pistonse30
    I'm not too daunted by the sprocket for that reason!
    My only worry with that is getting to the front cover bolts underneath the cam shafts to remove the cover.
    Thanks for the help guys. You're my bimmer angels.
      Only the first one looks bad, does the crank have a mark there?  I would get a new set and install them.  Check with plastigage when you put them in, did you pull any of the mains?
        Quick question, which way does the motor rotate when looking at it from the front?
        Quick update:
        Ordered a new oil chain and crank sprocket today.
        I will be ordering bearings tomorrow.
        That's all I got for now.
        Thanks for looking.
          Clockwise. The only engine i have seen rotate counterclockwise is a honda b series
            I have a pump from an m50 if that works?
              YES!!  How much do you want for it?
                  ^saw that.
                  How much??  I'll pick it up ASAP.
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    I heard Rowleym has a pump from an m50 if that works.
                      Somewhere I saw that Rowley has one, try asking him how much he wants for it.
                        Whatever works man! I live in green lake. Shipping works? Or you can pick it up. I'm very busy as of recent.
                        WAIT. I actually live in Princeton wi now.
                          PM'd ya.  Might take a drive to Princeton today!
                            Bearings ordered.  BOOM!!  well, hopefully not this time around.
                            I wish making this car reliable was as easy as ordering parts.
                            Everything I need is here or on its way this week to get this bolted back up ASAP the right way this time around.
                            Now for some thinking out loud:
                            I have been debating on going to a softer engine/trans mount to combat the vibes.  The vibes are both good and bad.  Good for me, bad for the bimmer.
                            If I go MS3 I would use the S52 timing pickup that is in the engine block to reduce the rotating mass of the OBD 1 harmonic balancer timing pickup.
                            Some properly offseted wheels to accommodate a lot of rubber so I'm gripping instead of bouncing the motor of the rev limiter every time acceleration is extreme.  If you know my name this is almost every time the right foot is on that GO pedal.  I will be borderline living underneath the rear suspension and in the trunk, watching for cracks and signs of stress, once there are bigger tires on there.  Hopefully the girlfriend will want to join me.
                            There are more thoughts but the motor needs to be in the front of my mind.
                              hilarious post :D
                              Perhaps you have already read this, but its a good read
                              http://www.atiracing.com/products/dampers/damper_dinan.htm
                              What is your fuel cut set to with the TRM tune?
                                Anyone have a Bentley manual and can look up what the spec is for the gap between the rod bearings and the journal is? Going to plastic gauge them soon.
                                  Both main and rod bearings should be .0008 - .0023" clearance measured with plastigage.
                                    Thank you!
                                      Is it .008-.023?
                                      .0008 seems really tight and plastic gauge doesn't go that small.
                                        A sheet of paper is ~0.003" thick  to have something from the real world you can relate to
                                        Pete McHenry suggests   ".0020"-.0025", with half a thousandth looser on the rear main"
                                        per this post here  http://forums.bimmerforums.com/forum/showthread.php?775356-Main-Bearing-Clearances
                                          IIRC Mine were about .0018.  Use the green that goes from .001-.003".
