<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E36 Scrape/Squealing sound when coasting in gear]]></title><description><![CDATA[<p dir="auto">Hey guys, I'm having a really terrible sound coming out of my car and I'm hoping to get some info on what it could be. I've looked around on various sound threads, but this situation specifically hasn't been covered (at least not that I could find). The sound is a high pitched squeak/scrape oscillating noise that speeds up with higher speed. I can't really tell if it's the front or the back... or somewhere in between. With windows up it sounds like the back, but with windows down I can't honestly tell. The sound only happens when I'm in gear AND coasting.  I hear it most strongly in 3rd gear and reverse. At interstate speeds I don't hear it all. When I hear the sound it will go away if I either hit the gas pedal (disappears instantly), or push the clutch in.</p>
<p dir="auto">A couple possibilities according to the forums:<br />
- Something on the drive shaft?<br />
- Throw out bearing?<br />
- Other clutch issues<br />
- E-brake scraping?</p>
<p dir="auto">Does anything I said above rule out certain things and hint towards others?</p>
<p dir="auto">Thanks for any help you can provide!</p>
<p dir="auto">EDIT: It's a 1998 328i with ~180k miles on it. To my knowledge the clutch has never been replaced.</p>
]]></description><link>https://wibimmers.com/topic/2884/e36-scrape-squealing-sound-when-coasting-in-gear</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:40 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2884.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Jul 2014 17:57:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Fri, 18 Jul 2014 04:30:17 GMT]]></title><description><![CDATA[<p dir="auto">umm, yes... exactly what i was going to say.</p>
<p dir="auto"><em>Like the prostitute says</em>: '<em>It's not the work</em>. <em>It's</em> the stairs.'</p>
]]></description><link>https://wibimmers.com/post/45104</link><guid isPermaLink="true">https://wibimmers.com/post/45104</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Fri, 18 Jul 2014 04:30:17 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 17 Jul 2014 00:24:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/45032">industrialsized said:</a></strong></p>
<p dir="auto">i'm just going to give my self a warning post and cut out the middle man</p>
<p dir="auto">Rofl. Im guessing you were about to post something offensive. Such as the N-word or nudes?</p>
]]></description><link>https://wibimmers.com/post/45033</link><guid isPermaLink="true">https://wibimmers.com/post/45033</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 17 Jul 2014 00:24:12 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 17 Jul 2014 00:15:44 GMT]]></title><description><![CDATA[<p dir="auto">i'm just going to give my self a warning post and cut out the middle man</p>
]]></description><link>https://wibimmers.com/post/45032</link><guid isPermaLink="true">https://wibimmers.com/post/45032</guid><dc:creator><![CDATA[industrialsized]]></dc:creator><pubDate>Thu, 17 Jul 2014 00:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Mon, 14 Jul 2014 17:01:33 GMT]]></title><description><![CDATA[<p dir="auto">That looks like it should give you plenty of height.</p>
]]></description><link>https://wibimmers.com/post/44846</link><guid isPermaLink="true">https://wibimmers.com/post/44846</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Mon, 14 Jul 2014 17:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Mon, 14 Jul 2014 16:28:50 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.amazon.com/gp/product/B00BMPFI6I/ref=oh_details_o08_s02_i00?ie=UTF8&amp;psc=1" rel="nofollow ugc">http://www.amazon.com/gp/product/B00BMPFI6I/ref=oh_details_o08_s02_i00?ie=UTF8&amp;psc=1</a> is the jack that i have.</p>
<p dir="auto">Is there anything that would be safe to put the jack on to get a little extra height out of it?</p>
]]></description><link>https://wibimmers.com/post/44842</link><guid isPermaLink="true">https://wibimmers.com/post/44842</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Mon, 14 Jul 2014 16:28:50 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Sun, 13 Jul 2014 23:57:21 GMT]]></title><description><![CDATA[<p dir="auto">The rear dif works perfect, I lift on the front subframe and the rear dif, I always lift the front first because the rear has more clearance.  I would be careful with using wood under the jack.  What kind of jack do you have?</p>
