<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m52 in a e30]]></title><description><![CDATA[<p dir="auto">Does anyone know if the stock trans in a 90 325is will bolt up to a m52?</p>
]]></description><link>https://wibimmers.com/topic/3606/m52-in-a-e30</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:41:55 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/3606.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Mar 2015 22:42:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m52 in a e30 on Wed, 18 Mar 2015 22:44:34 GMT]]></title><description><![CDATA[<p dir="auto">420g is heavy and expensive.  ZF still has no overdrive.</p>
]]></description><link>https://wibimmers.com/post/55957</link><guid isPermaLink="true">https://wibimmers.com/post/55957</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 18 Mar 2015 22:44:34 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Wed, 18 Mar 2015 22:03:29 GMT]]></title><description><![CDATA[<p dir="auto">You're crazy why no 420g or zf? Don't go to an older trans!</p>
]]></description><link>https://wibimmers.com/post/55951</link><guid isPermaLink="true">https://wibimmers.com/post/55951</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Wed, 18 Mar 2015 22:03:29 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 18:45:53 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, that would be easy if all I need is the drive shaft, my dif is a 4 bolt input as is the 3.23 LSD I just got.  I will look into this.  Not much comes up when searching, better mpg highway cruising would be awesome.</p>
]]></description><link>https://wibimmers.com/post/55890</link><guid isPermaLink="true">https://wibimmers.com/post/55890</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 17 Mar 2015 18:45:53 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 18:33:00 GMT]]></title><description><![CDATA[<p dir="auto">Stock driveshaft wouldn't work. You would need to use an e30 driveshaft actually. If your diff has the six bolt flange you have no options other than another e36 trans.</p>
]]></description><link>https://wibimmers.com/post/55889</link><guid isPermaLink="true">https://wibimmers.com/post/55889</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Tue, 17 Mar 2015 18:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 18:28:50 GMT]]></title><description><![CDATA[<p dir="auto">Maybe somebody would know this but other than a custom brace for the rear what about fitting a g260 into an e36 behind the m50?  I wonder what drive shaft length would fit or if it would have to be custom made.  The overdrive would be awesome and my g250 makes odd whirling noises on hard deceleration in second gear, similar to the noise Curly from the 3 stooges makes referred to as "whoop whoop whoop" at around 3-5 seconds.</p>
<p dir="auto"><a href="https://youtu.be/g5j8Jioan1w" rel="nofollow ugc">https://youtu.be/g5j8Jioan1w</a></p>
]]></description><link>https://wibimmers.com/post/55887</link><guid isPermaLink="true">https://wibimmers.com/post/55887</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 17 Mar 2015 18:28:50 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 18:27:52 GMT]]></title><description><![CDATA[<p dir="auto">Keep the obd2 as well!</p>
<p dir="auto">Oh and you will have to bend your selector rod about 10*</p>
]]></description><link>https://wibimmers.com/post/55886</link><guid isPermaLink="true">https://wibimmers.com/post/55886</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Tue, 17 Mar 2015 18:27:52 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 18:27:24 GMT]]></title><description><![CDATA[<p dir="auto">Is it bad of me to sell your brace, brand new, but for slightly less? I mean, I own one and I don't need it, but I feel like I'm stealing a sale from you?</p>
]]></description><link>https://wibimmers.com/post/55884</link><guid isPermaLink="true">https://wibimmers.com/post/55884</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Tue, 17 Mar 2015 18:27:24 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 14:12:54 GMT]]></title><description><![CDATA[<p dir="auto">I make the brace required to adjust for the rotation of the transmission</p>
]]></description><link>https://wibimmers.com/post/55862</link><guid isPermaLink="true">https://wibimmers.com/post/55862</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Tue, 17 Mar 2015 14:12:54 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 02:29:35 GMT]]></title><description><![CDATA[<p dir="auto">Awesome thanks for the info!</p>
]]></description><link>https://wibimmers.com/post/55850</link><guid isPermaLink="true">https://wibimmers.com/post/55850</guid><dc:creator><![CDATA[brehmer]]></dc:creator><pubDate>Tue, 17 Mar 2015 02:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Tue, 17 Mar 2015 01:27:44 GMT]]></title><description><![CDATA[<p dir="auto">The M50/52 block is based off the M20 so they are basically the same size disregarding different accessories.</p>
]]></description><link>https://wibimmers.com/post/55842</link><guid isPermaLink="true">https://wibimmers.com/post/55842</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 17 Mar 2015 01:27:44 GMT</pubDate></item><item><title><![CDATA[Reply to m52 in a e30 on Mon, 16 Mar 2015 23:55:35 GMT]]></title><description><![CDATA[<p dir="auto">I assume you are speaking of the manual, yes it will.  The e30 5speed that was used with the 6cyl engine is the Getrag g260.  The advantage it has is a nice overdrive for lower RPM highway cruising.  All of the e36 manuals had no overdrive.</p>
]]></description><link>https://wibimmers.com/post/55833</link><guid isPermaLink="true">https://wibimmers.com/post/55833</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 16 Mar 2015 23:55:35 GMT</pubDate></item></channel></rss>
