  4. My new 1995 540i/6
My new 1995 540i/6
150 Posts 18 Posters 3.1k Views 2 Watching
  • BMWbenB
    BMWbenB
    BMWben
    This is kinda far off in the process but do you know if I could get the centers powered coated at any old paint shop? or is it normally a specialty place? Also Chris suggested me getting the bolts zinc coated, do you know anything about that?
    BMWCCA #499464
      Powdercoating can be done by anyone who has the equipment. I doubt a paint shop would have a setup. You could also just have them painted professionally. You can't powdercoat the centercaps so if you get the faces powdercoated, you will need to find a matching paint for those.
      You could get your old bolts zinc coated but it depends on the pricing.
      • BMWbenB
        BMWbenB
        BMWben
        Well those gold bolts are $160 for 120 of them so I'll have to find something more cost effective. I soaked the bolts in vinegar to get the corrosion off and I'm going to use a wire wheel and drill to really get them clean. I'm sure I could get paint them myself but the paint probably wouldn't last to long so I need to figure out some way to do that. So what I'm thinking is refinish the faces to give them a nice shine, paint the centers gun metal grey, and get my bolts gold somehow.
        BMWCCA #499464
          You can use Montana Spray paint and clear coat and they will hold up good.
          Also, I am surprised you found gold bolts for that cheap. Those would be of suspect quality. I pay more than that for just chrome bolts when I have built wheels=)
          • BMWbenB
            BMWbenB
            BMWben
            I got a little done on my car this week, I had dropped her off at a shop last Sunday to get the drive shaft work done. Picked her up this Wednesday and the guy who did the work told me the brakes had seized up bad. I somehow got her back to my grandparents place (brakes a smoking) and proceeded to order new calipers for the front. I started on the job last night, got the calipers off easy but the rotors and mounting bracket nuts would not budge. 3c158157e4636a65c3a2bf3849b35f4b.jpg7c36db4a07b32a95aac70b443b88e306.jpg
            So I slept on it and picked up a blow torch this morning and gave it another go but still got no where. I decided to just try putting on the new calipers and just see what happens.
            I got the new calipers on and started to bleed the brakes and the bleeder screw on the rear passenger caliper decided to break clear off. Looks like I get to replace those one too. Maybe I can get it done next weekend but you never know. At least I finally got a chance to give her a good washing.
            BMWCCA #499464
              Can't wait till we actually detail this thing! The interior will clean up awesome too.
              • BMWbenB
                BMWbenB
                BMWben
                Finally got the car rolling last night! I threw on the back calipers and bled the brakes. Everything seemed to be in working order so I drove her back to school. I can't tell if the problems are completely fixed, there are is some noises the car still makes but they were probably there before and I'm not used to them. Maybe the new parts just need to be broken in a little, who knows. I can look into it some more this winter when I have time and money. At least I have my baby back for now at least.
                BMWCCA #499464
                  Probably still suspension bits that need replacement, but awesome!
                    Again, when you are ready to trade cars. You know where to find me
                    • BMWbenB
                      BMWbenB
                      BMWben
                      That is true, I'm going to start saving for those so I can get it done. Probably just have the shop that did my drive shaft stuff do it because you have to have an engine hoist and I've never done it before. Unless we can possibly do it when I'm home but $$$
                      I don't think I could fit all my crap for school in a E30 for the drive down here. What do you get on the highway with a boosted M20?
                      Also I've run into a slight paint problem. When she was sitting around for such a long time the sun and probably snap from the trees started bubbling the clear coat a bit. Here are a couple example pics.
                      There are probably around 6 on the hood and one on the roof. I was thinking about trying to wet sand it with 2000 grit but would that leave it looking terrible? I've never dealt with anything like this so I don't know how to get the best result. Any suggestion?
                      BMWCCA #499464
                        Are you sure it bubbled? You can use hand sanitizer to dissolve pine sap, it should just come off.
                        Sent from my potato phone
                          I told you to get a cheap car cover! If its just the sap,then a small application of alcohol will take it off.
                          • BMWbenB
                            BMWbenB
                            BMWben
                            Turns out it was just sap! Took a good amount of rubbing so get it off but it worked out. One less problem to deal with.
                            BMWCCA #499464
                              Good deal, an application of good wax should make it easier to clean in the future.
                              • BMWbenB
                                BMWbenB
                                BMWben
                                Bad news everyone, problems have come up again and you guessed it....their with the brakes. So I was going to drive over to my grandparents place for the day and when I pressed in the brake to stop the car from rolling the brakes froze up pretty much exactly as they did before I replaced all the calipers. I haven't noticed any significant problems with the brakes before today. For all I know everything else in the brake system needs to be replaced but I wanted a second opinion so what do you guys think?
                                BMWCCA #499464
                                  Could it be a binding linkage/sticking master cylinder?
                                    It sounds like a master issue to me. Your abs could be on the fritz too?
                                      Is the pedal overly firm or does it feel normal when the brakes locked up?  If the pedal is normal but all of your calipers seize then you need a new master.  If the pedal is rock solid then you have a booster issue.
                                      • CMartC
                                        CMartC
                                        CMart
                                        I'm not sure if they are compatible but I have a bunch of e39 brake parts of you need anything.
                                        Excursion 7.3
                                        E30 LS1
                                          Talking on the phone last night I think he said the peddle got firmer, but I'll wait for Ben to confirm.
