    Just finished cutting the o-ring grooves in the block with the isky groove-o-matic rental tool.
    927670dd915934a999507b147e195eb2.jpg1ea8fe852f00babf90fedb95f2fe3b8c.jpgb8affc5dfa034b10227b1936e1abf413.jpg
      Purdy nice!
        This will be a beautiful engine
          Sweet!!
            Groove-o-matic?! Funky!
              Pretty bird! Pretty bird!
              Is it gold or cast iron? The world may never know.
                Ordered some misc parts and everything to refresh the shifter. Installed the last of the head seals/gaskets. Also installed the oil baffle plate and started drilling the hole in the pan for turbo oil drain fitting.
                  Drill the block! lots of meat and its already out of the car. Works really nice. Unless you have a tig welder?
                    Too late. Already drilled the hole in pan and secured the thru-wall sealing fitting. :P Got the wire in the o-ring grooves, which turned out to be pretty tedious getting the wire ends filed down and touching.
                    Installed the first oil pan gasket with crank scraper as well as oil pump.
                    Finished up with the second gasket and the pan. What a huge PITA to install the pan bolts with two gaskets, crank scraper and pan to line up!
                    Time to take the triumph out for its first ride of the season before the Wisconsin game!
                      Got the ARP head studs installed in the block with head gasket placed.
                      Torqued the cam sprocket, set head and block to TDC and installed head on block. Torqued to spec.
                        $$$$ looking good!
                          YES!
                            Didnt get as much done last night as I wanted to, but I did get the water pump and timing belt on and tensioned. I also ordered a few more parts and pieces that will hopefully be here by the weekend.
                              Didn't opt for the gates Kevlar racing belt?
                                Nah. Thought about it, but OEM is good enough for me.
                                Tonight I got the valves adjusted, intake manifold installed, valve cover installed and got the exhaust manifold fitted
                                8edd3693973257c5828d8d6e46513244.jpgbd19f05586e9a3cc84e03def83f23d2c.jpg000bde9e96062f21d3b58ded98b9ded8.jpg
                                  Getting closer .... Timing covers on, water pump pulley, alternator bracket and distributor cap/rotor installed, exhaust manifold secured and turbina installed.
                                    Sweet!
                                    How much red loc-tite did you use on that Hey-zeus bolt?
                                    I tired to find an image of a brat being dunked in some Secret Stadium Sauce but I had to close that tab..  Almost shorted out my keyboard...
                                      Now to get the rest of the car looking that good=P
                                      I cannot wait to see this thing ripping
                                        Thanks guys! Yeah I used a good amount on that crank bolt sucker. Hopefully won't be a problem.
                                          Cut new grooves into the new injectors and got them on the rail.
                                          Remember kids, dont throw off the emperors groove ...
