  4. Turbo missing under load
78 Posts 14 Posters 1.6k Views 2 Watching
  • JeffJ
    JeffJ
    Jeff
    So I have a bunch if missing under load on the e36. Found out I didn't hook my wastegate up correctly had the line on the wrong port. Fixed that now have about 10-12psi sweet right well no!
    It misses from 3200-5000 my afr goes to 9:1-9:5 5000 it stops missing and shoots to 12:1-13:1 not good plenty of power after it stops missing. What causes the missing? Fixes? Suggestion?
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • frcefedF
      frcefedF
      frcefed
      I'm not well educated in turbos but it seems to me like 9:1 would drown your cylinders in gas. The lowest reading you should have from your afr is like 11:1 and up. What are you running for fuel management?
        Yep, you're running rich.
        What are you using to tune it?
          He has a Miller War chip iirc
            Jeff likes to complain about how rich he is
              Definitely too rich causing a misfire.
              • NarcosisN
                NarcosisN
                Narcosis
                How do your plugs look & what are they gapped at?  DId you turbocharge an N/A car?  If so, is the tune an piggy back / drop in or did someone actually tune the car?  Can you datalog the car?
                • frcefedF
                  frcefedF
                  frcefed
                  Does the war chip adjust for fuel as rpms increase? Or do you have seperate fuel management?
                    The extra fuel is manually entered into the fueling table.
                    As a side note, Load (ms) is immensely confusing
                    • frcefedF
                      frcefedF
                      frcefed
                      So then you can change it to give you less fuel, right?
                        yes very easily
                          Because we always measure load in milliseconds right?
                            According to Brody @ Miller, it made the most sense for how they set things up (apparently its injector pw). They would know better than we would, but regardless having TPS or MAP on the load axis makes it immensely easier to diagnose and tune since if you have a rich spot that occurs around 4000 rpm and 10psi, you can convert 10psi to kPa and take a look at the fueling table real easily.
                            • JeffJ
                              JeffJ
                              Jeff
                              Tune my car for me
                              Re gapped the plugs to .22 was over .35? No good
                              Miller blows don't care for it.
                              Time to re tune it hard when it's missing and hoes from rich to lean in a second.
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                over .035"?  thats pretty wide.
                                I have mine set to 0.027" right now 1 heat range colder than stock  (NGK 6)
                                • L
                                  L
                                  lagwagon
                                  9:1 isn't going to cause a misfire. My turbo car very briefly sees 8.5:1 at toe-in and I haven't bothered to tune it out. Also running the miller war chip.
                                  Is it consistent?
                                  Stock fuel pump?
                                  What engine?
                                  Perhaps I could send you my tune to try but my car runs a little different than most.
                                  My advice is to load the base map and work from scratch. Adjusting the timing is not the right thing to do here despite above advice. There's a 99% chance this is mechanical and not tune related. I would start with trying another TPS. Check MAF voltages for proper readings and try different plugs.
                                  Personally I have this same exact issue when cold because I run hot plugs (forget exact model right now, though, sorry)
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    300lph fuel pump it's pretty consistent I have the m50 . I know my injectors are small but shouldn't miss and still have that much fuel.
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                    • L
                                      L
                                      lagwagon
                                      Wait, if I'm understanding this correctly - you are running the war chip and stock injectors with the miller maf? Are you using the M50 base tune and then tuning to the turbo?
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        #24 injectors and using a 24 injector tune and changing it for the turbo stock maf. Need to Chang it
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          24#ers are probably only going to support 8psi max before the duty cycle gets craycray. I bump 100% duty cycle at 12psi on 33#  injectors @43.5psi fuel pressure
