E28 SETA Build
I have had to repair my e36 harness where it bends for the trunk to open as well. Use some 3M rubber splicing tape over the whole thing once you repair the wires, it seals to itself and stretches very tight. I use it at work for insulating lug/bolted motor wiring connections, but you can find it at at any hardware store.
Ok... Finally got my parts from Pelican after ordering almost 2 weeks ago... not too happy about that and they didnt even send me a sticker
and I realized that I ordered the wrong size copper lock nuts for my exhaust studs so gonna see what options I have.And found out why my trunk would only open with the key in the tumbler and why the trunk open light would stay on with it shut...
That was a fun one to get to i had to almost cut the entire boot in half to get to it.
Some e28 getting put back together porn coming your way soon!!!
As a matter of fact it does! You would not believe the amount of dirty looks I get! It's actually worse than the no fat chicks sticker with the whale below it
So made some progress on the e28's super eta. I installed the new exhaust manifold studs (which go in a lot further than you'd expect). I got the old manifolds of the original eta because the super eta has a different downpipe layout over the regular eta. Also I got the oil pan off the seta which had about 20 lbs of nastiness all over it so i used about half a roll of shop towels and brakleen to get all the greasy shit off of it. Then ground off all the old gasket on the pan which is hard as a fugging rock. Gonna tackle getting all the old gasket off the block with a scraper tomorrow. Also I wanna find the ass that thought that using 26 tiny very fine threaded bolts to hold the oil pan on was a good idea and kick him (or her) square in the man (or girl) BALLS!!!
We'll busted my ass on the e28 all day massive update and pics to come tomorrow!
Ok finally back on to do an update... Last time I left off on here was I got most all my parts for the Super ETA swap and manual swap.... Well here some pics and some info for whats been done.
Well I removed the oil pan and cleaned up all the nastiness and didn't get any pics of that just due to wanting to get it out of the way and wasn't all too entertaining just getting all the nasty hard gasket off and putting the new gasket on. But then I moved on to the timing belt and water pump. This was just one swipe from under the crank!
Timing belt and water pump are on! That was so easy to do on the m20 (Does anyone have an M20 Water pump pulley? need one ASAP!!!)
The blurry engine has taken flight!!!
Shits about to go in
Going in
Close... But no cigar
Finally after wiggling and jacking the trans up and down about a bajillion times I got the engine to set down on its mounts and bolted in the trans crossmember!!!
Here's what my old trans bushings looked like compared to the new ones
Starting to look like a car again!!!
Bye bye gangster lean
The harness is "in" lol
The condenser and the radiator are now bolted in place some of the hoses are set in place also the exhaust the driveshaft and the heatshield are in the car now
The shifter is in thanks to Mr Menard for his mad fabbing skills
Just need a few things and new fluids and its ready to roll and do some maaddd!!! burnouts
Anything can be done with a welder, you would be doing some crazy shifting to break that bracket off lol. We got some good stuff done today, I will get the corroded nasty hose connector off of the thermostat housing this week, I picked up a brass plug for it on the way home.
With balls big enough you don't need one.
southpark comes to mind
Chillax I do have a seat guys its just laying in the back seat. the drivers front seat install is the very last thing to do to let me know that the car is running and driveable.
but what if its not, what if in a haze of mid-grade petroleum fumes, you rush to the passenger compartment to go for your initial drive, forgetting that there is no seat, and lob yourself into position only to crush your twig-n-berries on the formed hump in the unibody.
I don't get the feeling that you are considering all the possible scenarios here.
and for that i give this thread a 1 star rating
Dafuq is this thing??? http://www.stanceworks.com/forums/showthread.php?t=24047 and snap... pleezzzz vote up a little those 3 stars make me feel insufficient
Cool idea, terrible execution.
Did you ever see this one?
BMW never offered even a concept, but there were a few companies that did touring conversions.
This is sex.
So the e28 touring is a myth
I've seen that one and I would trade almost everything I own to get one!!!
