  3. BMW Discussion
  4. 17" wheel fitment on a E30
42 Posts 12 Posters 0 Views 1 Watching
  • M
    M
    michael1972
    The wheels Im thinking about getting are 16x8 et 20 and 16x9 et 15 rear. You guys tell me. Whats gonna fit with minimal work..ie no fender pulling.
    • M
      M
      michael1972
      I think he suggested the 245 because its spec for a 9" wheel. I just want em flush and filling the wheel well.
        Here's a 16"x9" ET10 on a 205/40..... A 245 or 235 is gonna be...."tight".
        My fenders are rolled, but a "flat" sideway I don't think will fit at all.
          Be a man and run the real meats!
            Even a 215 rear will probably require a roll. Had plenty if fun getting Eric's rears clearanced on his 318 with same wheels sizes and offsets. Being that you have an early model, the high arches will give you a little extra room.
              Stock size sure will. Go to r3v and under the wheel and tire thread there are hundreds of people asking about specific setups and getting answers. Give it a look.
              • M
                M
                michael1972
                What about 205/40 fr and 225/40 rear.
                • M
                  M
                  michael1972
                  And will the 40 series be tall enough to fill my wheel well? Your car looks a bit lower then mine classE
                  post-2797-0-01453400-1418244813thumb.jp
                  post-2797-0-33108200-1418244831thumb.jp
                  post-2797-0-77262900-1418244847thumb.jp
                    http://www.willtheyfit.com/index.php?width=225&aspect=50&diameter=16&wheelwidth=7&offset=42&width2=225&aspect2=45&diameter2=17&wheelwidth2=8&offset2=20#content
                    fitment calculator
                      ^i would personally use a 40 sidewall. BUT I LIKE EM STIFF
                      • M
                        M
                        michael1972
                        fitment calculator
                        Thanks. Now I need to know the stock specs for the 14" BMW wheels
                        • M
                          M
                          michael1972
                          Are you running 16x9 with the 205/40 square? Also are those the smiley headlights? I dig those.
                            Those are just ellipsoids, an ellipsoid "smiley" looks like this.
                              Yeah that is a square setup on Collins car=) I think he may have a small spacer in the front or rear too. Fat tires definitely won't work all that well with the offsets your thinking though. 205/40 is what I would run if I had 16's. I have 205/40's on my 9.5's and 215/40's on my 10's.....my "fitment" is a little different than what you are after though.
                                are you going to be stock power level and not trackin or racing the car?
                                • M
                                  M
                                  michael1972
                                  Just the conforti chip for now. I am gonna do some light auto cross but will just use stockers fir that. I think I am gonn go with the 16x9 square setup with the 205/40's. I'm diggin the fat lip all the way around.
                                      if you want better looks and better handling in one fowl swoop,
                                      16x7.5 205/50
                                      16x8 225/45
                                      17x7.5 215/40
                                      17x8 235/40 (roll fenders)
                                      all should have an offset of about et20
                                      anything wider than 8" and you lose performance in your tire, because you can't use the proper size.
                                      if your car is not lowered, i'd go 15" or 16"
                                      • M
                                        M
                                        michael1972
                                        16x7.5 205/50
                                        16x8 225/45
                                        17x7.5 215/40
                                        My car is lowered on h&r race and e90 hats
                                          Well this just set the standard for the next e30 I want haha.
