  4. Cosmos Resurrection
Cosmos Resurrection
87 Posts 10 Posters 0 Views 1 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    Get a g260 behind that seta and a JM performance exhaust and you won't regret it!!!
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      It has a belt driven vacuum pump then?
      Another option is to delete the booster using a kit like this.  From a little reading it seems wise to go with a smaller diameter master cylinder to require less pedal force.  Surprised Earl isn't doing this to keep it ultra clean under the hood.  I may actually do this on my e36, undecided yet though.
      I am doing a Massive Brakes delete haha
        ^ I called that one.  I meant to link their site: http://www.massivebrakes.com/brake-systems.php?p=brake-booster-delete
        Have you driven a car without power brakes?  I have not, and am curious what it is like.  Although proper sizing will make the difference between good and bad I suppose.
          I have not, but in the name of simplifying everything, I will suffer through it=)
            Less isnt always more. Countersteering in a rwd car w/o powersteering sucks
              Oh well=) I have driven cars without power steering and above 20mph doesnt bother me at all
                Mkoepp is the drift king though. He doesnt often go for a drive that isnt full of opposite lock
                • mkoeppM
                  mkoeppM
                  mkoepp
                  Only been gone from the outernet for 2 days and look at all the replys. I thank you all.
                  I know a M30 to a M20 swap is not a well documented here. I am doing this for several reasons.
                  1. I am not building a gem here. I want to have the same comfort, gas mileage and enjoyment that my seta provided.
                  2. My dad "loves" the ride with 14" bottle caps and stock suspension. I like the ride also...enjoyable and even more so if you have a bad back as I do.
                  3. I want to have it done with as little down time as possible once started.
                  I would like to try this but I value my investment more than I trust my abilities.
                    True, I would not remove power steering, but brakes may end up with better control/feel manual if set up properly, the kit already changes the pedal ratio from 4:1 to 6:1 to decrease effort, and you can choose between several master cylinders that will bolt right on to get the desired diameter.  Mikes e28 has awesome pedal feel, not sure if the difference is because of no ABS?  It feels very firm, like I imagined it would be with SS flex lines (That's the best I can describe it).  But on my e36 I want it to feel like that, I am removing the ABS (didn't work anyway and I don't drive it in the winter) and doing SS flex lines.  Then again mine may take longer than Earl to finish...
                      I hope manual brakes aren't as ineffective as when you roll your car down the driveway without turning it on and try to use the brakes.  Id have to imagine the mechanical advantage of the MC is a little higher than on a power brake setup.
                      Brake pads with really good cold bite would probably be important. I cant stand the brake pads I have even with power assist.
                      I ate oatmeal for breakfast
                      buy silver in middle of week
                        I ate pancakes for breakfast!
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          Nuff said...
                          • andyhundleyA
                            andyhundleyA
                            andyhundley
                            Mike I have a extra g260 trans with early style shift carrier and a full shifter rebuild with all oem parts that will be available soon if your interested. All you would need is the pedal setup, clutch master/slave setup and a clutch/flywheel.
                            • mkoeppM
                              mkoeppM
                              mkoepp
                              I may have to take you up on this if funds are available at the time. The pedal, clutch and slave are all in the car which would make it easier.
                              • mkoeppM
                                mkoeppM
                                mkoepp
                                Well after thinking about it for way too long, I decided to dismantle the 533 rather than the seta. It is the better looking of the two runners I have but the seta is just plain worn out and the swap will take less time. The 533 has rust in many hidden areas but has lots of goodies. I will drive the seta (very reliable despite the looks) this winter and hope to have the 535 running soon.
                                I have ordered and have received new sub frame bushings, dog bones, diff mount, CSB, engine gaskets ect... I am ready!!
                                I cancelled insurance on it this morning just to put in cement and deter me from changing my mind again. I have most all of the interior out. I am cleaning/installing the interior to save space and chance of damage due to just laying around. Space is still a problem.
                                It has taken a while but I am really hyped on this. Depending on work/free time I hope to have this running in two weeks.
                                • mkoeppM
                                  mkoeppM
                                  mkoepp
                                  I know...Pictures will come soon.
                                  Nothing to really see at the moment.
                                  • mkoeppM
                                    mkoeppM
                                    mkoepp
                                    Well it's coming along slow but sure. Interior all swapped and hope to have the engine out by mid week.
                                    I may take the valance off my seta...better shape and closer in color. I can't put the US diving board bumper on yet because of garage door clearance.
                                      400x268xpufferSmile2.jpg.pagespeed.ic.OQ
                                      What is the ultimate plan for this car again? M30/M20/5spd/Auto/Cruiser
                                      glad to see progress.  love the E28
                                      • mkoeppM
                                        mkoeppM
                                        mkoepp
                                        Plans have changed. I am taking my M30 and 5 speed out of my 533 and running the seta this winter. I figure it will be plug and play since the pedals are in it and the car had a M30. I plan on bringing this car to the party next month :)
                                          I think we need to organize a caravan for us southerners to drive there
