  4. E46 window won't go up or down. Motors still fine?
15 Posts 5 Posters 190 Views 1 Watching
    Needs a regulator or the glass pulled out of the regulator. Most likely just needs a new regulator. Regulator replacement is regular.
      Pull the glass out? Which way is the cheapest. Just needs to work. Not looking to spend bookoo bucks on a regulator
        Look up e46 window regulator zip tie fix
          Regulators can be had for about $50 new
            Okay, I'll look into it. Where have you found them for $50? Thanks Tj!
              I too have heard of the zip tie fix.  Google it like a boss.
              • shovzS
                shovzS
                shovz
                This was the first DIY project I ever did on my car. I had no prior car experience what so ever. It was so simple. The only problem with the zip tie fix is you don't know if it will work until you take everything apart. In my case the cord was all messed up and tangled. I splurged and spent 150$ on a regulator from the dealer. I've seen mixed reviews on the other brands. Some say they work for years others say they fail within a year I can't comment on the off brand ones. But as far as saving money. Just do it yourself it's super easy
                  I planned on doing it myself...wouldn't take it to a shop lol
                  • shovzS
                    shovzS
                    shovz
                    yeah it's pretty simple bavauto has a good DIY video
                      Broke the windows motor mounts off? Wtf. It's on a coupe too
                      • X
                        X
                        xgeetx
                        Is the e46 regulator the same as an e36? I have an extra door so you could have the regulator for like $10 if it's a match (if you're in milwaukee0
                          Regulator is fine, as are the clips. The actual mounts broke.
                          • X
                            X
                            xgeetx
                            Hmmm, not sure what the mounts are. If you need new ones and it shares any pieces with an e36, my door is your door.
                              Not the same. But thanks though! I have industrial,( and I mean industrial) zipties. That have a breaking strength up in the... 200lbs of force range. ? I used them in a bout 4 locations to hold the motor in/and to not shift, until I can find a new motor mount!
