  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
    Its the equivalent of daytime running lights essentially. In Germany (not sure about the rest of Europe) if you are parking on the side of the road at night, your marked lights on the side of the vehicle must be on while the vehicle is parked. On the newer BMW's this activated by hitting the turn signal switch after you have shut off the vehicle.
      bigjae1976
      Installed a Momo steering wheel.
      10615632801837443189904749181795550811
      10351302801837466523235735011074263759
      And some ricing...I meant racing stripes.
      10389020801836996523282343897115083547
        can't say I've seen a momo in a E46, looks great!
          My floors no longer leak.
          Which means they hold water
          Which also means I still have a leak somewhere
          After a crazy storm that lasted about 6 hours. I had about an inch of standing water on the floor
          Maybe I could start a coy pond
          Or just wear crocs all the time
          Either way. It's holding me off from finishing the carpets.
            I was going to ask you how the storms were, the radar looked pretty intense up there. Now I know.
            Id say sunroof or possibly elephant trunk is clogged
            Twist 90 degrees or so to remove
              Don't have those in my car.
              But there is still the upper portion they connect to. I'll give it a look after work.
              Definitely wasn't sunroof or door seals. Nothing was soaked in that region
                ive had a bad passenger weatherstripping ever since I got my car (you can see sunlight through the very top corner of the door from inside) but it doesn't leak. You cant explain that
                  ^some things cannot be explained=P
                  • mkoeppM
                    mkoeppM
                    mkoepp
                    Cleaned her up yesterday and going to clay and wax her today.
                      Looks great!
                        Sold my 328i today... it was a sad day but I could tell the guy that bought it was truly thrilled after he drove it.
                        • mkoeppM
                          mkoeppM
                          mkoepp
                          Now you have some wiggle room for new projects ? :).
                          I only sold one BMW that I owned and that was a 94 325i sedan. I really liked the car but it was TOO small. I always felt cramped. It was great in all other regards and a blast to drive. It was in that car that I received my only speeding ticket in the last 15 years. I remember doing 55 and downshifting and rev matching into third and "Holy Crap" did that thing pull. I do miss it for that reason alone. I have a sweet spot for my E28's. I guess I am getting old but still have some class  :cool: .
                          • mkoeppM
                            mkoeppM
                            mkoepp
                            I ended up staining the picnic table and yard fence instead. I may get to it tonight or early tomorrow. I really need to build it up as I may be driving it this winter :(.
                            If I can I hope to get a mini van to prevent this but it does not look good as of now.
                              White plasti dip the door bottoms/wheel arches to keep the rust away! That's my plan if I ever drive a bimmer in winter again.
                                Now I have some wiggle room for a new washer and drier and finishing some home projects lol.  And of course i'll be getting a few things done with my 335i now.
                                • shovzS
                                  shovzS
                                  shovz
                                  was the buyer from Racine?
                                    shovz said:
                                    was the buyer from Racine? Sent from my iPhone using Tapatalk
                                    Nope, he ended up living right in Milton.  I got a text from him at 8:30 am asking if him and his step brother could come look at it and they were at my house by 11 am and bought it.  I did have someone that was going to come look at it on Sunday as well but I do not know where they were from.
                                      About to pop the vanos unit on and torque the exhaust cam bolts. Then pray as I manually turn the motor over to check for interference.
                                        Just turn the crank twice and the cams should have the "#1 TDC" flats level parallel again.  Just giver!!
                                          Done and done. Except for the giver part. Soon though.