]]></description><link>https://wibimmers.com/post/44828</link><guid isPermaLink="true">https://wibimmers.com/post/44828</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sun, 13 Jul 2014 23:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Sun, 13 Jul 2014 15:12:18 GMT]]></title><description><![CDATA[<p dir="auto">Luckily I do have a low profile jack, but because of that the range isn't the best. Can I get some extra range out of the jack by jacking up, for example, the front, putting on stands... then place the floor jack on some pieces of wood and jacking it farther, adjusting the jack stands again.</p>
<p dir="auto">Also, never jacked up the rear on my car. Should I put the floor jack under the rear differential?</p>
]]></description><link>https://wibimmers.com/post/44818</link><guid isPermaLink="true">https://wibimmers.com/post/44818</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Sun, 13 Jul 2014 15:12:18 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Sun, 13 Jul 2014 14:55:11 GMT]]></title><description><![CDATA[<p dir="auto">Along with what has been said, I will usually stack up a wheel or two under the car in a place that wont interfere with my work if im going to be underneath it. I will also have the jack in position on the lifting point (not supporting the weight of the car at all) ready to be lifted as an extra precaution incase a helper or someone nearby needs to come to the rescue. </p>
<p dir="auto">The biggest mistake I tend to make involves the rear wheels on the ground, car in gear, and me loosening the driveshaft, axles, or any other powertrain component which then propels the car forward making it want to come off the jack stands.</p>
<p dir="auto">dont do that.</p>
]]></description><link>https://wibimmers.com/post/44817</link><guid isPermaLink="true">https://wibimmers.com/post/44817</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 13 Jul 2014 14:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Sun, 13 Jul 2014 13:00:03 GMT]]></title><description><![CDATA[<p dir="auto">I always lift one end at a time, not side to side, such as get the front up on the 3ton stands at a short setting, then go to the back and get it up on the 6 ton, then go back to the front and lift it to a higher setting, I have 4 wooden ramps that are really helpful, without them it is hard to get the jack under the dif or front subframe unless you have a nice low profile jack.  I would recommend as much bevel on the leading edge of the steps as you can get, mine take a little practice to drive up the "steps".</p>
<p dir="auto">And ALWAYS try to shake the car around when it is on the stands to be sure it is stable before going underneath.</p>
<p dir="auto"><a href="http://s1317.photobucket.com/user/jc43089/media/WINTER%2013-14%20PROJECTS/GARAGE%20PICTURES/008_zpsdcbf3a81.jpg.html" rel="nofollow ugc"><img src="http://i1317.photobucket.com/albums/t621/jc43089/WINTER%2013-14%20PROJECTS/GARAGE%20PICTURES/008_zpsdcbf3a81.jpg" alt="008zpsdcbf3a81.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Here is a side shot to show how they are constructed, the top board is 2' the second is 3' and the bottom is 4'.  On 2 of them I added a block at the front edge as a stop.  The great thing is that unless your car is really low even if you drove off of the front it wouldn't hurt anything.</p>
<p dir="auto"><a href="http://s1317.photobucket.com/user/jc43089/media/WINTER%2013-14%20PROJECTS/GARAGE%20PICTURES/009_zpse24154f9.jpg.html" rel="nofollow ugc"><img src="http://i1317.photobucket.com/albums/t621/jc43089/WINTER%2013-14%20PROJECTS/GARAGE%20PICTURES/009_zpse24154f9.jpg" alt="009zpse24154f9.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">And they all stack up nicely when you aren't using them.</p>
<p dir="auto"><a href="http://s1317.photobucket.com/user/jc43089/media/WINTER%2013-14%20PROJECTS/GARAGE%20PICTURES/007_zps2f8e0cb8.jpg.html" rel="nofollow ugc"><img src="http://i1317.photobucket.com/albums/t621/jc43089/WINTER%2013-14%20PROJECTS/GARAGE%20PICTURES/007_zps2f8e0cb8.jpg" alt="007zps2f8e0cb8.jpg" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/44816</link><guid isPermaLink="true">https://wibimmers.com/post/44816</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sun, 13 Jul 2014 13:00:03 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Sun, 13 Jul 2014 00:54:42 GMT]]></title><description><![CDATA[<p dir="auto">Hey jc,</p>
<p dir="auto">I tried working with those jacks today, and it was the first time the car almost fell <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /> Luckily I wasn't under it, since I was in the process of jacking it up... is there a strategy around putting the car on 4 jacks? We were doing my girlfriend's mazda, so maybe we just didn't have the jacks in a good place -- when you have the first jacks in place and you start jacking up the other side, what stops the car from making the other jacks start to tilt?</p>
<p dir="auto">I think part of it may be us not having the jacks in the right place, so maybe when I do it on my e36 and have them in the designated spots, it won't be as much an issue.</p>
