<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[02 e39 530i click when turning]]></title><description><![CDATA[<p dir="auto">This one is getting to me a bit. There is a slight click when I'm turning and the noise increases and decreases with my rate of speed. It's coming from the driver's side front wheel. I feel nothing, just hear that click/tick. I've removed the wheels, used a wire wheel to go over everything lightly and sprayed brake cleaner all over everything. Once I put the wheel back on, no noises for a couple days. Then, the click comes back and starts driving me up the wall again! I just changed the brake pads last weekend to see if that made a difference... none, except how quickly it stops again. This honestly makes no sense to me as I can't find anything rubbing, calipers seem to move very smooth, dust shield is pushed back far enough, etc.</p>
<p dir="auto">I'm kinda tired of removing the wheel and putting it back on every few days to get rid of the click. My post is really to see if you guys have any suggestions to what I should check next. </p>
<p dir="auto">I have oversized hubs with hub centric rings. Don't know if the ring could be worn out or not, but I thought that was something I should mention.</p>
]]></description><link>https://wibimmers.com/topic/2745/02-e39-530i-click-when-turning</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:44:52 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/2745.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 May 2014 11:29:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 02 e39 530i click when turning on Sat, 07 Jun 2014 04:16:09 GMT]]></title><description><![CDATA[<p dir="auto">Looking forward to the walkthrough. My upper rad house just went out. I knew I should if replaced it when I had the tensioners and pulley and clutch fan... lesson learned again.. now I have to drive the rally wagon with bad brakes...</p>
<p dir="auto">Sent from my LG-LS970 using Tapatalk</p>
]]></description><link>https://wibimmers.com/post/42684</link><guid isPermaLink="true">https://wibimmers.com/post/42684</guid><dc:creator><![CDATA[I love my E39]]></dc:creator><pubDate>Sat, 07 Jun 2014 04:16:09 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 06 Jun 2014 19:24:25 GMT]]></title><description><![CDATA[<p dir="auto">Hub bearing being replaced for no reason other than piece of mind probably in the next couple weeks (still spending my wknds fixing our pathfinder). If I don't see a previously posted thread about the hub/bearings, I'll post some pics and instructions, and any problems I run into. Thx guys!</p>
<p dir="auto">BTW... still no noise. No idea how that ring could have MUCH to do with it, but I'll take it at this point!</p>
]]></description><link>https://wibimmers.com/post/42662</link><guid isPermaLink="true">https://wibimmers.com/post/42662</guid><dc:creator><![CDATA[MarcK]]></dc:creator><pubDate>Fri, 06 Jun 2014 19:24:25 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Tue, 03 Jun 2014 20:57:13 GMT]]></title><description><![CDATA[<p dir="auto">Let me know how the hub replacement goes my wheel bearing has been shot for a while. I will probably just take mine to the shop but still would like to know how it goes</p>
]]></description><link>https://wibimmers.com/post/42434</link><guid isPermaLink="true">https://wibimmers.com/post/42434</guid><dc:creator><![CDATA[I love my E39]]></dc:creator><pubDate>Tue, 03 Jun 2014 20:57:13 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Tue, 03 Jun 2014 13:52:48 GMT]]></title><description><![CDATA[<p dir="auto">Interesting, I'm not sure how what would cause a noise unless the wheel was loose enough to be moving on the hub.  If it comes back just check the lugs for tightness without removing the wheel and see if it goes away again.</p>
]]></description><link>https://wibimmers.com/post/42381</link><guid isPermaLink="true">https://wibimmers.com/post/42381</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 03 Jun 2014 13:52:48 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Tue, 03 Jun 2014 10:50:17 GMT]]></title><description><![CDATA[<p dir="auto">Just an update: Replaced the hub rings shortly after my last post, and the click has not come back yet. I can only hope it was that simple. I'll report back if anything changes.</p>
]]></description><link>https://wibimmers.com/post/42365</link><guid isPermaLink="true">https://wibimmers.com/post/42365</guid><dc:creator><![CDATA[MarcK]]></dc:creator><pubDate>Tue, 03 Jun 2014 10:50:17 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 19:09:54 GMT]]></title><description><![CDATA[<p dir="auto">Any movement is not good, It should not have any play.  I usually try to rock it from 12/6 o clock, rather than 3/9 o clock which would better check for tie rod/steering rack issues.</p>
