  3. Cars For Sale & Wanted
    oh man, I don't know how yall missed this one. DAMN!
    http://milwaukee.craigslist.org/cto/4842753510.html
      CYoung said:
      MilwaukeeAndy?
      Well I guess that mystery is solved.
      I'm "special"
        http://appleton.craigslist.org/cto/4844679100.html  clean Alpine E30 Vert again! Anyone here?
          m42b18 said:
          http://chicago.craigslist.org/wcl/pts/4837783972.html
          Not a whole car but if I remember correctly an e30 hardtop is super rare
          This is a good deal, and yeah they are rare if they have the head liner and all the brackets. I WANT THIS.
            http://miami.craigslist.org/pbc/cto/4844309627.html
            Idiots will be idiots. Apparently a guy on BF told him its not an e21 and that it is indeed an e30. Guy insists this is an e21. So much that he offered it to the BF guy for $1k if he's wrong. Wow!!
              Link to said thread. I foresee many lulz and much butthurt
                http://www.bimmerforums.com/forum/showthread.php?2153784-what-s-wrong-with-this
                  Leaving at 6 to check this beast out.  I will bring my dealer reset tool ;)
                  http://lacrosse.craigslist.org/cto/4794383332.html
                    You suck=P
                      http://bringatrailer.com/2015/01/20/golf-yellow-flared-1972-bmw-3-0-csl/     Not a C-list car, but hawt damn  :wub:
                        It was garbage.  He would let it go for 300 but I think the ECU is fried, he wasn't telling the whole story about what happened, claims he replaced the battery and it wouldn't start right away.  It cranks strong but no spark and no fuel pump, not even the 5 second prime when the key is turned to run.  Would hooking up battery backwards fry it?  Not sure but the fuel pump works fine when the relay is jumpered.  I did not test jumpering the engine control module relay, it is also controlled by the ECU.  I am not sure the sequence of operation as to when that should close.  Unless the problem is that relay I would deduce that the ECU is no good.
                        Overall the car was maybe a 2/10.  Rockers made of spray foam and bondo, floor peeling away the seam to the rocker.  Bald tires, rip in driver seat, etc.  Not worth 300 even.
                          Found my rear brake upgrade and LSD.  He wants 600 for the whole rear setup, seems a little high to me, thoughts?  Supposedly only had 86k.  From a 99 m3 vert.
                          http://dubuque.craigslist.org/pts/4838678123.html
                            Thanks for posting about this one. I came across it while searching for M42s. Don't know anything about the anti-theft systems, but I figured it would be easy to reset. If it was a runner I would be interested in it for the motor. I don't have any way of moving non-running cars 😕
                              I would pass even on it even for the engine, it did not look well taken care of.  Electrical tape on the spark plug wires, very dirty, and inside the valve cover looked like oil changes were not a priority.
                              The "anti theft" is just a relay above the drivers left knee, pull the relay and put a jumper in to bypass.  Pretty high tech.
                                Hooking a battery up backwards can short an ECU for sure.
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Clean looking E30 325ix
                                  another one
                                  I don't remember ever seeing this E30 before...?
                                  That was mine I posted it up forsale here a while back nobody bought it someone in Monroe bought it from me
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                  • FalluccaE30F
                                    FalluccaE30F
                                    FalluccaE30
                                    Heres a good one! LOL
                                    http://racine.craigslist.org/cto/4847145185.html
                                    Something is obviously wrong with this.
                                    post-3411-0-59067400-1390834556thumb.jp
                                    Nick
                                    2002 E46 325i
                                    1991 E30 318i
                                    2013 Jeep SRT8
                                    • teatoe993T
                                      teatoe993T
                                      teatoe993
                                      Plow King
                                      http://detroit.craigslist.org/mcb/cto/4864705084.html
                                        teatoe993 said:
                                        Plow King
                                        Ooooohh!!! I want!!
                                        • andyhundleyA
                                          andyhundleyA
                                          andyhundley
                                          2002 parts
                                          http://milwaukee.craigslist.org/pts/4874391445.html
