E21 project thread
Have you been driving this thing?
Drove it to my house, we drove around New Germany and cried about the ending of Where The Red Fern Grows.
It was a magical time indeed!
This car drove.
For a whole 30 feet!
Video evidence is required
So Snap had an epiphany about my cars issues today and it might just do the trick. Tomorrow shall be the test to see if its good to go. Cross fingers!
Wow. THe skills excersised here. Just amazing. Love the work, love the car. I am astounded.
And the results are??
Thanks man! Lots of thought, engineering, and custom work has gone into this setup. Yeah there were easier ways to do things, but my #1 philosophy is being different. Even if it means making things more difficult for myself, lol.
Haven't gotten over to the car yet. Will be this afternoon. I will update this pronto!
You are welcome. The work looks amazing and difficult. The car is going to be a lot of fun and has a lot of heart into. Enjoy it!
giddy UP!!
Dressed up the daily quick.
And wanted to introduce the new member of the family!
Well our initial thought doesn't seem to be the case, but still doing some testing on injector wiring.
Update: Was testing the wiring for the injector pins just now. Checked continuity between the injector clip pins and chassis ground, got nothing which is good. Then I tested continuity between the injector pins on the MS db37 connector and the injector clips. Db37 pins 34 & 35 tested good against cyl 2 & 4 injector clips. Db37 pin 33 tested good against cyl 1 & 3 injector clips, but db37 pin 32 was a no go. Hhmmm interesting. Took apart the db37 plug and unwrapped the tape around wires and found this for pin 32.
That wire for pin 32 popped out of the db37 connector pin, which is why continuity was zero. Getting closer! So now I just need to figure out how to get that wire back in and seated right and see if that fixes my issues.
Well good news!! I ended up buying a d-sub crimper tool and a d-sub extractor/insertion tool from radio shack. I was a bitch extracting the pin from the connector without the wire attached, but eventually got it with the help of a bent paperclip. when attempting to recrimp the wire onto the old pin, the pin broke in half. Went back to radio shack and bought some new pins. Crimped wire and inserted back into connector with tool. BINGO!!! Continuity on pin 32 is now golden. Put wiring back together, installed injector clips, throttle body and charge piping again and fired her up.
She runs amazingly smooth now with no more shutter! I am assuming that with the one wire connected to injectors 1&3 that they werent getting enough current to fire enough fuel, causing the shutter. Now I just need to retune everything since its running super rich and i should be good to go!!
flares probably won't be done till winter or even next year. The car needs mucho body work done before the flares can even go on too.
yeah, yeah, yeah
=( Well at least post a bunrout video!
Second this, can I get a third?