]]></description><link>https://wibimmers.com/post/42172</link><guid isPermaLink="true">https://wibimmers.com/post/42172</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 30 May 2014 19:09:54 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 17:34:43 GMT]]></title><description><![CDATA[<p dir="auto">I did check for movement, but didn't feel enough of anything to get my attention. If it is the hub, my guess is that this is so early it hasn't started moving much yet.</p>
<p dir="auto">I'll be replacing the hub/bearings next weekend. I'll report back either way.</p>
<p dir="auto">*I'm actually doing the hubs/bearings on my wife's Pathfinder this weekend. The hub movement is very obvious on that thing.</p>
]]></description><link>https://wibimmers.com/post/42164</link><guid isPermaLink="true">https://wibimmers.com/post/42164</guid><dc:creator><![CDATA[MarcK]]></dc:creator><pubDate>Fri, 30 May 2014 17:34:43 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 17:07:04 GMT]]></title><description><![CDATA[<p dir="auto">A wheel bearing is a possibility, did you check for movement/looseness of the wheel with it off of the ground?</p>
]]></description><link>https://wibimmers.com/post/42158</link><guid isPermaLink="true">https://wibimmers.com/post/42158</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 30 May 2014 17:07:04 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 16:48:27 GMT]]></title><description><![CDATA[<p dir="auto">A bearing could make the noise since it is allowing the wheel to tilt during a turn and possibly make contact with something. You could check by simply lifting the car and shaking the wheel, but you know that already=)</p>
]]></description><link>https://wibimmers.com/post/42154</link><guid isPermaLink="true">https://wibimmers.com/post/42154</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 30 May 2014 16:48:27 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 16:06:03 GMT]]></title><description><![CDATA[<p dir="auto">Only while I'm turning. Once I hit a certain angle, it goes away. Driving straight, it's as smooth and quiet as it's supposed to be. The village is 4 traffic circles long, and that angle is enough to make it click.</p>
<p dir="auto">I'm really having a hard time wrapping my head around it being a bearing, but... I've got 145k now so I'll probably do them anyway for piece of mind.</p>
]]></description><link>https://wibimmers.com/post/42151</link><guid isPermaLink="true">https://wibimmers.com/post/42151</guid><dc:creator><![CDATA[MarcK]]></dc:creator><pubDate>Fri, 30 May 2014 16:06:03 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 14:35:45 GMT]]></title><description><![CDATA[<p dir="auto">Hey Marc, you said it happens when you are turning?  Or all of the time when moving?</p>
]]></description><link>https://wibimmers.com/post/42145</link><guid isPermaLink="true">https://wibimmers.com/post/42145</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 30 May 2014 14:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 12:30:04 GMT]]></title><description><![CDATA[<p dir="auto">No spacers, everything is stock right now except the rings. I found two possible answers, but one of them doesn't make sense to me. One person said they replaced the sway bar links and the click went away for them. I could buy this one. The other suggestion was wheel bearing. I thought a bearing would make more of a grind or humming sound (?). Is it possible that it's a click from the driver's side wheel bearing?</p>
<p dir="auto">*You make a good point. Because I'm rather anal, I want a concentricity gauge to have around just in case now.</p>
]]></description><link>https://wibimmers.com/post/42138</link><guid isPermaLink="true">https://wibimmers.com/post/42138</guid><dc:creator><![CDATA[MarcK]]></dc:creator><pubDate>Fri, 30 May 2014 12:30:04 GMT</pubDate></item><item><title><![CDATA[Reply to 02 e39 530i click when turning on Fri, 30 May 2014 11:40:04 GMT]]></title><description><![CDATA[<p dir="auto">Do you have wheel spacers? if so, they may not be installed concentrically and could be bumping the bottom of the caliper</p>
]]></description><link>https://wibimmers.com/post/42135</link><guid isPermaLink="true">https://wibimmers.com/post/42135</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 30 May 2014 11:40:04 GMT</pubDate></item></channel></rss>
