When I took mine out I didn't take out those studs. I jumped on the trailing arms to break it loose. On mine the aluminum part for the stock mount corroded and was stuck to the body.
What happened to said diff?
Mine snapped off the top of the aluminum bushing and left it in the car. Had to drill and hammer it out.
Well I got it out. Used a 3 foot rod and a 5/8ths lag bolt. I had to bend the rod to get it in there, but after a few quick smacks, the casting snapped right where I drilled the holes.
And after I got it out, I still had the other half of the casting stuck in the car. So I just repeated the process. Thread in lag bolt, insert rod from the top, HAMMER TIME.
Out it came.
The electric impact I use is so helpful. The torque of the electric motor really helped drive that lag bolt into the aluminum.
Next I just need to toss all the hardware in the tumbler, replace all the bushings, and clean everything up and paint it! :sigh:
old diff is for sale BTW.. http://www.wibimmers.com/board/index.php?/topic/3579-e30-373-open-differential-for-sale/
here you can see how dried out the swing arm bushings are
This sucks too, the axle boots are cracked and about to tear from just looking at them. Anyone have suggestions on new axles? (Brand, where to buy, HP amount etc?) I figure I will need better ones once I swap the car anyways.
Just replace the boots and repack the cv joints with grease. There is no need to replace the whole thing. Sent from my potato phone
I might go that route for now to save some cash. I wont be seeing big HP numbers till next year anyways. I have seen a few guys that run stock M coupe Axles and they are pushing 600+.
So I have been trying to find a complete set of boots for these axles and I can only find the inners.
This is what I was looking at: http://www.ebay.com/itm/231058828736?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I know the Meyle ones are nice, but I cant find the other ends. Anyone have any pointers?
On a side note, I took my buddies drift car to work the other day and it developed a slight vibration. upon return to my shop, I found the culprit.......
Also, 18's on an E30?
:PUKE: -
Depending on offsets and tire size, 18's in back almost look "presentable"... Everytime someone posts pics of 18's on E30's tho, it's always the rear..... Because 18's in front looks like utter and complete rubbish.
Double stagger might be possible, but why.
http://www.realoem.com/bmw/showparts.do?model=BB13&mospid=47326&btnr=33_0470&hg=33&fg=25
Item 5 is the inner, 6 is the outer. Pelican has a full kit with all 4 boots, the bolts, grease etc for $115.50
Awesome!!! thank you so much. Placing my order today!
So it been awhile since I updated, So here are some pics of my latest struggles and successes with my E30 . It seemed like the more I started to take things apart, the more I found things that needed to be fixed. Typical money pit as expected.
So I can start here, I removed the old subframe bushings with a two jaw press. It was a little annoying but it worked pretty good.
Once that was done, I got out the wire wheel and sandpaper, and took the pleasure of grinding and sanding all that nasty ruberized coating off of the subframe to prep it for paint. I had a good friend of mine machine some camber plates(which look amazing) and I planned on welding those on. But due to the deadline of Sowo closing in, I decided that they will have to wait until I get back to be installed.
This is what the kit basically looks like.
So skipping that, which im not to thrilled about, I Painted my Subframe. Needless to say I am stoked how it turned out. Its a shame I will need to grind it down again to weld on the camber plates.
Here's a close up. I used this metallic spray after a nice coat of black, and it really gave it some POP!
Also prior to tackling my rear subframe, I installed new wheel bearings up front, only to realize that my balljoints were starting to get really weak. So I took everything apart, cleaned and painted everything. I ordered new control arms, sway bar endlinks, and sway bar bushings for the front end.
After sorting out what needed to be ordered for the front end, I crawled under the car to take a closer look at my drive shaft. I had a slight vibration at higher speeds and I think I found the culprit. Transmission mounts were garbage. I jacked the motor up and the mounts were completely in half. It made me think back to the year prior, when I replaced my motor mounts that were the exact same way, yet I never checked the trans mounts.
Meaning for who knows how long, I was just driving around with my motor resting on top of the mount locations. Pretty neat. LOL(P.S. Dont mind the nastiness. The leak has since been fixed and I haven't take the time to rack the car and Pressure wash the underside)
Needless to say I think I found everything that I needed to replace suspension wise. So I got out my check book and ordered the following:
X_Axle boot kit
X_Rear trailing/control arm bushings
X_drive shaft flex disc
X_drive shaft mount bearing
X_rear axlenut locking plates x2
X_Sway bar endlinks front and rear
X_Lemforder Control arms and ball joints
X_Front control arm bushings
X_Stainless braided brake lines
X_rear Wheel bearings
X_countless misc hardware
X_and the Obvious Trans mounts
But then I didnt stop there. I also had a lead on the first step to the new motor swap I am going to pursue next winter...
