  4. Help! Axle/Diff Issue!
11 Posts 4 Posters 0 Views 1 Watching
    bigjae1976
    So the axle bolt sheared off? The half shafts are held in my some E12 bolts. Or do you need to replace the half shaft? Or are you talking about the splines in the hub sheared off?
    I have the tools to do remove the axle if you need some help.
    • T
      T
      TrickTizzle
      I'm not sure...
      I took for another spin last night and the noise goes away when the rear is under load, or if I drop it N.
      I'd say its the half shaft/output shaft. I dont know a whole lot about the drive train on these cars so I'm just guessing.
      Any chance you'd be able to meet up and give the noise a listen?
        If you end up having a bad half shaft, I have a pair of brand new ones in the boxes yet. Not a bad job to do either, less than half an hour per side.
        • T
          T
          TrickTizzle
          Really? I assume you have to remove the axle first, and then you can get at the output shaft.
            bigjae1976
            Are you sure its not a bad center support bearing on the driveshaft?
            • T
              T
              TrickTizzle
              It's hard to tell where the noise is coming from while driving. Seems to be the rear at times and then the center at other times. I think it's the output shaft on the transmission or possibly the driveshaft bearing.
                bigjae1976
                Axles and output shafts just don't break...I'd put my money on the CSB. I have E12 sockets, impact and a universal joint. Drop the exhaust, some covers, and the heat shield. Then you can inspect the center bearing.
                I'd also replace the flex disc, the lock nuts for the flex disk, buy a cover for the CV joint, and repack with grease if you end up replacing the CSB.
                • T
                  T
                  TrickTizzle
                  I think you're right, its the CSB. At first it seemed to be an axel issue but the noise has tapered off a bit but its still there.
                  Does anyone have access to a lift? I don't think this job would be too fun with the car on jackstands..?
                    bigjae1976
                    Its not too bad...depends on how rusted up your exhaust is.
                      If it's a northern car, you probably won't get the cat section separated from the catback without cutting the bolts and putting new in.  With 2 people you can drop the whole thing without too much trouble though.  You need a large channel locks to loosen the nut in the middle of the driveshaft to get it to shorten.  The CSB needs to be preloaded when installed, a fancy term for push it forward 1cm before tightening the bolts.  Mark the 2 parts of the shaft when you separate so you can reassemble the same way.
