  4. TehRaydarlover's AWD lover
156 Posts 15 Posters 0 Views 1 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    Anytime! Depending on where your located, if you ever need help working on it hit me up.
      So is this all done to simply increase the strength of the front diff?
      Awesome project, and I like that analyzer.
      I'm sure you know this, but I would hope you check what kind of tool steel that is? I'm not even sure what it's doing so I can't really comment on how strong it needs to be.
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        Yeah that's the goal, should be able to handle pretty much everything I can throw at it when its done. Yeah I was going to shoot it just for fun. I don't think it will see a huge load its mainly just holding the shaft the spider gears ride on. I figured if it is some sort of tool steel it should be nice and hard and hopefully help keep the shafts aligned correctly.
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          Put in my LED fog lights and high beams. Quite the improvement in visibility with the LEDs vs. halogens:
          14411941020619639349526213497895023537
          Before anyone says anything about the pitting, I already have some cerium oxide on the way haha
          10869408102061963937752697839761915444
          10900043102062011385738867125327763933
          10873339102062011408139421315478049015
          Just lows:
          10869908102062011424539839089758605405
          lows with fogs:
          10887433102062011443740311348855342057
          Just lows:
          10887503102062011482141276478107167608
          Lows with fogs:
          10854453102062011504941842383934986342
          And lows with LED brights:
          15562771020620115265423826905601730650
            Sweet. Whats the lumen rating?
              Details on the bulbs please.
              Sent from my potato phone
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                The fogs are 1600LM per bulb, 5000k and the highs are 1800LM per bulb, 6000k. There is a guy on r3v that sells the kits. Picked them up during his black Friday sale.
                  I like the fogs! Might have to go this route also.
                    Link to the kits please.
                      I dont even see a post showing any fogs
                      • TehRaydarloverT
                        TehRaydarloverT
                        TehRaydarlover
                         http://www.r3vlimited.com/board/showthread.php?t=323966
                        Here are the brights, I just asked him for the fogs and he made it happen.
                        Fog must be too thick to see?
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          Thanks to Rowleym for the m20 block, coffee table coming along nicely:
                          10888668102062636590168585936938686927
                          10865833102062636648570043358986562169
                          10916335102062636717371764732125058495
                          Here's an interesting shot of the location of the main oil galley (cylinder wall on the right)
                          10407342102062477885001054561607351084
                            That is incredible! You need a 200 head to replace that 885 with. keep the 885 alive!
                            I say LED mood lights in place of the spark plugs
                            • TehRaydarloverT
                              TehRaydarloverT
                              TehRaydarlover
                              Head is cracked so nbd, also going to put in a full valvetrain. Defiantly putting light in the spark plug holes. Will make perfect lighting for the pistons and valves, and the wires will be hidden on the back side of the block, win win.
                                Will you be getting megasquirt to run the lighting? =P I think a starter motor rigged up would be cool to spin it all
                                  Use a stock plug wire loom and have a hollowed out coil containing a battery pack for a dc power source
                                  Id like to see pics of the crack on the head
                                  • TehRaydarloverT
                                    TehRaydarloverT
                                    TehRaydarlover
                                    might go a little fast with a starter motor hooked up haha.
                                    pic of the drug addict:
                                    post-3378-0-59064000-1420426216thumb.jp
                                      Yikes, thats a serious overheat
                                        Wow never seen a crack like that.  I got a set of LED 9004 hi/lo bulbs coming to try out on the Maxima.  If they work pretty good I am interested in putting them in my new Hella lights for my e36.  Did you/ could you try the LED in the projector low beams to see how the pattern looks?
                                        • TehRaydarloverT
                                          TehRaydarloverT
                                          TehRaydarlover
                                          Yeah it's a pretty impressive crack. The cam and rocker arms that were in it are quite f'd too. I didn't get the lows yet because I have smileys. He said with the bulb placement(too far forward?) it creates a hot spot. LEDs work fine for regular ellipsoids. I might try to do a bi-xenon or just regular hit for the lows. We'll see. Guess I could/should have just tried it with a fog light bulb.
