m52 in a e30
I make the brace required to adjust for the rotation of the transmission
Maybe somebody would know this but other than a custom brace for the rear what about fitting a g260 into an e36 behind the m50? I wonder what drive shaft length would fit or if it would have to be custom made. The overdrive would be awesome and my g250 makes odd whirling noises on hard deceleration in second gear, similar to the noise Curly from the 3 stooges makes referred to as "whoop whoop whoop" at around 3-5 seconds.
Stock driveshaft wouldn't work. You would need to use an e30 driveshaft actually. If your diff has the six bolt flange you have no options other than another e36 trans.