]]></description><link>https://wibimmers.com/post/44811</link><guid isPermaLink="true">https://wibimmers.com/post/44811</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Sun, 13 Jul 2014 00:54:42 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 19:51:48 GMT]]></title><description><![CDATA[<p dir="auto">Will do! I'm sure having the whole car up will help do the exhaust too, since the issue on her car is in the middle of the pipe <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/44698</link><guid isPermaLink="true">https://wibimmers.com/post/44698</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 19:51:48 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 16:02:28 GMT]]></title><description><![CDATA[<p dir="auto">Use them in pairs on an end of the car, ie 6ton in back and 3 ton in front.  My 6 ton are about the same height at the shortest setting as the 3 ton on their longest height, so I usually have the 6 ton at the lowest or one notch up and the 3 ton extended most of the way.</p>
]]></description><link>https://wibimmers.com/post/44680</link><guid isPermaLink="true">https://wibimmers.com/post/44680</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 10 Jul 2014 16:02:28 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 15:58:57 GMT]]></title><description><![CDATA[<p dir="auto">Can i have 6 ton stands on one side and 3 ton stands on the other, or would the height not match up?</p>
]]></description><link>https://wibimmers.com/post/44678</link><guid isPermaLink="true">https://wibimmers.com/post/44678</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 15:58:57 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 15:56:27 GMT]]></title><description><![CDATA[<p dir="auto">I would recommend a pair of 6 ton stands, the footprint is much larger and more stable then the smaller 3 ton stands, I have 2x 6 ton stands and use 2x 3 ton stands so it is more stable when yanking on wrenches etc underneath.  They can be gotten at for not much more cost and saving a few bucks won't matter much if a car falls on you.</p>
]]></description><link>https://wibimmers.com/post/44677</link><guid isPermaLink="true">https://wibimmers.com/post/44677</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 10 Jul 2014 15:56:27 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 15:42:16 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm well I like safety. We're working on my GF's exhaust soon, and we could barely get under with only the back or the front popped up. I think $26 for more stands would be well worth it. Good tips, thank you.</p>
]]></description><link>https://wibimmers.com/post/44676</link><guid isPermaLink="true">https://wibimmers.com/post/44676</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 15:42:16 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 15:34:04 GMT]]></title><description><![CDATA[<p dir="auto">I like have all 4 wheels off the ground anytime I work on the car for clearance and safety.  With all 4 off the ground I can give the car a SOLID hip check and it won't move.  If you are only going to lift the back I would put a chock front and back of at least one wheel.  That's how I have done it and I have never had an issue.</p>
]]></description><link>https://wibimmers.com/post/44673</link><guid isPermaLink="true">https://wibimmers.com/post/44673</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 10 Jul 2014 15:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 15:27:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/44671">patsbimmer1 said:</a></strong></p>
<p dir="auto">It's perfectly fine to jack it up and run it.  Just take every safety step you can to make sure it won't come down.  I usually put all four wheels in the air on jack stands because I am a bit paranoid but it is alright to put 2 jack stands in the back and chock the front wheels.  I usually put the stands under the LCA's in back.</p>
<p dir="auto">The $15 stethoscope works just fine for this job and you just move it around on the case until you think you have pinpointed your noise.  I always listened without it first then with and compared noises.  You may not need anyone pushing the pedal unless it is at a certain rpm/mph.  Once you put it in gear the wheels will spin.</p>
<p dir="auto">You don't need to apply gas in 1st to stop it from dying? I guess that makes sense since it has no car to push... never thought of that.</p>
<p dir="auto">I only have 2 jack stands... would it be it worth it to grab 2 more for this, you think? For some reason I picture 4 stands as less safe than 2 <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" /> Do I chock both sides of the front wheels to be safest? Never had to jack up the rear, and when doing the front I always had E-brake and in gear so chocking the back I never second guessed.</p>
