  4. crappy e36
crappy e36
64 Posts 10 Posters 0 Views 1 Watching
  • frcefedF
    frcefedF
    frcefed
    I just had an alignment done (that helped a lot with the front) the front tie rod ends feel super tight. I checked all of the mounts for the rear subframe and there are no visible cracks. So m3 rear control arm bushings seem like a good choice, are they available from pelican?
    Sidenote: the m50 stumble at low rpms has never been solved, has it? I had an m50 in an e34 chassis a while back and never found a cure after replacing o2 sensors, cleaning the icv and so on I'm already at my witts end with this m50 stumble and I haven't even done anything, haha I didn't even want an e36 chassis but it was a last minute thing so I guess I'm just gonna roll with it now.
      Did it only stumble when cold? Coolant temp sensor issue?
        Check over the boots on your coils too. If they have any small cracks or splits it can cause a misfire. You should also do a akoke test to find any vacuum leaks. I have a slight miss only at idle and need to smoke test my e34.
        For fromt control arm bushings I would highly recommend the treehouse racing eyeball arms but if this is low budget, offset m3 mounts would be great. If this is a drift car, I would recommend poly rear subframe bushings. The rubber might still have too much give when throwing it sideways. You can get sets through AKG Motorsports, Bimmerworld, or Turner Motorsports. I always order all of my OEM parts through ECS Tuning. They always seem to have the lowest price to me and I have had excellent interaction with their customer service. Some people have had issues in the past but I have never had anything less than great service.
          The m3 bushings for the front control arms are an upgrade (more rubber, they are available with centered hole, and offset hole.  I'm not sure if the offset to increase caster would help you or not.)
          I don't know if the rears are different, I have UUC poly rear trailing arm bushings and they stiffened the rear up nicely, I did not lube them properly the first time and they squeaked fyi.
          • frcefedF
            frcefedF
            frcefed
            It stumbles all the time, hot or cold, just around 2-4k rpms. Besides that it runs perfectly other than the burning bleach smell when I floor it.... Ha the cluster claims its at 44k for mileage, not sure if I believe it.
              You might want to consider e46 control arms as an upgrade.  From what I understand they will give you a little more at full lock.
                They give you added track width mainly I believe. This, plus an SLR half kit(or some rack spacers) will give you lots of lock. Don't just replace the stock arms.
                Also, No need to up the rev limit with a stock motor. Keep it at 6800 or whatever, and don't be afraid the bang the hell out of it. 7k won't hurt a properly maintained m50..
                • frcefedF
                  frcefedF
                  frcefed
                  What is an slr half kit?
                    The e46 arms give you mad tyte camber=P You do need e90 tie rods though to make up the added width. There is a lot you can do to get more lock in the front. There are tons of threads on driftworks and such from UK guys building e36 drift cars.
                    • frcefedF
                      frcefedF
                      frcefed
                      Well I am a sucker for camber, especially when my e34 pillowball mounts are maxed out at like 2.8 degrees:(
                        With e46 arms you will probably put the camber adjustments max positive. Nearly.
                        • frcefedF
                          frcefedF
                          frcefed
                          I dont have pillowball mounts on my e36 yet. Haha
                            http://www.driftworks.com/forum/technical/161071-e30-e36-lock-increase-guide-my-try-photos.html
                            Some more info on the swap.
                            • frcefedF
                              frcefedF
                              frcefed
                              Nice! Yeah I'm definitely doing the e46 swap...
                              Soo I've noticed my rear tires toe in and my tires are wearing ridiculously fast.. anyone know why?
                              • MorzadaM
                                MorzadaM
                                Morzada
                                Given that this thread started with a question about your rear suspension, I'm going to go out on a limb and say that your RTABs are shot.
                                Why can't the Maples just be happy in their shade?
                                • frcefedF
                                  frcefedF
                                  frcefed
                                  Why would that make the tires toe in? Wouldnt that force them back so they toe out?
                                  • frcefedF
                                    frcefedF
                                    frcefed
                                    Well I did some research and my rtabs have to be shot but $280 for solid ones from turner seems like a lot.
                                      I have the UUC red poly RTABs, I don't remember how much they cost but not that much.  Otherwise new OE with limiters (oversize washers that limit deflection) would probably be much better than old worn out ones.
                                        Are they wearing inside or out?
                                          The e36 naturally has a lot of toe in and premature outside tire wear is a common problem. If it's inside then it is for sure the rtab's. The rear wheels will toe out at speed with bad rtabs.
