  4. 540i: Resonator/Muffler delete.
49 Posts 9 Posters 885 Views 2 Watching
    The big thing I'm shooting for is more tone around town and no drone on the hwy.  I love how quiet this thing is on the highway.  However, when I mash the throttle, I want to hear that V8 sound.
      I've driven/ridden in his car and it has no drone on the highway. Only thing I'd have done differently is put in a straight pipe so the exhaust exits out behind the car and not under it. Still a simple mod and great results.
      He has videos here. http://www.wibimmers.com/board/index.php?/topic/2493-camera-tow-hook-mount/?fromsearch=1
        After looking at a few other forums, I have a new query.
        What about dual straight pipes from the Y-resonator?  As in, cut a hole in the dead end y-resonator, and branch off for an additional exit on the other side of the car.
        I've seen a couple of videos where people deleted the muffler all together and sounded great under load with little to no drone at cruising speed.  That's what I want to achieve.  However, this was just single exit with a turn down at the end.  Exhaust piping is cheap and I could play with it a bit but I'd like to get some opinions, educated guesses, ect.
        • CMartC
          CMartC
          CMart
          My 2001 had 2 sets of cats and a straight pipe. Sounded great when you wanted it to, but didn't drone out on the highway.
          I believe you have 2 2-1 headers which don't have the cats built in so it won't be the same, but without any muffler it wasn't as bad as I thought it would be.
          Excursion 7.3
          E30 LS1
          • Dominic540D
            Dominic540D
            Dominic540
            CYoung said:
            I believe Dominic540i just chopped off his "scuba tank" and it sounds awesome. Not sure if his exhaust is the same as yours though.
            You are correct there, and it should be the exact same exhaust. I always planned to put a turndown pipe in its place, but never got around to it. Now I have other plans anyway, since my car is completely torn apart. My exhaust is off entirely if you would like pictures of anything also. I would definitely recommend it though. Very slight loss in bottom end torque (almost unnoticeable), but definite gains in top end power.
            As far as the dual exhaust option, it would require cutting/modifying the spare tire tub, as there is no room for a pipe on the passenger side. I would stay away from that personally.
              Yeah, if you could post some photos, that'd be great!
              • Dominic540D
                Dominic540D
                Dominic540
                Not a problem. It'll be a day or two before I get to it, but I'll see what I can do for you. I should really start a thread for my car at some point too....
                  Or do they crazy and weld in a M5 trunk floor and swap bumpers!
                  I 2nd starting more 540i build threads.
                  • BMWbenB
                    BMWbenB
                    BMWben
                    Dominic540 said:
                    .As far as the dual exhaust option, it would require cutting/modifying the spare tire tub, as there is no room for a pipe on the passenger side. I would stay away from that personally.
                    Or do dual pipes side by side like my 540  :cool: also, another person to join our 540 gang when we go to meets Dom!
                    I really need to do my exhaust too, I'm just cutting out my cats and stock resonator and putting a magnaflow resonator on. If you want Zach, we could team up and knock both of our cars out when I'm home in a week.
                    BMWCCA #499464
                      I'm all the way on Lake Michigan, otherwise I'd be game. I'm going to do my exhaust work about the same time I do my trans flush/filter change/diff flush.
                      Sadly, my car is an i/A, so I'm like the bastard child of the 540 clan.  Like Jon Snow, but a total bitch.
                      • BMWbenB
                        BMWbenB
                        BMWben
                        I'm sure we could make an exception but I'd have to consult Dom. On the over on Lake Michigan part, I will more likely then not head over to Milwaukee area for a visit to some family friends (Chris, Aaron Anding wants us to visit) maybe we could work something out where when I'm over there there we can do it that weekend and then Chris could could just be there because party, then have a party. My friends are flexible so we could plan something and get all the stars to align just right.
                        BMWCCA #499464
                          I'm down!
                          • Dominic540D
                            Dominic540D
                            Dominic540
                            Woohoo, the gang is growing! (And yes, I think we can make the exception.)
                            I plan on doing a very similar exhaust setup once I get everything done and put back together.
                              I second an M5 rear bumper cover for true duals.
                              Simply cutting off the dead end donkey dick thing under the car should not hurt performance, but it is a major percentage of the total resonator volume, it will make it louder and possibly add a drone.
                              If it were me, I'd cut the entire stock resonator thing off, make custom dual exhaust from the Y back.  I'd weld in two tuned resonators (magnaflow or similar) and hand two smaller mufflers in the rear (again, magnaflow or similar).
                              I've never looked underneath a 540, but can you run a passenger exhaust and keep the spare?
                              • CMartC
                                CMartC
                                CMart
                                Someone in the 540 clan should really think about buying mine. It was badass.
                                https://m.flickr.com/#/photos/121188167@N08/15508368719/
                                Excursion 7.3
                                E30 LS1
                                  Except for the rediculous looking crush bends
                                  • CMartC
                                    CMartC
                                    CMart
                                    Yes, except for the rEdiculous looking crush bends that you can't see because they are under the car.
                                    Excursion 7.3
                                    E30 LS1
                                    • BMWbenB
                                      BMWbenB
                                      BMWben
                                      CMart said:
                                      Someone in the 540 clan should really think about buying mine. It was badass. https://m.flickr.com/#/photos/121188167@N08/15508368719/
                                      Im ballin on a broke ass college kid budget and my 540 is a e34, probably won't bolt right in.
                                      Your in Milwaukee too, might as well do all the 540 gangs exhaust done this winter. On a second note, WIbimmer 540 gang stickers. A necessity.
                                      BMWCCA #499464
                                      • CMartC
                                        CMartC
                                        CMart
                                        Can my bastard 340i join?
                                        And yeah I think this will only fit a late model E39 or any one with the 4-1 manifolds.
                                        Excursion 7.3
                                        E30 LS1
                                        • Dominic540D
                                          Dominic540D
                                          Dominic540
                                          It may be possible, but I have not thought seriously enough about it to warrant giving it a try. If it is possible, I would imagine it could be rather difficult, and may hang down lower than the underside of the car.
                                          I am just north of Milwaukee by about 40 miles (only about 15 from Zach), but my car is no where near ready to have an exhaust put on. It currently has the engine and tranny removed and half of the engine is apart with more to do.
                                          I like the sticker idea though, definitely necessary.
