  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    The tires on these e39 rims are 215/55R17 and the seem to fit okay in the front from lock to lock. No problem in the rear.
    Just to make some clearance for snow I'll get some new 205/50R17 for them so I'm able to rotate all 4 to slow down rear tire wear.
    74.1 to 72.6 spacers are on their way.
    Mudflaps are in the works also. Going to get as flappy as possible!!
    What oil should I run with the S54? I'm about to do some searching but want your input also!
    Thanks for lookin'.
      I would stick with the castol 10w60 from the dealer. To my understanding the castrol 10w60 sold elsewhere is different. For mudflaps, I'd just order oem ones, they're only like $30 a pair. You don't need to be running around looking like a Subaru fanboy.
        I always get the castrol from the dealer. Is that weight okay to run in the colder temps?
        The flaps are to help prevent direct road spray hitting the car. The stock ones don't look like they do a great job of that.
        • T
          T
          tsweers89
          The choice of the right SAE grade is based on the climatic conditions in the region in which you normally drive.
          *The following is the only recommended and approved synthetic oil for BMW M (Motorsport)vehicles in the US market with gasoline engines, at the present time.
          BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles
          equipped with S54, S62, S65 or S85 engines
          Castrol EDGE Professional TWS Motorsport SAE 10W-60 Synthetic Engine Oil,
          BMW part number 07 51 0 009 420
          or
          Castrol Edge Professional OE 5W30 Synthetic Engine Oil
          BMW part number 07 51 0 037 195
            Best options for an e46 roof rack?
              I'm running the oem one on my wagon, love it. I believe the standard e46 coupe/sedan crossbars are about $220 from BMW.
                So far this winter the M3 has been doing okay. Avoiding driving it on the super cold days in favor of the 2001 XJ Jeep.
                Necessary to do's:
                - Weld two new resonators I have into section 1.
                - Install new crush rings and bolts where the headers meet section 1.
                Hopefully these two fixes will fix the running rich on bank 1&2 and stop the vibrations at low rpm.
                - Connect sunroof drain hose in the A pillar.
                - Dry out the carpet.
                  Finally getting some exhaust stuff welded up!
                  Resonators and MagnaFlow muffler.
                      Doing a little work on the M3. Paint, flaps.
                      a099b8b139133d32520a8544b25896b4.jpgd4ca224fc73324e1c046ff654a39c60b.jpga1a69a13a358a93909d2e52b3fe545b4.jpgc7d580f20ddcc4bd90912e56c5e61366.jpg12d19c2fd989d18b36bd5887b0021802.jpgbb33e565229ed27344c1853de7ea4fbd.jpg1d5979237c37b8c62e718c794ebb75dd.jpg
                        Painting Kevin's old wheels?
                          Had to... the field paint wasn't too professional.
                          Anyone know what style these rims are? I really like them.
                            Nice card trick! :P
                              f6f27fda30a371e5beb3f06fcef05c80.jpg8b556baf338ebbb62fe3d67abdf7e223.jpg86d8e13dbe3e4afe9940817cfcabb6fc.jpg
                              Almost done. The fiancée isn't too happy about the paint fumes that are in the entire house now but at least they're painted! :mellow:
                                DrLeadFoot said:
                                Had to... the field paint wasn't too professional. Anyone know what style these rims are? I really like them.
                                Not arguing against it, I know how crazy they were in person haha. Style 18's I believe.
                                  17c5fc716ebaa43ae065af5888b7b64c.jpg6ef663ed2fba02064b963a78fb253edd.jpg9de5dc7206d93a5e5aa7d4f57be78da3.jpg
                                  Finally done. Passenger rear is slightly rubbing. I'll let itself do the adjustments.
                                    404 ERROR
                                    Fatlace/illest sticker not found
                                      404 ERROR
                                      Haha.
                                        Now time to test out these snow tires!
                                          For reference:
                                          http://www.bimmerforums.com/forum/showthread.php?245961-Steering-wheel-squeak-FIXED-Writeup-w-pics
                                          http://www.bimmerfest.com/forums/showthread.php?t=494644
