  3. Services Offered/Wanted
  4. Needs head gaskets done. any takers?
15 Posts 5 Posters 0 Views 1 Watching
  • jockhater2J
    jockhater2J
    jockhater2
    looking to have my head gaskets done on my M10 motor along with other work.
    -distributor cap, spark plugs, wires, alternator voltage regulator,
    -head gasket, water pump gasket (water pump is already new), timing chain, timing guides, valve adjustment
    - any other bmw maintenance/head job maintenance
    -shifter/transmission mount bushings )whatever the vibration is at high rpms coming from shifter)
    -Fix broken driver door hinge
    I already asked Jake at rawsome but he is booked and I already only got to drive the car for 2 months last year.
    just PM if your interested and we'll go from there.
    the car can either be worked on at my place or I can tow it to your place.
    • T
      T
      tsweers89
      What were you quoted for all this? Just wondering if we are even in the same ballpark
      • jockhater2J
        jockhater2J
        jockhater2
        I can check with jake(rawsomotion) and see what all data says for time. but $50 an hour is what I was expecting.
        • T
          T
          tsweers89
          Ah I see, we are at $85 an hour. Good luck in your search.
          • jockhater2J
            jockhater2J
            jockhater2
            rawsomotion is $50 an hour for cash. I'd pay $85 if thats flat rate and under 10 hours of labor. where are ypu located?
            • T
              T
              tsweers89
              I'd have to look up labor but I assume its more than 10 hours with everything you need done. Call another shop and get a quote. I assume they won't even do it over the phone and would need to see the car in person.
              • jockhater2J
                jockhater2J
                jockhater2
                a shop quoted me $2000-3000. at that point I will just wait until jake is free'd up and have him do it. I know his labor for 15 hours would be $750.
                • jockhater2J
                  jockhater2J
                  jockhater2
                  My bad. Jake is $65-70 an hour. so around $1000 for 15 hours of labor. can a
                  nyone match that?
                    That's still not bad. In all honesty you can probably tackle this as even the gasket on my m42 was very simple.
                    • jockhater2J
                      jockhater2J
                      jockhater2
                      i know I could do it. this cars head gasket would be easier than my jetta's. which i did. but i just don't want to.
                        Speaking of Jake, I just took a look at his site and Rawsomotion is closing up shop in Germantown and he's joining up with Endless Autosport in West Allis. Good to see he's staying in the mix.
                        https://www.facebook.com/Rawsomotion
                        • jockhater2J
                          jockhater2J
                          jockhater2
                          jake said $1040 for 16 hours of labor.
                          he thinks this job should be 4-8 hours
                          i'm just going to have the head gaskets done, the cap, plugs and wires and water pump gasket.
                            Not a huge fan of the Rawsomotion guy, he sold me a diff, I asked if it leaked from the input seal. He said no, and that it leaked a bit from the rear cover.
                            I put it in my car, and it leaked about 3 tablespoons every time I drove it. From the input seal. Not too thrilled lol.
                            Sorry for thread crapping, but I just thought of that.
                            • T
                              T
                              tsweers89
                              Considering he is closing up shop and I assume just getting hired by Endless it looks like he wasn't doing that great to keep the doors open
                              • jockhater2J
                                jockhater2J
                                jockhater2
                                no one?
