  4. 1978 e21 m20 turbo swap, AKA What did I get myself into
do it myself
192 Posts 14 Posters 3.4k Views 3 Watching
    bfinley
    Rowleym said:
    ^ I thought it was done from the PO
    Thought what was done?
      bfinley
      Went into the shop planning to clean and organize my pile of parts ...
      Ended up wrestling the fenders off. Thankfully they were not welded on, just a nasty combo of some kind of gasket paste and rubber under coat...
        bfinley
        Goodness it's been a while, I've been slowly removing paint and bondo.. Gonna take it down to bare metal and build it back up. I finally got an argon tank for the welder. So after commencement I'll be patching the floors. Picked up a 2.7 eta from mike, full harness and ECU, connected to an auto trans which has already been removed. Fighting with the torque converter though.
        so if anyone has an 885 head laying around... I want it
        I'll get some pictures over the weekend
        Mike and maybe John are going to come down this weekend to help me get the 2.7 eta on a stand, grind down some more paint and pull the dash.
          bfinley
          Dash is out, brake booster is out, steering column is out, tail lights are out.
          Still need to get the heater core.
          Finally down to just a shell, going to make a trip to steel mart soon and get the floors patched. Then order the roll cage next month.
            Looks good, I hope you took lots of pics of how the wiring goes lol.  How much interior do you plan on putting back?
              We dont frequently get to see the finished product of a project thread on here. I hope we get to see this one finished!
                bfinley
                The dash will go back after I add some tubing for structural integrity.
                John you know Mike and I aren't as meticulous as you are, we'll just remember where everything went right? ok there isn't a chance I'll rememer and we definitely didn't label them. Most everything in the dash however will not be going back. I'll be making a custom gauge cluster with lots of aircraft style switches, because I can !
                Snap, this car will be driving and painted by the end of the summer
                  Do work!!  Looking good and it is good to see it being done the right way.
                    bfinley
                    Thank you!
                    I don't know about "done the right way" but it's going to get done and it's going to be obscenely fun
                      Thank you!
                      It seems you aren't bandaidin' the car. You're getting in there and addressing the issue. That's done the right way in my book!
                        bfinley
                        I found my dash !
                          :cool:   This does nothing except get me in trouble with my wife for spending too much money on oem parts...  I would not recommend being OCD like me.
                            bfinley
                            I may have gotten a little ahead of myself
                              Is that a whole new quarter?
                                bfinley
                                No thankfully. It is a whole sprsy csn of primer
                                Sent from my SCH-R830 using Tapatalk
                                • RamRod E28R
                                  RamRod E28R
                                  RamRod E28
                                  If you are doing that dash you need some shark mouths painted on the front fender to match the fighter plane cockpit
                                  1988 BMW 528e - Need parts?
                                  1996 Mazda Miata (SOLD!!!)
                                  1996 BMW 325i (Donor car)
                                    bfinley
                                    Ok after a ride in Mikes e28 I'm chomping at the bit to get the motor and trans together and back in the car... (after fixing the floor and all that nonsense.)
                                    So I need a clutch and flywheel since the ETA motor I bought off mike was an autotragic.
                                    Pelican and BAVauto want roughly 5-700 dollars for a clutchkit and flywheel so I've turned to ebay.
                                    Before I pull the trigger I'd like some reassurance that I'm buying the right parts since I'm frankensteining parts from different years together.
                                    Motor is out of a '84 528e which is what I've speced the clutch and flywheel for.
                                    Trans is a midyear 85/86 GT260
                                    Pretty sure it should all match up....
                                    Here are the links I'm looking at
                                    http://www.ebay.com/itm/SACHS-FX-CLUTCH-KIT-84-93-BMW-325-e-es-i-is-ix-525i-528e-2-5L-2-7L-E28-E30-E34-/400687829057?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1984|Make%3ABMW|Model%3A528e&hash=item5d4adb1041&vxp=mtr
                                    http://www.ebay.com/itm/EXEDY-CLUTCH-PRO-KIT-BMW-325i-325is-325ix-525i-2-5L-E30-E34-M20-528e-2-7L-E28-/161027461479?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1984|Make%3ABMW|Model%3A528e&hash=item257dfc1167&vxp=mtr
                                    May have just found a clutch and flywheel on car-parts.com fingers crossed
                                    I want my car back!
                                    • RamRod E28R
                                      RamRod E28R
                                      RamRod E28
                                      car-part.com is a magical website!!!
                                        bfinley
                                        It is. Im hopefully getying fenders from them as well
                                        • RamRod E28R
                                          RamRod E28R
                                          RamRod E28
                                          why not just a whole parts car? everyone needs one... :)
