  4. Wrecked car won't start
30 Posts 7 Posters 588 Views 1 Watching
  • X
    X
    xgeetx
    Thanks guys. I'll look into this I. The evening. I ordered a tank and it came with no cap or bleed screw :P any reason that will be an issue right now? I know I'll need it before I drive around
      I can send you a used cap and bleed screw for the cost of shipping, I won't be needing them anymore.  PM me.
      • X
        X
        xgeetx
        DrLeadFoot said:
        What kind of motor?
        M52 motor, btw.
          I think it's blown up and I'll even do you the favor of removing the car from you :)
          • X
            X
            xgeetx
            Haha, this is the 3rd offer from people who could "take it off my hands"! I'm not convinced it's blown up quite yet! ;)
            • X
              X
              xgeetx
              http://imgur.com/SaDzEbX
              Is that where the crank position sensor is supposed to be??! Looking at images there should definitely be something there... is it possible it hasn't been there for a while or can the engine absolutely not run without it?
              Edit: Looks like that was the sensor position for OBD1 engines? I guess the mystery continues!
              IT STARTED. After I unhooked the MAF and removed the air filter (maybe unnecessary), it started up. It had a really shakey idle for a bit then seemed to calm down. It smells absolutely terrible. Very exhausty around the engine and in the cabin. I now have a headache.
                Oops, I forgot something that I recently learned, obd2 has the CPS at the back of the crankshaft.  No worries about that then.
                • X
                  X
                  xgeetx
                  Hmmmm. So letting it idle for a bit, the only abnormal sound is the fan rubbing the duct tape I have holding my overflow hose up, since the fan shroud is snapped. I haven't attempted to drive it since it's still missing a front end.
                  Any idea what the bad exhaust smell is? Is that from continuous failed starts? Maybe put a lot of fuel in the cylinders or something? Maybe it's just from idling? Any ideas on that?
                  Here was the sound when it wouldn't start...
                    You may be correct on the smell from lots of cranking without firing.  I have found with mine that if I start it just to move the car and shut it off without running it for more than a minute it will run very rough the next time I start it.  I'm not sure if it fouls the plugs or why but my m50 and m20 and our Maxima are all that way.
                    • NarcosisN
                      NarcosisN
                      Narcosis
                      Have you pulled & inspected the plugs?
                      What happened to the car?
                      • NarcosisN
                        NarcosisN
                        Narcosis
                        It sounds like your fleet of cars needs a tune up.
                        • X
                          X
                          xgeetx
                          Hey narcosis! I have not pulled and inspected the plugs. I pulled a couple coils and looked down the tube to see if there was anything bizarre, but there wasn't. Maybe I should pull all the coils? I changed the plugs about 700 miles ago, so I doubt they're part of it... but if you recommend I still take a look I definitely will!
                          As far as what happened, I rear-ended someone. I have some pics on the "Well Crap :(" thread if you're curious.
                            They are freshly tuned, no issues there.  Only happens when starting and moving the car a couple feet and shutting it off so that it only ran for 15-30 seconds.  It will just run rough for a few seconds on startup the next time.  Not sure if newer ones are better but try it sometime.
                              Is there some sort of "reset" button that needs to be switched after an accident?
                              My buddy had a Grand Marquis that didn't start until he google'd the issue. The Doc don't no des new cars...
                                There shouldn't be.
                                The Grand Marquis has a fuel shut off valve that is standard on all Ford products.  That thing can be set by hip checking the body or a loud subwoofer as well.
                                • X
                                  X
                                  xgeetx
                                  Checked down in all the plug wells (holes?) for oil, and didn't find any. It now starts even with the MAF plugged in but it runs a little rough. The car has a distinct vibration. Could this be because the fan is missing some fins? I wouldn't think that imbalance has much effect, but thought I'd add it :P
                                  After letting it idle a few minutes, the temperature seemed fine, but the engine started to smoke from the area I show here: http://imgur.com/CGYmJAg
                                  The smoke wasn't very thick, but was white/gray. It smelled 'burnt', but I'm not attuned to the standard engine smoking smells. It didn't smell sweet like coolant, but I don't know what burning coolant smells like!
                                    That smell is oil burning off your exhaust manifold due to a leaky valve cover gasket. I'm sure it was bad before the accident, you're just smelling it now because the car's been sitting.
                                    • X
                                      X
                                      xgeetx
                                      Hmmm so it was probably smoking before too? Should I be able to see something dripping in that area?
                                        You could try a mirror just under the valve cover where it meets the head and you will see some moisture but I have never experienced a leaky valve cover where it was bad enough to watch it drip out.  Usually it's a very slow run.  If you turn your heat on while parked and running you will smell it through your vents.
                                        I have always thought of the valve cover gaskets as a maintenance item as soon as I bought an e36.
                                        • X
                                          X
                                          xgeetx
                                          To be fair, it has been leaking for a while, and I've been told about it... I just always monitored my oil level and didn't think a slow leak was a big deal. If that leak triggers a smokey engine, sounds like it's time to replace it. I'm scarred from the time I attempted to change it on a Nissan several years ago and it ended up spraying (literally) oil all over the engine.
