  4. E30 Radiator Support Removal
11 Posts 5 Posters 0 Views 1 Watching
    A few guys on here have done it. You essentially remove yours with a spot weld drill bit and then bolt it back on when you're done.
    • CMartC
      CMartC
      CMart
      Yeah, I get the concept. I am mainly looking for an in depth how to that shows each spot where it is welded.
      Excursion 7.3
      E30 LS1
        I swear Jake (Stewcrew) had pictures of when he did his on here but I can't turn anything up=/
          The spot welds are freaking everywhere, and there are a bunch that are hard to get to. I ended up cutting mine out not so nicely because mine was a bit too rusty to want to put back in.
            Starting on post #168
            http://www.wibimmers.com/board/index.php?/topic/1087-e30-m50-tear-down-kinda-thing/page-9
            • CMartC
              CMartC
              CMart
              Awesome thanks.
              Looks like I have some drilling/cutting to do.
              Excursion 7.3
              E30 LS1
                I personally would seperate the top section(where the headlights hold on to or whatever, and build a lower support for the radiator. So, you can pull the front end off without having the radiator come off every time as well.
                someguy2800(From BF.C) or something has that setup. i think it turned out great.
                • CMartC
                  CMartC
                  CMart
                  Thanks I am definitely still open to recommendations.
                  Link?
                  Excursion 7.3
                  E30 LS1
                    I don't quite see the point of doing it that way. I figured they were made removable to pull engines easier, and you need the radiator out to do so. Maybe I am missing something g.
                      I like to take the front end off for easier access to things on the front of the engine, when you don't need to flush the cooling system and such. You could make it come off with a couple of pins, so it would be uber quick on the track to do some fixin' without absolutely having to take the radiator off every time. But, when you want to, its just a bolt or two, and a couple hoses to do so.
                      preference though!
                      Its a ford 9" e30 with a borg warner turbo and e85 and a t56, I bet you can find it on google
