  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    must
    go
    for ride
    thoon
      Every time it rains I get this on the floor. The whole A pillar is wet. Any ideas? Sunroof seal? Door seal?
        bigjae1976
        Probably the sunroof seal. There's a tube that runs from the edge of the sunroof to the door frame. Might not be connected or something. Might need to drop the headliner.
        You could look at my car and see what you are dealing with. The headliner is out but the sunroof cassette is still in...for now.
          I'd bet the tube came off, I've seen it on plenty of other vehicles.
            Thanks guys!
              Liquid Gold.
              For the records
                6 qts?  Tell me that's not all of it...
                  It calls for 5.8 quarts
                    Really?!?!  My 328i takes 7 qts!
                      Haha so does my s52
                        Reason number 263 to buy an e46 M3:  Save money on oil by buying one less quart.
                        Side note: Ignore fact that 10w60 is roughly the same price as unicorn blood.
                          Yeah the 7 qts is for the factory oil cool......
                          oh wait.
                            Welp, I'm getting a severe clunking while accelerating in 1st and banging/clunking when I let off the throttle going 30mph. Hopefully it's axels but I think the diff is to blame.
                            • T
                              T
                              tsweers89
                              Never heard axles make that noise. Could be rear diff bolts, the front ones sometimes break and cause this issues. Or the diff itself could be bad. Also would want to look into the driveshaft if the diff is not found to be the issue.
                                I didn't see any broken bolts or cracked anything.
                                It sounds and feels like the CSB but the diff had a little play in it and it was making some noise when I had it jacked up and was spinning the wheels like Jam Master J.
                                There has been a new vibration the past 200 miles once I hit 100mph. Anything above/below that it is fine.
                                • T
                                  T
                                  tsweers89
                                  You won't see the broken bolts, they are the front ones that go into the subframe. They have updated bolts from bmw, google e46 m3 rear clunk.
                                    Thank you.
                                      From what I'm reading about the "clunk" I believe that it isn't that. Still leaning towards the CSB. My diff might be making noise when rotating the tires due to the sloppiness of the ///M diff.
                                        http://www.m3forum.net/m3forum/showthread.php?t=375693
                                        This is exactly what the noise is like.
                                          I would definitely believe it's the CSB.  Mine was making HORRENDOUS noise before I replaced it to the point that I thought my diff was gone, my clutch was exploding, my drive shaft was falling out, my wheels were gonna fall off, etc.
                                          Turns out replacing the guibo and CSB fixed it all.  I had a severe clunk when taking off from a stop, banging/ clunking on decel around 25 mph - 35 mph and a vibration between 65 mph and 75 mph.
