  4. E36 Scrape/Squealing sound when coasting in gear
37 Posts 7 Posters 716 Views 1 Watching
  • X
    X
    xgeetx
    I will definitely look into them. How would I isolate the transmission as the true issue? Pop in with a stethoscope (or are those things a joke :P?). I'm also willing to just take it to a mechanic for inspection, but I always like to do the work myself.
      I LOVE my stethoscope!  When I was in a shop that thing was magic!  I got teased ever time I pulled it out but it worked and that shut everyone up lol.
      • X
        X
        xgeetx
        Think it'd help in this case? Do I buy one of the mechanic ones for like $15 then point it against transmission while someone is pushing gas pedal?
        Is it safe to run back wheels in 1st/2nd while it's up on jack stands?
          It's perfectly fine to jack it up and run it.  Just take every safety step you can to make sure it won't come down.  I usually put all four wheels in the air on jack stands because I am a bit paranoid but it is alright to put 2 jack stands in the back and chock the front wheels.  I usually put the stands under the LCA's in back.
          The $15 stethoscope works just fine for this job and you just move it around on the case until you think you have pinpointed your noise.  I always listened without it first then with and compared noises.  You may not need anyone pushing the pedal unless it is at a certain rpm/mph.  Once you put it in gear the wheels will spin.
          • X
            X
            xgeetx
            You don't need to apply gas in 1st to stop it from dying? I guess that makes sense since it has no car to push... never thought of that.
            I only have 2 jack stands... would it be it worth it to grab 2 more for this, you think? For some reason I picture 4 stands as less safe than 2 :P Do I chock both sides of the front wheels to be safest? Never had to jack up the rear, and when doing the front I always had E-brake and in gear so chocking the back I never second guessed.
            Is there a reason you use the control arms instead of the sides under the jack points?
              I like have all 4 wheels off the ground anytime I work on the car for clearance and safety.  With all 4 off the ground I can give the car a SOLID hip check and it won't move.  If you are only going to lift the back I would put a chock front and back of at least one wheel.  That's how I have done it and I have never had an issue.
              • X
                X
                xgeetx
                Hmmm well I like safety. We're working on my GF's exhaust soon, and we could barely get under with only the back or the front popped up. I think $26 for more stands would be well worth it. Good tips, thank you.
                  I would recommend a pair of 6 ton stands, the footprint is much larger and more stable then the smaller 3 ton stands, I have 2x 6 ton stands and use 2x 3 ton stands so it is more stable when yanking on wrenches etc underneath.  They can be gotten at for not much more cost and saving a few bucks won't matter much if a car falls on you.
                  • X
                    X
                    xgeetx
                    Can i have 6 ton stands on one side and 3 ton stands on the other, or would the height not match up?
                      Use them in pairs on an end of the car, ie 6ton in back and 3 ton in front.  My 6 ton are about the same height at the shortest setting as the 3 ton on their longest height, so I usually have the 6 ton at the lowest or one notch up and the 3 ton extended most of the way.
                      • X
                        X
                        xgeetx
                        Will do! I'm sure having the whole car up will help do the exhaust too, since the issue on her car is in the middle of the pipe :)
                        • X
                          X
                          xgeetx
                          Hey jc,
                          I tried working with those jacks today, and it was the first time the car almost fell :( Luckily I wasn't under it, since I was in the process of jacking it up... is there a strategy around putting the car on 4 jacks? We were doing my girlfriend's mazda, so maybe we just didn't have the jacks in a good place -- when you have the first jacks in place and you start jacking up the other side, what stops the car from making the other jacks start to tilt?
                          I think part of it may be us not having the jacks in the right place, so maybe when I do it on my e36 and have them in the designated spots, it won't be as much an issue.
                            I always lift one end at a time, not side to side, such as get the front up on the 3ton stands at a short setting, then go to the back and get it up on the 6 ton, then go back to the front and lift it to a higher setting, I have 4 wooden ramps that are really helpful, without them it is hard to get the jack under the dif or front subframe unless you have a nice low profile jack.  I would recommend as much bevel on the leading edge of the steps as you can get, mine take a little practice to drive up the "steps".
                            And ALWAYS try to shake the car around when it is on the stands to be sure it is stable before going underneath.
                            Here is a side shot to show how they are constructed, the top board is 2' the second is 3' and the bottom is 4'.  On 2 of them I added a block at the front edge as a stop.  The great thing is that unless your car is really low even if you drove off of the front it wouldn't hurt anything.
                            And they all stack up nicely when you aren't using them.
                              Along with what has been said, I will usually stack up a wheel or two under the car in a place that wont interfere with my work if im going to be underneath it. I will also have the jack in position on the lifting point (not supporting the weight of the car at all) ready to be lifted as an extra precaution incase a helper or someone nearby needs to come to the rescue.
                              The biggest mistake I tend to make involves the rear wheels on the ground, car in gear, and me loosening the driveshaft, axles, or any other powertrain component which then propels the car forward making it want to come off the jack stands.
                              dont do that.
                              • X
                                X
                                xgeetx
                                Luckily I do have a low profile jack, but because of that the range isn't the best. Can I get some extra range out of the jack by jacking up, for example, the front, putting on stands... then place the floor jack on some pieces of wood and jacking it farther, adjusting the jack stands again.
                                Also, never jacked up the rear on my car. Should I put the floor jack under the rear differential?
                                  The rear dif works perfect, I lift on the front subframe and the rear dif, I always lift the front first because the rear has more clearance.  I would be careful with using wood under the jack.  What kind of jack do you have?
                                  • X
                                    X
                                    xgeetx
                                    http://www.amazon.com/gp/product/B00BMPFI6I/ref=oh_details_o08_s02_i00?ie=UTF8&psc=1 is the jack that i have.
                                    Is there anything that would be safe to put the jack on to get a little extra height out of it?
                                      That looks like it should give you plenty of height.
                                      • I
                                        I
                                        industrialsized
                                        i'm just going to give my self a warning post and cut out the middle man
                                          Rofl. Im guessing you were about to post something offensive. Such as the N-word or nudes?
