  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
    I am excited to see this thing run!
      Been waiting for this build thread! Hope you give us lots of details on the fab work.
      • CMartC
        CMartC
        CMart
        Weekend Update:
        Subframe spacers added to the E30 for proper alignment. (shiny things on the bottom right and left)
        15266698110eeba25de28z.jpgimage
        Motor and trans pulled from the E39. I spent a ton of time removing and labeling wires so I can properly reassemble without headache.
        1545340407596702327a3z.jpgimage
        And separated.
        154303367067f740163b3z.jpgimage
        I still need to:
        Pull the E30 driveshaft and get the front end of the E39 one welded on.
        Pull the rest of the harness out of the E39 and remove the unnecessary wires.
        Clean the motor
        Clean the E30 bay
        Put the new motor mounts on
        Weld the trans mount
        Mount the brake booster
        Wire, wire, wire, wire and wire some more.
        Excursion 7.3
        E30 LS1
          Are the spacers to get the proper alignment on the trans to driveshaft?
          • CMartC
            CMartC
            CMart
            Correct.
            1527673486011554aea13z.jpgimage
            1546029761185925a2966z.jpgimage
            152767386807a79f1fc0cz.jpgimage
            15276810788da766c919dz.jpgimage
            Excursion 7.3
            E30 LS1
              Very nice!  that looks like it fits nicely.
                This is exciting stuff! Have you seen JGood's V8 swap thread on R3V?
                Are you planning on having it done by spring?
                • CMartC
                  CMartC
                  CMart
                  It is amazing how much time you can save having the right tools. This was less than 2 hours of cutting. Front end is totally off, B pillars, roof all the way to the rear window, windshield, etc. I wanted to get the 540 out so I had plenty of room for the rest of the fabrication. Planning on taking everything to the scrap yard Saturday morning and then I get really get going on hard stuff.
                  I also decided to make the rad support removable so I can install/remove the engine and trans together instead of having to drop in the motor then add the trans from the bottom. I did it once and it was a pain in the ass.
                  Excursion 7.3
                  E30 LS1
                    I was gonna chop up the last E28 but when I realized it fit on a uhaul I ditched that idea. In 4 engine installation pics.
                    • CMartC
                      CMartC
                      CMart
                      In for a test fit.
                      Excursion 7.3
                      E30 LS1
                        This was definitely gnarly to see in person when picking up that m42 radiator from you.
                          Looks good. I can't wait to see this thing at Gefrorenfahrt!
                          In the unlikely event that the car's not ready it would be still be cool if you brought the CTS-V :)
                          • CMartC
                            CMartC
                            CMart
                            Thanks guys - It is definitely coming together.
                            When is Gefrorenfahrt?
                            Someone was telling me about an E30 meet mid-May. If I can stay motivated through the cold I should have no problem getting it to that.
                            Excursion 7.3
                            E30 LS1
                              lol
                              • M
                                M
                                michael1972
                                Not a big caddi fan but.....that CTS-V tho. Yep
                                • RamRod E28R
                                  RamRod E28R
                                  RamRod E28
                                  How's the exhaust gonna route with the steering linkage? I'd be all over a v8 swap in my e28 if it weren't for the damn steering linkage!!!
                                  1988 BMW 528e - Need parts?
                                  1996 Mazda Miata (SOLD!!!)
                                  1996 BMW 325i (Donor car)
                                  • CMartC
                                    CMartC
                                    CMart
                                    With a welder and a dream.
                                    Really though, I've heard you need new linkage and I've heard it fits around it. I won't know until I get my manifolds cut and start fitting it up. That is small potatoes compared to the brake relocation.
                                    Excursion 7.3
                                    E30 LS1
                                      e30-m60-m62-swap-exhaust%20manifold-500x
                                      http://store.garagistic.com/ocart/e30-m60-m62-swap-headers-exhaust-manifolds
                                      • CMartC
                                        CMartC
                                        CMart
                                        I have the manifolds they use to do this, they came with the car. I am just going to cut off the manifolds at the cat (like they do) and weld on the flange when I do the rest of the exhaust. $350>the $40 it will cost to do it myself.
                                        Excursion 7.3
                                        E30 LS1
                                        • CMartC
                                          CMartC
                                          CMart
                                          BMW 540 for sale - some assembly required...
                                          Finally cleared up some much needed garage space this weekend. Onto removing the radiator support and filling the garage space with some things needed for the fab work that needs to be done. Welder, band saw, vice, press, and bench grinder are up there on this list.
                                          I am also looking for a M62B46 (4.6L motor from the X5). If anyone comes across a wrecked 4.6 X5 or a decent deal on a running or non running motor please let me know.
                                          Excursion 7.3
                                          E30 LS1