<p dir="auto">Is there a reason you use the control arms instead of the sides under the jack points?</p>
]]></description><link>https://wibimmers.com/post/44672</link><guid isPermaLink="true">https://wibimmers.com/post/44672</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 15:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 15:16:05 GMT]]></title><description><![CDATA[<p dir="auto">It's perfectly fine to jack it up and run it.  Just take every safety step you can to make sure it won't come down.  I usually put all four wheels in the air on jack stands because I am a bit paranoid but it is alright to put 2 jack stands in the back and chock the front wheels.  I usually put the stands under the LCA's in back.</p>
]]></description><link>https://wibimmers.com/post/44671</link><guid isPermaLink="true">https://wibimmers.com/post/44671</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 10 Jul 2014 15:16:05 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 14:36:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/44664">patsbimmer1 said:</a></strong></p>
<p dir="auto">I LOVE my stethoscope!  When I was in a shop that thing was magic!  I got teased ever time I pulled it out but it worked and that shut everyone up lol.  </p>
<p dir="auto">Think it'd help in this case? Do I buy one of the mechanic ones for like $15 then point it against transmission while someone is pushing gas pedal?</p>
<p dir="auto">Is it safe to run back wheels in 1st/2nd while it's up on jack stands?</p>
]]></description><link>https://wibimmers.com/post/44666</link><guid isPermaLink="true">https://wibimmers.com/post/44666</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 14:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 14:19:49 GMT]]></title><description><![CDATA[<p dir="auto">I LOVE my stethoscope!  When I was in a shop that thing was magic!  I got teased ever time I pulled it out but it worked and that shut everyone up lol.</p>
]]></description><link>https://wibimmers.com/post/44664</link><guid isPermaLink="true">https://wibimmers.com/post/44664</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 10 Jul 2014 14:19:49 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 14:09:12 GMT]]></title><description><![CDATA[<p dir="auto">I will definitely look into them. How would I isolate the transmission as the true issue? Pop in with a stethoscope (or are those things a joke <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" />?). I'm also willing to just take it to a mechanic for inspection, but I always like to do the work myself.</p>
]]></description><link>https://wibimmers.com/post/44661</link><guid isPermaLink="true">https://wibimmers.com/post/44661</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 14:09:12 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 14:03:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/44655">xgeetx said:</a></strong></p>
<p dir="auto">How much cheaper could a transmission that is incredibly robust cost? My brother picked up 2 for 200$ from Dons sportcars. You should check them out. They will have everything you need. </p>
<p dir="auto">Wait a minute is your car clean? Its junk Sell it for cheap. <img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">328's are the best. </p>
<p dir="auto">Is that a salvage yard? Was it a used transmission then?</p>
<p dir="auto">Used with 100k on them. Yea it's a salvage parts place. Can't really go in the yard unless you know what's up.</p>
<p dir="auto">Nothing wrong with used items like zf trans.</p>
]]></description><link>https://wibimmers.com/post/44659</link><guid isPermaLink="true">https://wibimmers.com/post/44659</guid><dc:creator><![CDATA[Rowleym]]></dc:creator><pubDate>Thu, 10 Jul 2014 14:03:43 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 13:52:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/44642">Rowleym said:</a></strong></p>
]]></description><link>https://wibimmers.com/post/44655</link><guid isPermaLink="true">https://wibimmers.com/post/44655</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 13:52:10 GMT</pubDate></item><item><title><![CDATA[Reply to E36 Scrape/Squealing sound when coasting in gear on Thu, 10 Jul 2014 13:31:36 GMT]]></title><description><![CDATA[<p dir="auto">Haha, I actually deep cleaned it and threw in new floor mats 2 weeks ago <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" /> I went without floor mats for a very long time. I'm ashamed.</p>
]]></description><link>https://wibimmers.com/post/44651</link><guid isPermaLink="true">https://wibimmers.com/post/44651</guid><dc:creator><![CDATA[xgeetx]]></dc:creator><pubDate>Thu, 10 Jul 2014 13:31:36 GMT</pubDate></item></channel></rss>
