  4. 02 e39 530i click when turning
14 Posts 5 Posters 0 Views 1 Watching
  • MarcKM
    MarcKM
    MarcK
    Only while I'm turning. Once I hit a certain angle, it goes away. Driving straight, it's as smooth and quiet as it's supposed to be. The village is 4 traffic circles long, and that angle is enough to make it click.
    I'm really having a hard time wrapping my head around it being a bearing, but... I've got 145k now so I'll probably do them anyway for piece of mind.
    Situations don't make the person, they reveal the person.
      A bearing could make the noise since it is allowing the wheel to tilt during a turn and possibly make contact with something. You could check by simply lifting the car and shaking the wheel, but you know that already=)
        A wheel bearing is a possibility, did you check for movement/looseness of the wheel with it off of the ground?
        • MarcKM
          MarcKM
          MarcK
          I did check for movement, but didn't feel enough of anything to get my attention. If it is the hub, my guess is that this is so early it hasn't started moving much yet.
          I'll be replacing the hub/bearings next weekend. I'll report back either way.
          *I'm actually doing the hubs/bearings on my wife's Pathfinder this weekend. The hub movement is very obvious on that thing.
            Any movement is not good, It should not have any play.  I usually try to rock it from 12/6 o clock, rather than 3/9 o clock which would better check for tie rod/steering rack issues.
            • MarcKM
              MarcKM
              MarcK
              Just an update: Replaced the hub rings shortly after my last post, and the click has not come back yet. I can only hope it was that simple. I'll report back if anything changes.
                Interesting, I'm not sure how what would cause a noise unless the wheel was loose enough to be moving on the hub.  If it comes back just check the lugs for tightness without removing the wheel and see if it goes away again.
                • I love my E39I
                  I love my E39I
                  I love my E39
                  Let me know how the hub replacement goes my wheel bearing has been shot for a while. I will probably just take mine to the shop but still would like to know how it goes
                  Sent from my LG-LS970 using Tapatalk
                  -Because Racecar-
                  • MarcKM
                    MarcKM
                    MarcK
                    Hub bearing being replaced for no reason other than piece of mind probably in the next couple weeks (still spending my wknds fixing our pathfinder). If I don't see a previously posted thread about the hub/bearings, I'll post some pics and instructions, and any problems I run into. Thx guys!
                    BTW... still no noise. No idea how that ring could have MUCH to do with it, but I'll take it at this point!
                    • I love my E39I
                      I love my E39I
                      I love my E39
                      Looking forward to the walkthrough. My upper rad house just went out. I knew I should if replaced it when I had the tensioners and pulley and clutch fan... lesson learned again.. now I have to drive the rally wagon with bad brakes...
                      -Because Racecar-
