  4. My new 1995 540i/6
My new 1995 540i/6
150 Posts 18 Posters 3.1k Views 2 Watching
    Probably still suspension bits that need replacement, but awesome!
      Again, when you are ready to trade cars. You know where to find me
      • BMWbenB
        BMWbenB
        BMWben
        That is true, I'm going to start saving for those so I can get it done. Probably just have the shop that did my drive shaft stuff do it because you have to have an engine hoist and I've never done it before. Unless we can possibly do it when I'm home but $$$
        I don't think I could fit all my crap for school in a E30 for the drive down here. What do you get on the highway with a boosted M20?
        Also I've run into a slight paint problem. When she was sitting around for such a long time the sun and probably snap from the trees started bubbling the clear coat a bit. Here are a couple example pics.
        There are probably around 6 on the hood and one on the roof. I was thinking about trying to wet sand it with 2000 grit but would that leave it looking terrible? I've never dealt with anything like this so I don't know how to get the best result. Any suggestion?
        BMWCCA #499464
          Are you sure it bubbled? You can use hand sanitizer to dissolve pine sap, it should just come off.
          Sent from my potato phone
            I told you to get a cheap car cover! If its just the sap,then a small application of alcohol will take it off.
            • BMWbenB
              BMWbenB
              BMWben
              Turns out it was just sap! Took a good amount of rubbing so get it off but it worked out. One less problem to deal with.
              BMWCCA #499464
                Good deal, an application of good wax should make it easier to clean in the future.
                • BMWbenB
                  BMWbenB
                  BMWben
                  Bad news everyone, problems have come up again and you guessed it....their with the brakes. So I was going to drive over to my grandparents place for the day and when I pressed in the brake to stop the car from rolling the brakes froze up pretty much exactly as they did before I replaced all the calipers. I haven't noticed any significant problems with the brakes before today. For all I know everything else in the brake system needs to be replaced but I wanted a second opinion so what do you guys think?
                  BMWCCA #499464
                    Could it be a binding linkage/sticking master cylinder?
                      It sounds like a master issue to me. Your abs could be on the fritz too?
                        Is the pedal overly firm or does it feel normal when the brakes locked up?  If the pedal is normal but all of your calipers seize then you need a new master.  If the pedal is rock solid then you have a booster issue.
                        • CMartC
                          CMartC
                          CMart
                          I'm not sure if they are compatible but I have a bunch of e39 brake parts of you need anything.
                          Excursion 7.3
                          E30 LS1
                            Talking on the phone last night I think he said the peddle got firmer, but I'll wait for Ben to confirm.
                              The booster is easy to diagnose.  With the car off, push the pedal a few times to firm it up then, while holding the pedal like you were sitting at a stop light, turn the car on.  The pedal should drop, if not then it's a bad booster.  The hose going to the booster can also be suspect if it is too soft and pinching shut.
                                Thinking about this more, the master won't cause the brakes to lock up at all.  It will cause a low or spongy pedal but not lock up.  It has to be either brake booster or an obstruction in the lines/hoses creating pressure and causing a lock up.
                                • BMWbenB
                                  BMWbenB
                                  BMWben
                                  I was thinking today and last night and I guess I have realized the brake petal getting increasing harder. It would make sense that pressure in the system is constantly building up and then finally causing the brakes to stop relaxing. Another thing is the mileage on car, when I replaced the old calipers they were literally falling apart from rust (I broke one of the bleeder screw clear off) so there could be easily be rust in the system messing stuff up. Of course being a poor college kid I had to go with the quick fix but that never works out and here I am. For me to be able to get it to a shop, do you think I could open one of the bleeder screws to release some pressure from the system, possibly relaxing the calipers for enough time to get me to a shop. My car is not in a position so do any sort of work as of right now so doing a full bleed or trying to look/work on something is completely out of the question.
                                  BMWCCA #499464
                                  • BMWbenB
                                    BMWbenB
                                    BMWben
                                     I'm not sure if they do either but I'm in South Carolina right now for school and I'm trying to drive home in a week. Thank you for the offer! Maybe we can work something out though.
                                    BMWCCA #499464
                                      I would highly recommend you don't do that.  You would need to crack open all of them and you will lose fluid quickly.  It could become dangerous very quickly and there is a good chance it wouldn't work.
                                      • BMWbenB
                                        BMWbenB
                                        BMWben
                                        Hmm I wonder if I could get AAA to tow it to my shop for free.
                                        BMWCCA #499464
                                          AAA ftw, why wouldn't they tow it. Just don't try to have them pick it from a repair shop, huge hassle, just get out to the road in front and say it quit there. Tell them it is rwd so they don't send just a front lift truck. You should request a flatbed truck.
