  4. Wrecked car won't start
30 Posts 7 Posters 589 Views 1 Watching
    Oops, I forgot something that I recently learned, obd2 has the CPS at the back of the crankshaft.  No worries about that then.
    • X
      X
      xgeetx
      Hmmmm. So letting it idle for a bit, the only abnormal sound is the fan rubbing the duct tape I have holding my overflow hose up, since the fan shroud is snapped. I haven't attempted to drive it since it's still missing a front end.
      Any idea what the bad exhaust smell is? Is that from continuous failed starts? Maybe put a lot of fuel in the cylinders or something? Maybe it's just from idling? Any ideas on that?
      Here was the sound when it wouldn't start...
        You may be correct on the smell from lots of cranking without firing.  I have found with mine that if I start it just to move the car and shut it off without running it for more than a minute it will run very rough the next time I start it.  I'm not sure if it fouls the plugs or why but my m50 and m20 and our Maxima are all that way.
        • NarcosisN
          NarcosisN
          Narcosis
          Have you pulled & inspected the plugs?
          What happened to the car?
          • NarcosisN
            NarcosisN
            Narcosis
            It sounds like your fleet of cars needs a tune up.
            • X
              X
              xgeetx
              Hey narcosis! I have not pulled and inspected the plugs. I pulled a couple coils and looked down the tube to see if there was anything bizarre, but there wasn't. Maybe I should pull all the coils? I changed the plugs about 700 miles ago, so I doubt they're part of it... but if you recommend I still take a look I definitely will!
              As far as what happened, I rear-ended someone. I have some pics on the "Well Crap :(" thread if you're curious.
                They are freshly tuned, no issues there.  Only happens when starting and moving the car a couple feet and shutting it off so that it only ran for 15-30 seconds.  It will just run rough for a few seconds on startup the next time.  Not sure if newer ones are better but try it sometime.
                  Is there some sort of "reset" button that needs to be switched after an accident?
                  My buddy had a Grand Marquis that didn't start until he google'd the issue. The Doc don't no des new cars...
                    There shouldn't be.
                    The Grand Marquis has a fuel shut off valve that is standard on all Ford products.  That thing can be set by hip checking the body or a loud subwoofer as well.
                    • X
                      X
                      xgeetx
                      Checked down in all the plug wells (holes?) for oil, and didn't find any. It now starts even with the MAF plugged in but it runs a little rough. The car has a distinct vibration. Could this be because the fan is missing some fins? I wouldn't think that imbalance has much effect, but thought I'd add it :P
                      After letting it idle a few minutes, the temperature seemed fine, but the engine started to smoke from the area I show here: http://imgur.com/CGYmJAg
                      The smoke wasn't very thick, but was white/gray. It smelled 'burnt', but I'm not attuned to the standard engine smoking smells. It didn't smell sweet like coolant, but I don't know what burning coolant smells like!
                        That smell is oil burning off your exhaust manifold due to a leaky valve cover gasket. I'm sure it was bad before the accident, you're just smelling it now because the car's been sitting.
                        • X
                          X
                          xgeetx
                          Hmmm so it was probably smoking before too? Should I be able to see something dripping in that area?
                            You could try a mirror just under the valve cover where it meets the head and you will see some moisture but I have never experienced a leaky valve cover where it was bad enough to watch it drip out.  Usually it's a very slow run.  If you turn your heat on while parked and running you will smell it through your vents.
                            I have always thought of the valve cover gaskets as a maintenance item as soon as I bought an e36.
                            • X
                              X
                              xgeetx
                              To be fair, it has been leaking for a while, and I've been told about it... I just always monitored my oil level and didn't think a slow leak was a big deal. If that leak triggers a smokey engine, sounds like it's time to replace it. I'm scarred from the time I attempted to change it on a Nissan several years ago and it ended up spraying (literally) oil all over the engine.
                                I would get it done as soon as you can but I haven't heard of them getting that bad!
                                • X
                                  X
                                  xgeetx
                                  How bad? Are you surprised it's causing smoke?
                                    I have seen them cause smoke but I have never heard of them spraying oil like you mentioned with your Nissan.  Sorry for my delayed response as I am sure you have been waiting in suspense for my answer lol.
                                    • X
                                      X
                                      xgeetx
                                      Haha! Maybe a little bit.
                                      The spraying I think was because I didn't seat the gasket on correctly, and then drove around. It appeared to have "sprayed" because the engine was covered in oil, but perhaps I exaggerated a bit :).
                                      Got a new radiator fan, radiator mount (holy shit only $39 on ebay w/ free shipping), and the cap & bleed screw for my expansion tank. Waiting on the gasket to get here and then we'll see how it all goes! I'm hoping the engine was shaking because of the now-asymmetrical radiator fan... hence the new one I ordered.
