  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
    It's actually Montreal blue, with black bedlined rockers. It's perfect for a few years as a fun work beater. He is hooked already, I told him to join up on here.
    Sent from my potato phone
    • dastuzD
      dastuzD
      dastuz
      M3 ate a wall this fall... and got rear ended by a 350Z moments later... so the winter project is... an over the top rebuild.
      Front
      -Electric Fan
      -Low temp thermostat
      -New water pump (metal impeller)
      -Power pulleys
      -Brake ducts
      -New hood
      -New bumper cover
      -Larger radiator
      -New fender
      Interior
      -Full gut...
      -New comp steering wheel
      -Dash mounted battery cut off
      -Cage
      Suspension/wheels
      -Adjustable rear control arms
      -New rims / tires (at 265 right now...  looking to see if 285 will work well instead)
      Rear
      -New trunk
      -A lot of body work!
      Sure I forgot some items... and it'll grow as I build
      I'll have quite a few stock parts I'll be listing here and there as I go.
        Sorry to hear about the mishap. Looks like you have a busy winter making that car into even more of a track monster!
        • dastuzD
          dastuzD
          dastuz
          The car was over 6 ft in the air, slammed back to the ground, and then was struck at over 60mph by another car...  and I walked away with minor neck pain.  I figured I owed it to the car for the over the top build.  Man...  those cars are built so well.
          • dastuzD
            dastuzD
            dastuz
            Just a sample...
            post-3482-0-17328900-1417574306thumb.jp
            post-3482-0-52589400-1417574349thumb.jp
            post-3482-0-33498800-1417574384thumb.jp
              This!
                Gonna do some shaving? 0_o
                  Engine delete
                    I'm driving my BMW.  Yay.  Nice to have one again.  Plus, it does 100 mph before you hit the end of a freeway on ramp. ...so I'm told.
                    However, I have a complaint about TJ.  HE SELLS CARS WITH BURNED OUT 3RD BRAKE LIGHTS.  Avoid this seller at all costs.
                      I replaced the batteries in one of my key fobs and re-initialized the key.  I can now remotely lock and unlock my car.
                      I also found if I put the key to my chin, I can lock/unlock my car from 80ish yards away.  SICK.
                        ^Jeremy Clarkson teach you that? 😃
                          Haha, no I was reading a thread about key reprogramming on bimmerforums and someone mentioned it.
                          This weekend I'm getting a new brake light switch and a spare LCM from a guy parting out a couple of 540's.  Also replacing some burned out bulbs around the car.  Thinking about getting the dead pixels fixed in the cluster after the new year.
                          Also, I'll be cracking open the mystery glove box.  Will post pics of contents.
                            Got the mystery glove box opened. No guns, unfortunately. However, if you need lasik, I know a guy.
                            Apparently stubborn glove box is common in 5er's of this vintage. I also found out why the car is so clean for having 257k. Must have been a Wisconsin to Illinois commuter car.
                              Very little content for a glove box=P
                                Right?  I was hoping for at least a .38 special (gun or CD)
                                • andyhundleyA
                                  andyhundleyA
                                  andyhundley
                                  TJ and I didn't want to break the glovebox.
                                    It was simple as lifting the lever and pushing up on the glove box.  The mechanism is just a little goofy.
                                      ^Same with the e34 issues
                                      • I love my E39I
                                        I love my E39I
                                        I love my E39
                                        Making sure if it ever snows that it is dry and clean. Through the winter in the driveway under wrap. =]
                                        -Because Racecar-
                                          I installed an afe cold air intake and shark injector on my dad's E46 330i today.  I have no pics to prove this actually happened.
