get really weak. So I took everything apart, cleaned and painted everything. I  ordered new control arms, sway bar endlinks, and sway bar bushings for the front end.
                Coming together awesome=)
                  After sorting out what needed to be ordered for the front end, I crawled under the car to take a closer look at my drive shaft. I had a slight vibration at higher speeds and I think I found the culprit. Transmission mounts were garbage. I jacked the motor up and the mounts were completely in half. It made me think back to the year prior, when I replaced my motor mounts that were the exact same way, yet I never checked the trans mounts.  :eek: Meaning for who knows how long, I was just driving around with my motor resting on top of the mount locations. Pretty neat. LOL
                  (P.S. Dont mind the nastiness. The leak has since been fixed and I haven't take the time to rack the car and Pressure wash the underside)
                  Needless to say I think I found everything that I needed to replace suspension wise. So I got out my check book and ordered the following:
                  X_Axle boot kit
                  X_Rear trailing/control arm bushings
                  X_drive shaft flex disc
                  X_drive shaft mount bearing
                  X_rear axlenut locking plates x2
                  X_Sway bar endlinks front and rear
                  X_Lemforder Control arms and ball joints
                  X_Front control arm bushings
                  X_Stainless braided brake lines
                  X_rear Wheel bearings
                  X_countless misc hardware
                  X_and the Obvious Trans mounts
                  But then I didnt stop there. I also had a lead on the first step to the new motor swap I am going to pursue next winter...
                    The majority of the new parts came. I clear coated all the metal pieces to prevent rust and oxidation
                    and painted the control arms to match the subframe.
                    I also made a stop out to a friends shop to lend him a hand on an E92 he was welding a cage in.
                    Needless to say he was making great progress before I even go there and it fit in the car flawlessly.
                    There was also another BMW nearby...
                    I will be pressing the rear hubs out tonight and painting the swing arms as well. I will take more pics as I move along. I want to drive this thing again!!! Urggghh
                      Pretty sure that's the ESS supercharged M3 I got to drive at Concours. Can't be too many around right?
                      Paint looks great!
                        Great work!
                        More pics of the tools and how you pull the bearings please!
                          You missed the engine bay pic of that second bmw!!!
                          But hey this is exciting
                          Also. Is that an r154? DId you give up on the adapter? I'm very much so thinking my next swap will be 4g63 into an e30 for a daily.
                            DrLeadFoot said:
                            Great work! More pics of the tools and how you pull the bearings please!
                            I will for sure. I was unable to find time last night, so I will be doing it today.
                            Paint looks great!
                            I assume so. It hardly has over 10k on the clock.
                            Thanks Earl!
                              Ahhhh, I was waiting for someone to ask what trans that was.. ;) and no, I did not give up on the adapter, but the price was right so I had to!  BTW you didn't miss much, that E30 was just a stock M20.
                                Are you going to at least tell me what trans? Ha.
                                  Rowleym said:
                                  Are you going to at least tell me what trans? Ha. Sent from my iPhone using Tapatalk
                                  Only if you can guess what it is. You were close though lol.
                                  • C
                                    C
                                    cpandrewschmidt
                                    What sideskirts are you rockin'?
                                      Genuine Rieger side skirts sir. I plan on getting the Reiger Infinity front lip to match soon too, but I just want to get the moving bits all squared away first.
                                        More updates. Since I had the back seat out to remove the subframe, I took my seat to a local friend of a friend that does interior upholstery to have the top of the seat restitched. The plastic rear window amplifies the sun and bakes the top of almost all the vert rear seats. My seat was extremely dry and fragile when I got the car, and after the first year of owning it and packing people into the back, the stitching gave away. I have since added lots and lots of leather replenishing chemicals and the leather has bounced back quite well, so I finally got it fixed. I unfortunately did not take any before pictures of the seat, but here is what it looks like now that I got it back(I have since cleaned and replenished the leather).
                                        Focusing back on the suspension, I go the new control arms installed, along with the new sway bar links and brackets, the calipers I rebuilt, and I installed the new lines. it all came together very nice and I am getting excited to drive this thing more and more each day.
                                        New sway bar links
                                        Old brake line
                                        New VS. Old brake lines side by side
                                        Everything installed and back together minus the wheels
                                        I also rebuilt the calipers, but due to having brake fluid all over, I didn't take any pictures.
                                          Heres one more for good measure
