  3. Cars For Sale & Wanted
6.1k Posts 117 Posters 82.7k Views 5 Watching
    I don't remember ever seeing this E30 before...?
    MilwaukeeAndy?
      oh man, I don't know how yall missed this one. DAMN!
      http://milwaukee.craigslist.org/cto/4842753510.html
        CYoung said:
        MilwaukeeAndy?
        Well I guess that mystery is solved.
        I'm "special"
          http://appleton.craigslist.org/cto/4844679100.html  clean Alpine E30 Vert again! Anyone here?
            m42b18 said:
            http://chicago.craigslist.org/wcl/pts/4837783972.html
            Not a whole car but if I remember correctly an e30 hardtop is super rare
            This is a good deal, and yeah they are rare if they have the head liner and all the brackets. I WANT THIS.
              http://miami.craigslist.org/pbc/cto/4844309627.html
              Idiots will be idiots. Apparently a guy on BF told him its not an e21 and that it is indeed an e30. Guy insists this is an e21. So much that he offered it to the BF guy for $1k if he's wrong. Wow!!
                Link to said thread. I foresee many lulz and much butthurt
                  http://www.bimmerforums.com/forum/showthread.php?2153784-what-s-wrong-with-this
                    Leaving at 6 to check this beast out.  I will bring my dealer reset tool ;)
                    http://lacrosse.craigslist.org/cto/4794383332.html
                      You suck=P
                        http://bringatrailer.com/2015/01/20/golf-yellow-flared-1972-bmw-3-0-csl/     Not a C-list car, but hawt damn  :wub:
                          It was garbage.  He would let it go for 300 but I think the ECU is fried, he wasn't telling the whole story about what happened, claims he replaced the battery and it wouldn't start right away.  It cranks strong but no spark and no fuel pump, not even the 5 second prime when the key is turned to run.  Would hooking up battery backwards fry it?  Not sure but the fuel pump works fine when the relay is jumpered.  I did not test jumpering the engine control module relay, it is also controlled by the ECU.  I am not sure the sequence of operation as to when that should close.  Unless the problem is that relay I would deduce that the ECU is no good.
                          Overall the car was maybe a 2/10.  Rockers made of spray foam and bondo, floor peeling away the seam to the rocker.  Bald tires, rip in driver seat, etc.  Not worth 300 even.
                            Found my rear brake upgrade and LSD.  He wants 600 for the whole rear setup, seems a little high to me, thoughts?  Supposedly only had 86k.  From a 99 m3 vert.
                            http://dubuque.craigslist.org/pts/4838678123.html
                              Thanks for posting about this one. I came across it while searching for M42s. Don't know anything about the anti-theft systems, but I figured it would be easy to reset. If it was a runner I would be interested in it for the motor. I don't have any way of moving non-running cars 😕
                                I would pass even on it even for the engine, it did not look well taken care of.  Electrical tape on the spark plug wires, very dirty, and inside the valve cover looked like oil changes were not a priority.
                                The "anti theft" is just a relay above the drivers left knee, pull the relay and put a jumper in to bypass.  Pretty high tech.
                                  Hooking a battery up backwards can short an ECU for sure.
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    Clean looking E30 325ix
                                    another one
                                    That was mine I posted it up forsale here a while back nobody bought it someone in Monroe bought it from me
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                    • FalluccaE30F
                                      FalluccaE30F
                                      FalluccaE30
                                      Heres a good one! LOL
                                      http://racine.craigslist.org/cto/4847145185.html
                                      Something is obviously wrong with this.
                                      post-3411-0-59067400-1390834556thumb.jp
                                      Nick
                                      2002 E46 325i
                                      1991 E30 318i
                                      2013 Jeep SRT8
                                      • teatoe993T
                                        teatoe993T
                                        teatoe993
                                        Plow King
                                        http://detroit.craigslist.org/mcb/cto/4864705084.html
                                          teatoe993 said:
                                          Plow King
                                          Ooooohh!!! I want!!
