    Media blasted the shifter carrier
    It was a pain trying to get the rouge out of the inset spots so I decided to clean it up the easiest way I could=)
    My orders from Garagistic and Ireland Engineering also arrived
    I am currently ordering all of my clutch components and have a dssr on the way as well=)
      $$$$ Earl's a pimp
      • RamRod E28R
        RamRod E28R
        RamRod E28
        It's been so long since I've seen this thread... holy progress batman!!! Looking good earl!!!
        1988 BMW 528e - Need parts?
        1996 Mazda Miata (SOLD!!!)
        1996 BMW 325i (Donor car)
        • mkoeppM
          mkoeppM
          mkoepp
          I can't wait to see this beast. Pictures never do a car like that justice.
            DSSR arrived and is the perfect length. Glad that the e30 m3 lever ended up being the only one that was even close
            Currently modifying my z3 lever to fit. BMW revised the bushing at the bottom of the lever to eliminate the need for the yellow washers. Unfortunately that makes it too wide to fit in the DSSR.
              Interesting, didn't know that about some shift levers.  Don't take off too much, it should be very snug fitting.
                I am taking it off very slowly with 220 grit sand paper=)
                  That sounds like an exciting evening.
                    I was at it for an hour and still didn't remove enough material. Today will be round two=)
                    Edit: How tight should the fitment be? I know there should be no play but how hard should it be to move the dssr on the shift lever? Right now I can fit it by hand pressing hard and it takes a little force to move
                    • andyhundleyA
                      andyhundleyA
                      andyhundley
                      You want it to move freely but I shouldn't have any side to side movement.
                        I think it will now feel "slightly" better
                          Looking good Earl!
                            My flywheel got finished up yesterday=)
                            My clutch kit should be on it's way here shortly and I am picking up a transmission on Saturday. Once I get the trans, I will be cleaning it up and replacing the shifter detent springs, input/output shaft seals, selector shaft seal, and the selector rod joint.
                              Liking the progress!  Is the car still in storage at the paint shop?
                                I'm so jelly of that shifter linkage! Got to get the wire wheel out and clean mine up!
                                  Still in storage at the paint place indeed=( Still haven't found any shops by us.
                                    What size master are you using with the power brake delete?
                                      Going to be running an 11/16 Rabbit master
                                        I forget, how big is OE?  What was the specific application for yours?  Is that one that Massive recommends?
                                          OE is 23 or 25mm. Lee recommends 17-19mm.
