686 Posts 32 Posters 8.9k Views 3 Watching
    If you keep the M20 carbs would be a unique look. http://www.performanceforums.com/forums/showthread.php?67286940-NA-M20-with-TK-goodness
    If you're going for big power go 24v.
    Mention of ditching EFI for carbs  and ditching M20 for 24v
    all in one post.
    I cant handle this.
    Haha. That post has Snap written all over it!
      ClassE said:
      He means a runner angle like this:
      Which would work best for NA if you can clear the booster (or delete it). Longer runners will give more torque in lower RPMs.
      I love this idea - I'm not sure it's a "whack it up and weld" kinda job - but I don't know your fab skills either. Regardless - if I stay M20 this is most likely course of action in fall!
      If Anyone has a CAD drawing of an m20 manifold flange, I could CNC a flange, and not use the stock stuff at all, but then I would also have to build injector bungs, and then it starts getting costy(for you guys).
      I was going to use the stock manifold, and cut the flange, to try and keep the cost low for the people. And its damn easy.
      But I do have material for 3 Intake manifolds for supercharged m50's currently
      I am adapting a gen 3 eaton m90 to 24v's, but I am also thinking about doing it to an e30 :)
      But I do not have velocity stacks yet(wasn't going to use them with the supercharger) and I don't have those little bends.
      But why did you say 130* snap?
        I was laying on my side while I posted that, now that I am right-side up, it would be more of a 60-70 degree bend.
          Started replacing front tie rods last night - didn't know BMW used a lock plate to hold the inner tie rods.... Which apparently needs to be replaced since you ruin them removing the originals.
          So dealership will have some for me tomorrow - car sits until then. :( So no alignment before Saturday. No happy about it - but not super concerned either. Rear toe looks good, car tracks straight, camber is alittle off side-to-side but not enough to worry me for 200 miles.
          After the GTG.... Time for some painting and coating in the bay before Scooters.
            E36/Z3 does not use lock plates.
            I just used blue loctite on my Z3 rack and have had zero problems with it.
            Ask anyone about what a sane and gentle driver I am and you will take comfort in knowing its kosher :D
              My compact uses them
              http://www.realoem.com/bmw/showparts.do?model=CG53&mospid=47505&btnr=32_0630&hg=32&fg=25
              It also looks like other e36's use them
              http://www.realoem.com/bmw/showparts.do?model=BG13&mospid=47485&btnr=32_0630&hg=32&fg=25
                None on the Z3 though
                [http://realoem.com/bmw/showparts.do?model=CJ33&mospid=48094&btnr=32\_0630&hg=32&fg=25
                I](http://realoem.com/bmw/showparts.do?model=CJ33&mospid=48094&btnr=32_0630&hg=32&fg=25) am using E30 tie rods with the Z3 rack, there is nothing special about the Z3 rack that would aid in tie-rod retention.
                The primary reason for the lock plate from my own observation is to keep the inner tie rod from loosening during an alignment.
                But take what I say as typical forum hearsay, I was not present in the ZF steering rack design meetings to be able to know the exact reasons why.
                Im not from here.
                  lol I wasn't ripping on you Snap=) I trust your word over most things
                    Oh I know, no rustlin over here.
                    I want to make sure I am not feeding bad information so I do my best to backup what I say when there may be question
                    • andyhundleyA
                      andyhundleyA
                      andyhundley
                      Earl and snap are going to fight to the death Saturday morning!
                        things get tense when your project isnt finished.
                          "Snap said..."
                            Just to throw in my 2 cents, my 2/94 e36 steering rack has lock plates.  If you are going with just loctite, make sure you get the threads clean with brakeclean or something so that the loctite actually works.
                              So replacement inner tie rod ends are "fatter", so not enough overhang to bend washer flanges down.... Nice.
                                Eh, just giver!
                                  Blue loctite and DUN... Taking to work tomorrow as a test run for Saturday... Kinda worried still about the quasi-whine thing from rear.
                                    Well... Might not make GTG now on Saturday.
                                    Broke upper bearing spring seat on coils, having pieces brought to machine shop tomorrow to hopefully remake. Long story - to angry and tired to elaborate... So pics and info tomorrow.
                                      Well - three emails back and forth to Igor already tonight (he must be up late - it's friggen 11:15pm). Bedtime - tired and sad.
                                        =/ It seems to be a super simple piece so getting it machined today shouldn't be impossible. This does sucks though=(
                                          Yeah, I don't think it'll be a big deal. I'm more upset I'll have zero wheel time to troubleshoot any issues before hoping on a highway tomorrow AM. We're having both sets of parents over tomorrow night for a birthday dinner for my mom - so can't get wrenching until after that...
                                          If it wasn't for the last minute - nothing would ever get done.
