  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Nice card trick! :P
      f6f27fda30a371e5beb3f06fcef05c80.jpg8b556baf338ebbb62fe3d67abdf7e223.jpg86d8e13dbe3e4afe9940817cfcabb6fc.jpg
      Almost done. The fiancée isn't too happy about the paint fumes that are in the entire house now but at least they're painted! :mellow:
        DrLeadFoot said:
        Had to... the field paint wasn't too professional. Anyone know what style these rims are? I really like them.
        Not arguing against it, I know how crazy they were in person haha. Style 18's I believe.
          17c5fc716ebaa43ae065af5888b7b64c.jpg6ef663ed2fba02064b963a78fb253edd.jpg9de5dc7206d93a5e5aa7d4f57be78da3.jpg
          Finally done. Passenger rear is slightly rubbing. I'll let itself do the adjustments.
            404 ERROR
            Fatlace/illest sticker not found
              404 ERROR
              Haha.
                Now time to test out these snow tires!
                  For reference:
                  http://www.bimmerforums.com/forum/showthread.php?245961-Steering-wheel-squeak-FIXED-Writeup-w-pics
                  http://www.bimmerfest.com/forums/showthread.php?t=494644
                    Can you guys help me shead some light on the M3's cylinders misfires?
                    5047372ea2a34408c164184c7bfe9618.jpg23f7fdcbd2573f0a76df6c020bd54769.jpg5de68ddd4c2bc5c9b2bfc235e8ae296e.jpg
                    • T
                      T
                      tsweers89
                      Well smotth running values def indicates cylinders 1 and 2 misfiring at that time. BUt your fault codes show more, and a low fuel level fault also. When does the misfire occur? Id be inclined to either investigate cylinders 1 and 2 or clear all faults, make sure you have more then a 1/4 tank of gas and see what faults return. coils. plugs, injectors could all cause this.
                        Plugs and coils have been replaced recently. Usually #6 always throws a code. The tank was full.
                          I cant believe all the crap you can read off newer control modules.
                          That would drive the OCD crazy with all the faults that come up
                            I cant believe all the crap you can read off newer control modules. That would drive the OCD crazy with all the faults that come up
                            You have no idea, I bought the scanner that can tap into every module in my e46. It is ridiculous what it will record, "low voltage passenger side mirror" for example. It was a shadow code so it wasn't actively happening. If you unplug anything it will remember.
                            Gets crazy, and that's on a 2000, imagine what the 2014 cars are like.
                              No thanks O__O
                              • T
                                T
                                tsweers89
                                Clear it, see what happens. Next time it comes on please get a real scanner and print codes. aka gt1 or isid. I mean how easy would it be to have burger run faults for you quick. Also do you have any tuning software on it or stock?
                                  I printed the codes from an autologic(?) Scanner. It comes on right after start up after clearing. I have frank smith software.
                                  • T
                                    T
                                    tsweers89
                                    Ok so its a present fault. Do all the misfire faults come back? cylinder 1 and 2 could be the culprit and causing the rest to store faults also. What if you remove the software and clear? Easiest thing would be to swap coils and plugs with differenct cylinders just to make sure its not either of them. I know you stated they were new but still. Next would be fuel injectors.
                                      Recently replaced does not mean good. Don't rule something out because its new.
                                      Sent from my potato phone
                                        Okay, got a lot fixed.
                                        - The EGT sensor wire had sheared off and replaced with a new one.
                                        - One O2 sensor was replaced.
                                        - The #6 injector was leaking and was replaced.
                                        - Valve job was due so got it done but everything wasn't too out of wack.
                                        - Hood latch sensor was replaced.
                                        - An exhaust stud on the #5 cylinder was missing. Got a new one in there.
                                        - A new belt, tensioner and idlers were all replaced.
                                        - Rear trunk latch was replaced.
                                        The cherry on top was the previous shop that installed the headers, after extremely scratching off the ceramic coating, more than likely removed the passenger side engine mount to provide room. Well, while Urban MotorworX was re-installing the missing exhaust stud he noticed the engine mount didn't have any bolts. After further inspection only one bolt was still on holding the broken piece of the engine mount to the block. THE WHOLE ENGINE WAS RESTING ON THE STEERING RACK! That would explain the weird vibrations I've been dealing with. This is also why the EGT sensor was sheared off. Matt installed two bolts to bandaid the problem for the time being. Tuesday the new arm will be here. Not sure if the previous shop over torqued the bolts and with my hard driving they came loose or if they were tight in the first place *cough, exhaust stud, cough*. After thousands and thousands of dollars spent on fixing issues of incompetent mechanics at this shop my word of advise to the community is please steer clear.
                                        The car is running amazing at the moment. I am getting a too lean code from bank one and two but I think that might be the tuning that needs to be tweaked.
                                          Interesting, this is why I do everything myself, I just don't trust anyone else to do it how I would. The only thing I can't do is mount tires and do an alignment, my neighbor works at a shop and I get those things done by him.
