  4. E46 328ci
E46 328ci
156 Posts 19 Posters 3.0k Views 2 Watching
  • 3
    328ci
    lol
    I would replace it with a dynavin if it wasnt $600. It does an alright job, but I definitely can see why people hate it
    And I would replace it with an aftermarket deck if they didnt look absolutely hideous in these cars. I've never seen one framed properly to make it look OEM.
      The trim looks gorgeous man!  The car is going to get where you want it but slow down and enjoy the process right now.
        I like it!  Keep it clean, keep up the maintenance, keep searching for lightly used parts on the forums.
        Cut a spring for the mean time.  One coil never hurt anyone...#gatewaydrug
        • 3
          328ci
          Thanks dude! I like keeping up with maintenance, I like having the peace of mind. Its not completely sound as of the moment, but I've taken care some of the the things that needed the immediate attention. Hope to continue replacing things through out the year!
          I'm tempted to cut a coil in the front...
          Thanks man! I want to enjoy it, but I also want my vision to become a reality.
          Pictures from up north soon after I do some editing
          • 3
            328ci
            Tried to find some locations for pictures today, found a couple good places
            14508489164f9f3750fc8b.jpgIMG_2241 by durty30, on Flickr
            14508735982b56e846358b.jpgIMG_2229 by durty30, on Flickr
            1450874332290a8d525d7b.jpgIMG_2218 by durty30, on Flickr
            1432351999863ffd1e9efb.jpgIMG_2236 by durty30, on Flickr
            • 3
              328ci
              Attempted to do the brakes tonight. Got the passenger side done, but the driver side caliper wasnt compressing the full way so I couldnt slide the caliper over the rotor. Probably gonna have to rebuild as the boot looks to be messed up, the passenger side one looked in a lot better condition
                That road salt just messes everything up, hopefully the piston isn't pitted badly.  A rebuild kit is pretty cheap.
                • 3
                  328ci
                  Got a remaunfactured one on the way, this thing was pretty fucked
                  • 3
                    328ci
                    I'd say those puppies are toast. No symptoms of a sticking caliper or anything though, they did put up a fight trying to get off the rotor, on the driver side only.
                      Yep, good call on a reman, doubtful to save that.  Use plenty of brake grease on everything when reassembling.
                      • 3
                        328ci
                        This caliper had the bracket attached to it. It has BMW engraved on the caliper, was just not expecting it to be all one piece. Got them bleed and all buttoned up, shes good to go
                        Shouldve cleaned the struts...
                          Looks great!  Did you do all 4 or just the fronts?
                          • 3
                            328ci
                            I just did the fronts, the rears are still in good condition
                            • 3
                              328ci
                              Just reading about doing the subframe and diff bushings has me seriously dreading doing it. Sounds like such a PITA. But it really has to be done, and when they are I feel like the car will feel completely different. Then I can finally stop worrying as well.
                                Are there weld in reinforcement kits for the e46 like the e36?  That would be the time to do it.  It isn't too bad of a job, just time consuming.
                                • 3
                                  328ci
                                  Yeah there are, do not have a welder though. Have a friend that might be able to do it...definitely would be the time to do it.
                                  Getting the subframe out shouldnt be too bad (I say that now...), but more so time consuming. Having the emergency brake lines running through it is going to be another pita. My biggest concern in the whole thing is getting the bushings in and out of the subframe/differential. I've researched and thought about it and have decided to go with rubber over poly. Two main reasons being cost and ride quality. I can do the whole subframe and diff for $100 cheaper than it would be to just do the subframe in poly. Also the ride quality, and the stress that they are going to transmit to other components. The only benefit to them is the install, but it isnt worth imo. There is a bushing press at work but I hear people have to trouble with the subframe.
                                  Does anyone have a bushing pulling/pushing tool? or a link to a good one to make?
                                    Don't have any knowledge on the differences between your bushings and how mine were in the E30 - but a long chunk of threaded rod and some nuts/sockets should get them out. Worse case - do what I did in some: Swiss-cheese the bushings and pull them out in pieces.
                                    Car looks great BTW - Moar lows will help with the esthetics IMO, but a good looking car overall.
                                    • 3
                                      328ci
                                      This seems to be the general consensus on how to make your own bushing puller. I'll have to look into it further on how to make one. I do like your idea of just beating the shit out of them.
                                      Thank you. You dont have to tell me twice that the car needs more low lol. I think once I get that, the car will be at where I want it aesthetically, besides an Mtech II rear bumper and either a M3 or Mtech II front bumper
                                      Maintenance comes first though, so the plan is after I take care of the rear end is to go through and figure out anything else that needs immediate attention. Then modzzz
                                      • 3
                                        328ci
                                        Figured out how to photoshop a car lower.
                                        Estimated ride height from springs:
                                        144805711898b9a3015c5c.jpgI can dabble by durty30, on Flickr
                                        Where I would love to be, but probably wont. Depending on the suspension route I go:
                                        1448056752992cd2ded81c.jpgYes by durty30, on Flickr
                                        We got some new cutting compound at work today so I wanted to try it. First washed the car and then clay bared the hood (the only part I buffed). I then used the cutting compound followed by a polish. Finished off with a carnauba wax. The feel is really smooth, but I wished I would have had some of my buddies Zymol. The bead isnt bad either, I took video.
                                        I shot it vertically, im sorry. But you can really see the depth and shine in the paint.
                                        • WiscoE90W
                                          WiscoE90W
                                          WiscoE90
                                          looking good man! if your going to DIV come find me.
                                          Instagram ~ weak_e90
