pistonse30
    I will be getting the VAC harmonic dampener. I tried to order it today but they didn't have time to process my order. I called twice. Great products, phones... not so much.
      Got this over the weekend.
      Is anyone familiar with timing the S52 that could swing by my house and make sure I have it correct? Willing to pay $$$
        Thanks Jeff!!!!!
          Nice work jeff!
          • JeffJ
            JeffJ
            Jeff
            Thanks! Guys just got a new lathe last week hoping to have it running this week!
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • TehRaydarloverT
              TehRaydarloverT
              TehRaydarlover
              Just read the last 8 pages... life seems so much simpler without those 12 extra valves haha :P
                The headache is worth the outcome! I got a taste of the power and it is addicting. The only car that got me was that fox body 5.0 that was turbocharged and probably built. He got the jump on me and still didn't pull more than one car on me. Soon. Soon.
                • TehRaydarloverT
                  TehRaydarloverT
                  TehRaydarlover
                  awesome haha, keep up the good work!
                    Finally got into the garage.
                    With my JB racing flywheel there is no flywheel lock hole so I just need to keep an eye on the tdc mark.
                    The cam locking tool that I got was a little too narrow. So I'm going to watch that with my eye too. Sketch yes. I need to get this on the road.
                    Got the timing set up and just need to torque down the exhaust cam bolts while there is torque on the tensioner.
                    Then is is all down hill from there.
                    • milwaukeeandyM
                      milwaukeeandyM
                      milwaukeeandy
                      Then lets shoot photos
                        Got the lower cover on and torqued down. Black RTV'd everything and used the gaskets so hopefully no leaks.
                        VAC damper is on but I'm waiting to torque the NEW crank bolt.
                        Should finish the timing in the next 48 hours.
                        I've been busy...
                        Won the Milwaukee All City Mens Softball Tournament...
                        And got engaged!!!
                          Congrats on all occasions=)
                            Sounds like life is going well! Glad to hear. Count me in on photographies w/ andy
                            • milwaukeeandyM
                              milwaukeeandyM
                              milwaukeeandy
                                So close yet so far.
                                Need to get all new block to engine mount bolts and torque & loctite them properly. Along with new motor mount bolts. The "stock" condor bolts have been beyond stripped. 0a2fa236f34cc46a75a219129a8c1a9d.jpg
                                Out with the old... in with new!!
                                New water heater too. $460 labor and parts. Jose the Plumber can do everything and some! 3 month warranty on his labor, insured, hard worker.
                                • mkoeppM
                                  mkoeppM
                                  mkoepp
                                  Congratulations are in order and progress is looking good. All :) for you!
                                    Finally made some good progress.
                                    Made my cam tool.
                                    Got the vanos all bolted up, rtv'd and torqued down.
                                    Documenting these spark plugs. Kummrow put these in. I will replace them and make sure they are gapped to .021 and facing away from the intake.
                                    To do list:
                                    - Install oil pump.
                                    - Oil pan.
                                    - Valve cover.
                                    - Torque subframe.
                                    - Steering rack.
                                    - Skid plate.
                                    - Torque down transmission.
                                    - New bolts for motor mounts, engine and subframe side.
                                    - Random odds & ends to tighten up.
                                    - Intake manifold & throttle body.
                                      What are those plugs? NGK V power?
                                        They are.  Do you know anything about them?
                                          I use NGK 2288 in my m50, they have 2 grounds, and a protruding center electrode, they are also the factory plugs for the s50, I pulled a set from an m52 that said NGK on one side and BMW on the other.  My m50 came with Bosch 4 ground plugs that I replaced with the NGKs and gained 2mpg.  I looked up the x52 engines and they have a few other choices, so see if the plugs you have are any of them, there also may be different heat ranges required with a turbo setup which I do not know about.  I just know that I prefer NGK plugs.  Also now that I think about it...why would the x50 engines have different plugs than the x52 engines?  The heads, blocks etc are the same castings so any of them should be physically interchangeable, unless it is a piston clearance issue?
