<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help! Axle/Diff Issue!]]></title><description><![CDATA[<p dir="auto">Was going to get gas the other day and all of a sudden I hear a big thump...and now when I left off the gas all I hear is thump thump thump. It seems its quite violent. I got under the car and  found one of the nuts of the axles sitting on the exhaust.</p>
<p dir="auto">I live in an apartment so there isnt much room to work in my garage...Would there be any one around Milwaukee that can help me diagnose what's going on with my car and possibly fix the axle if it came down to it?</p>
]]></description><link>https://wibimmers.com/topic/2938/help-axle-diff-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:58:46 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2938.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Jul 2014 22:50:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Tue, 29 Jul 2014 18:56:56 GMT]]></title><description><![CDATA[<p dir="auto">If it's a northern car, you probably won't get the cat section separated from the catback without cutting the bolts and putting new in.  With 2 people you can drop the whole thing without too much trouble though.  You need a large channel locks to loosen the nut in the middle of the driveshaft to get it to shorten.  The CSB needs to be preloaded when installed, a fancy term for push it forward 1cm before tightening the bolts.  Mark the 2 parts of the shaft when you separate so you can reassemble the same way.</p>
]]></description><link>https://wibimmers.com/post/45654</link><guid isPermaLink="true">https://wibimmers.com/post/45654</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 29 Jul 2014 18:56:56 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Tue, 29 Jul 2014 00:22:09 GMT]]></title><description><![CDATA[<p dir="auto">Its not too bad...depends on how rusted up your exhaust is.</p>
]]></description><link>https://wibimmers.com/post/45602</link><guid isPermaLink="true">https://wibimmers.com/post/45602</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Tue, 29 Jul 2014 00:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Tue, 29 Jul 2014 00:04:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/45503">bigjae1976 said:</a></strong></p>
<p dir="auto">Axles and output shafts just don't break...I'd put my money on the CSB. I have E12 sockets, impact and a universal joint. Drop the exhaust, some covers, and the heat shield. Then you can inspect the center bearing.</p>
<p dir="auto">I'd also replace the flex disc, the lock nuts for the flex disk, buy a cover for the CV joint, and repack with grease if you end up replacing the CSB.</p>
<p dir="auto">I think you're right, its the CSB. At first it seemed to be an axel issue but the noise has tapered off a bit but its still there.</p>
<p dir="auto">Does anyone have access to a lift? I don't think this job would be too fun with the car on jackstands..?</p>
]]></description><link>https://wibimmers.com/post/45601</link><guid isPermaLink="true">https://wibimmers.com/post/45601</guid><dc:creator><![CDATA[TrickTizzle]]></dc:creator><pubDate>Tue, 29 Jul 2014 00:04:00 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sun, 27 Jul 2014 18:49:03 GMT]]></title><description><![CDATA[<p dir="auto">Axles and output shafts just don't break...I'd put my money on the CSB. I have E12 sockets, impact and a universal joint. Drop the exhaust, some covers, and the heat shield. Then you can inspect the center bearing.</p>
]]></description><link>https://wibimmers.com/post/45503</link><guid isPermaLink="true">https://wibimmers.com/post/45503</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Sun, 27 Jul 2014 18:49:03 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sun, 27 Jul 2014 16:09:16 GMT]]></title><description><![CDATA[<p dir="auto">It's hard to tell where the noise is coming from while driving. Seems to be the rear at times and then the center at other times. I think it's the output shaft on the transmission or possibly the driveshaft bearing.</p>
]]></description><link>https://wibimmers.com/post/45499</link><guid isPermaLink="true">https://wibimmers.com/post/45499</guid><dc:creator><![CDATA[TrickTizzle]]></dc:creator><pubDate>Sun, 27 Jul 2014 16:09:16 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sun, 27 Jul 2014 07:47:58 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure its not a bad center support bearing on the driveshaft?</p>
]]></description><link>https://wibimmers.com/post/45496</link><guid isPermaLink="true">https://wibimmers.com/post/45496</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Sun, 27 Jul 2014 07:47:58 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sat, 26 Jul 2014 19:03:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/45482">wasnt m3 said:</a></strong></p>
<p dir="auto">If you end up having a bad half shaft, I have a pair of brand new ones in the boxes yet. Not a bad job to do either, less than half an hour per side.</p>
<p dir="auto">Really? I assume you have to remove the axle first, and then you can get at the output shaft.</p>
]]></description><link>https://wibimmers.com/post/45483</link><guid isPermaLink="true">https://wibimmers.com/post/45483</guid><dc:creator><![CDATA[TrickTizzle]]></dc:creator><pubDate>Sat, 26 Jul 2014 19:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sat, 26 Jul 2014 18:50:10 GMT]]></title><description><![CDATA[<p dir="auto">If you end up having a bad half shaft, I have a pair of brand new ones in the boxes yet. Not a bad job to do either, less than half an hour per side.</p>
]]></description><link>https://wibimmers.com/post/45482</link><guid isPermaLink="true">https://wibimmers.com/post/45482</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Sat, 26 Jul 2014 18:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sat, 26 Jul 2014 18:29:37 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure...</p>
<p dir="auto">I took for another spin last night and the noise goes away when the rear is under load, or if I drop it N.</p>
<p dir="auto">I'd say its the half shaft/output shaft. I dont know a whole lot about the drive train on these cars so I'm just guessing.</p>
<p dir="auto">Any chance you'd be able to meet up and give the noise a listen?</p>
]]></description><link>https://wibimmers.com/post/45480</link><guid isPermaLink="true">https://wibimmers.com/post/45480</guid><dc:creator><![CDATA[TrickTizzle]]></dc:creator><pubDate>Sat, 26 Jul 2014 18:29:37 GMT</pubDate></item><item><title><![CDATA[Reply to Help! Axle/Diff Issue! on Sat, 26 Jul 2014 05:17:11 GMT]]></title><description><![CDATA[<p dir="auto">So the axle bolt sheared off? The half shafts are held in my some E12 bolts. Or do you need to replace the half shaft? Or are you talking about the splines in the hub sheared off?</p>
<p dir="auto">I have the tools to do remove the axle if you need some help.</p>
]]></description><link>https://wibimmers.com/post/45459</link><guid isPermaLink="true">https://wibimmers.com/post/45459</guid><dc:creator><![CDATA[bigjae1976]]></dc:creator><pubDate>Sat, 26 Jul 2014 05:17:11 GMT</pubDate></item></channel></rss>
