  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    I figured I would start a build thread that got away from my member intro as I will be really pushing to get this done over the next three weeks.
    This started off with me wanting to LS swap a E30. I found though that you can get a running 540i for the price of a LS1/T56 so since this is my first real swap having all the parts was important to me.
    I start off by buying a 2000 540i with a M62TUB44 and 6 speed behind it. I then learned that these are near impossible to swap so I parted that out and started looking for a pre 99 car.
    1334009041364168d1ecdz.jpgDSC_0106
    1334010240369b0e53118z.jpgDSC_0109
    I came across a 1991 318is in Indiana with a blown motor for a good price so I bought a truck, drove it down and picked it up. Not 100% as described, but a good clean car with low miles - minimal rust - low miles - etc.
    142087469096d4fb012faz.jpgDSC_0384
    My garage will never look this clean again
    Then the tear down of the E30 and part out of the E39 began. Unfortunately I lost a lot of time this summer by not having garage space.
    15224830517d0b6113386z.jpgimage
    After the 2000 E39 was gone my garage had room for the 1998. The E30 is pretty torn down at this point too. I have the motor/trans mounts, but still need the driveshaft shortened. The motor/trans from the E39 will be coming out this weekend. Wiring will be a pain, but since I have the whole car it should be easier.
    15396010152606c91c20ez.jpgimage
    And though not BMW related those 275 tires are from my new toy.
    15209668769f0797f4d4bz.jpgimage
    152098222783cd33c93a3z.jpgimage
    Anyway I will use this thread to keep the build updated. I got a new job recently and have a week off in between my old and new. I will be using that time to get as far as I can on the E30. I thought from the beginning I would build this, sell it and try again with a S62, but depending on how much I like driving the car I will likely keep it, paint it, and do my best to make it look like it just drove off the showroom floor... with a V8...
    Excursion 7.3
    E30 LS1
      I can't wait to see the build progress. Props to you for taking on this swap and wanting to do it as cleanly as possible.
        I am excited to see this thing run!
          Been waiting for this build thread! Hope you give us lots of details on the fab work.
          • CMartC
            CMartC
            CMart
            Weekend Update:
            Subframe spacers added to the E30 for proper alignment. (shiny things on the bottom right and left)
            15266698110eeba25de28z.jpgimage
            Motor and trans pulled from the E39. I spent a ton of time removing and labeling wires so I can properly reassemble without headache.
            1545340407596702327a3z.jpgimage
            And separated.
            154303367067f740163b3z.jpgimage
            I still need to:
            Pull the E30 driveshaft and get the front end of the E39 one welded on.
            Pull the rest of the harness out of the E39 and remove the unnecessary wires.
            Clean the motor
            Clean the E30 bay
            Put the new motor mounts on
            Weld the trans mount
            Mount the brake booster
            Wire, wire, wire, wire and wire some more.
            Excursion 7.3
            E30 LS1
              Are the spacers to get the proper alignment on the trans to driveshaft?
              • CMartC
                CMartC
                CMart
                Correct.
                1527673486011554aea13z.jpgimage
                1546029761185925a2966z.jpgimage
                152767386807a79f1fc0cz.jpgimage
                15276810788da766c919dz.jpgimage
                Excursion 7.3
                E30 LS1
                  Very nice!  that looks like it fits nicely.
                    This is exciting stuff! Have you seen JGood's V8 swap thread on R3V?
                    Are you planning on having it done by spring?
                    • CMartC
                      CMartC
                      CMart
                      It is amazing how much time you can save having the right tools. This was less than 2 hours of cutting. Front end is totally off, B pillars, roof all the way to the rear window, windshield, etc. I wanted to get the 540 out so I had plenty of room for the rest of the fabrication. Planning on taking everything to the scrap yard Saturday morning and then I get really get going on hard stuff.
                      I also decided to make the rad support removable so I can install/remove the engine and trans together instead of having to drop in the motor then add the trans from the bottom. I did it once and it was a pain in the ass.
                      Excursion 7.3
                      E30 LS1
                        I was gonna chop up the last E28 but when I realized it fit on a uhaul I ditched that idea. In 4 engine installation pics.
                        • CMartC
                          CMartC
                          CMart
                          In for a test fit.
                          Excursion 7.3
                          E30 LS1
                            This was definitely gnarly to see in person when picking up that m42 radiator from you.
                              Looks good. I can't wait to see this thing at Gefrorenfahrt!
                              In the unlikely event that the car's not ready it would be still be cool if you brought the CTS-V :)
                              • CMartC
                                CMartC
                                CMart
                                Thanks guys - It is definitely coming together.
                                When is Gefrorenfahrt?
                                Someone was telling me about an E30 meet mid-May. If I can stay motivated through the cold I should have no problem getting it to that.
                                Excursion 7.3
                                E30 LS1
                                  lol
                                  • M
                                    M
                                    michael1972
                                    Not a big caddi fan but.....that CTS-V tho. Yep
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      How's the exhaust gonna route with the steering linkage? I'd be all over a v8 swap in my e28 if it weren't for the damn steering linkage!!!
                                      1988 BMW 528e - Need parts?
                                      1996 Mazda Miata (SOLD!!!)
                                      1996 BMW 325i (Donor car)
                                      • CMartC
                                        CMartC
                                        CMart
                                        With a welder and a dream.
                                        Really though, I've heard you need new linkage and I've heard it fits around it. I won't know until I get my manifolds cut and start fitting it up. That is small potatoes compared to the brake relocation.
                                        Excursion 7.3
                                        E30 LS1
                                          e30-m60-m62-swap-exhaust%20manifold-500x
                                          http://store.garagistic.com/ocart/e30-m60-m62-swap-headers-exhaust-manifolds
