  4. M20 Cylinder Head Porting
16 Posts 5 Posters 0 Views 1 Watching
    This thread here seems to hold some solid research and information concerning M20 cylinder head design/modification.
    http://speedtalk.com/forum/viewtopic.php?f=1&t=31132
    For anyone wanting to know what the cross section of the ports looks like, here is a silicone casting of the ports and combustion chamber
    731 head left  885 head right
    Measurements taken of the stock combustion chamber to give you an idea about what kind of engineering/drugs was involved in creating such a high-spec single cam engine from the 80's
    Flow bench testing with putty added to the floor of the port for experimentation
    The results that come from knowing what you are doing with cylinder head porting:
    350rwhp on an NA M20
    timingbelte30bmw325528525.jpg?w=490&h=21
    I wish I had all the time and knowledge to build a proper cylinder head but unfortunately I do not.
    DrLeadFoot mentioned doing some porting on his old M20 and getting good results. Has anyone messed around with portwork?
    I mostly plan on polishing the combustion chambers, mirror finish exhaust ports, port matching the intake and exhaust, then adding a dowel to the intake manifold/head for it to locate consistently after it is matched.  Nothing too exotic. I would hate to do anything on the intake side to kill the performance.
      That sound is incredible!  I too wish I had more time to play with this sort of thing.  That wasn't a stock cam I assume but it sure idled smooth.
      On another note about head modifications, there is an interesting practice with grooving certain spots in the combustion chamber invented by a guy from India named Somender Singh.  Google dat.
        It looks like Jim McFarland Dimples are a thing too
          Ah yes, thanks for the reminder. I read something about that years ago I need to take a look at it again because I forgot the premise of it.
          Id like to think that it just increased tumbling and likelyhood of complete combustion.
          Metric Mechanic puts grooves in their CC's as well.
            From the brief reading I just did, it helps make for cleaner combustion and helps eliminate carbon buildup. Have a spare head to play with? =P
              Edges typically become hot-spots prone to pre-ignition though. I have known people to polish the CC to minimize the chance of carbon grabbing a foothold to stick to.
                Supposedly that is why the grooves aren't very deep. If you make them too deep you essentially make "glow plugs" at the edges
                • TehRaydarloverT
                  TehRaydarloverT
                  TehRaydarlover
                  I've been reading through all of these threads on various forums, researching porting  the m20 cylinder head. Finally started. This is just a ruff cut of the intake. I still have to polish/fine tune and do the exhaust and combustion chambers. So far I'm pretty happy with how it's turning out. I have data from flowing the stock head in college, it would be cool to flow it again after I'm done and see how much I killed the flow haha.
                    Looking forward to seeing some CFM comparisons. What tools are you using for material removal? just die grinders?
                    • TehRaydarloverT
                      TehRaydarloverT
                      TehRaydarlover
                      Yeah, just bur bits and flapper wheels. Need to make sure to use a cutting oil of some kind otherwise the aluminum gums up in the bur bits.
                        I used wd40 as a cutting oil on mine for the gasket matching. Its cheap and works. Thats pretty much my only use for WD40, it blows for everything else besides "displacing water"
                        I see "bent valve" on the head, is this a practice head? Or what you are using for your build?
                          haha!
                          *ahem*
                          anyway, I'm glad you recognize the futility of doing port work without a couple spare heads, a flow bench, and a lot of trial and error. Most of what I've read comes from books on small block chevys written by David Vizard. Those heads respond the opposite of what you would expect, because most of the intake flow skips the short-side radius and flows across the back of the valve. Helping the air follow that path also helps improve swirl on the intake stroke. Of course BMWs don't have a (shitty?) wedge-head design, so I'm sure the rules are completely different. Regardless, unless you're running huge cams your main focus should be improving low-lift flow, since the valve spends a lot of time there. Getting the flow started early in the cycle is like getting a good run at the last corner before a long straight. 5mph faster through the corner means you're faster the whole way down the straight. A good valve job goes a long way...
                          • TehRaydarloverT
                            TehRaydarloverT
                            TehRaydarlover
                            Yep, I was just using mineral spirits from the parts washer haha.
                            This is "the" head. Out of the 6 heads i have this is literally the only one without scorn cam journals. The jounerals on this one are literally perfect. It came from a junk yard south of mke. I'm guessing it snapped a timing belt back in the day and has been sitting on that shelf for years. The shed it was in looked like it could fall down at any moment haha.
                            • TehRaydarloverT
                              TehRaydarloverT
                              TehRaydarlover
                              Yep lol, I practiced on a cracked head but yeah without a flow bench all I can do is try and make it look intuitive to me. The car will be turbocharged, so I guess I can overcome poor flow by increasing the delta P haha.
                              From talking with Jim at metric mechanic you get the most improvements from the roof cut. Looking at pictures on the Internet that also seems to be what most people do.
                              I've been trying to almost square off the roof and blend in the bowl machining into the runner. Then also shortening the ramp to the valve and make it follow the flow more, instead of a ramping choke point. I think I'm going to take some more off to make it follow the radius of the runner into the combustion chamber.
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                Looking down the intake runner
